HeadlightArmor
Old 06-17-2014, 03:43 PM   #1
Protaper
Drives: 2012 camaro ss
vibration from lowering cradle
I upgraded my fuel pump to the ZL1 pump which required drive shaft removal and lowering the rear cradle. Now I have a significant vibration at about 50mph and above. the vibration does not change with pushing in the clutch. Is there an alignment step for replacing the rear cradle?
Whipple 2.9, K&N CAI, JBA LTH, high flow cats, ZL1 pump, MSD BAP, JRE tune
Protaper is offline   Reply With Quote
Old 06-17-2014, 04:21 PM   #2
BMR Sales
BMR Sales's Avatar
Drives: Race Car
No, there should be no alignment required after lowering the cradle. Did you mark the driveshaft yokes prior to taking it out and put it back in the same exact position? I'm not saying that is the problem, but it could have something to do with it. The rubber "guibo" isolators are supposed to absorb driveshaft vibration, but it might be worth a shot trying to re-clock the driveshaft to one of the other of the three positions.
Old 06-17-2014, 04:29 PM   #3
Protaper
but pushing in the clutch dosent change the vibration. shouldn't the drive shaft slow down and decrease vibration if that was it.
Old 06-17-2014, 04:37 PM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yeah, you would think so, but I've seen these cars do stranger things!!! Just saying it might be worth a shot. There isn't a whole lot of play in the movement of the rear cradle since it has those alignment pins.
Old 06-17-2014, 04:45 PM   #5
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
No. Depressing the clutch only relieves the driving force from the shaft. Drive shaft spins if the rear axles are spinning. The faster the rear wheels, the faster the drive shaft goes. It honestly sounds like the driveshaft was not attached properly.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 06-17-2014, 04:54 PM   #6
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
Agreed. Driveshaft is first thing to check, then anything else that rotates that you took loose like wheels.
Southern Comfort is offline   Reply With Quote
Old 06-19-2014, 04:49 PM   #7
Protaper
thanks guys. Drive shaft was in the wrong position despite the mechanic marking both sides..Dont know how that happens but its fixed.
Old 06-19-2014, 05:10 PM   #8
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Good to hear it's fixed.
