HeadlightArmor
Old 06-20-2014, 08:44 PM   #29
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Installed, time for the moment of truth, test drive.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is online now   Reply With Quote
Old 06-20-2014, 08:47 PM   #30
paraphlax
paraphlax's Avatar
Drives: 2012 LFX Bumblebee IPF Supercharged
Very interested in how this turns out! Looking to go with meth and a smaller pulley in a few months also.
paraphlax is offline   Reply With Quote
Old 06-20-2014, 10:18 PM   #31
MagnumForceGB
What an adventure, forgot to tighten up the clamp that goes into the intercooler, realized it before I got on it and had to turn back to fix it. Took it out again but never went over 6000 RPM's, at 5000 RPM's my PSI was at 6, AFR was around 12. Before my PSI at that point was 4 so I've gained 2 PSI. I had 0 knock retard, so no detonation was occurring.
I went and got a K061058 belt, going to install it tomorrow and do some more runs. The worse part about this is I'm hearing every little noise, but the computer is saying everything is ok.
Old 06-20-2014, 10:46 PM   #32
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Old 06-21-2014, 12:43 AM   #33
MagnumForceGB
Got bored and installed the new shorter belt. I used K061058 and it has the same tension as the stock belt with the stock pulley. You have to make sure it is in the groves exactly before putting it on the water pump pulley, it is very tight.
Old 06-21-2014, 03:54 PM   #34
MagnumForceGB
Went all out today and the car felt great. Max boost is about 11-12 psi, had to up my meth nozzles though, was running 12.5 after 6000 RPM's, switched to a bigger nozzle and now run 12.
The car moves through 1st and 2nd gear extremely fast now, 3rd gear hauls ass too. I'm getting just 1 degree of knock at 5000 RPM so I may have to meth turn on just a hair earlier.
Current setup is:
IPF Supercharger with 3.48" pulley
Snow Performance Stage 2 Meth controller, 1x 60 cc/min before supercharger (keeps it cool), 1x 225 cc/min 18" before IAT, 1x 175 cc/min 6" before IAT
IAT relocated to 4" before throttle body
Ported Intake Manifold
American Racing Headers 1-7/8" Headers
ARK DT-S 2.5" catback
Denso ITV24 Spark Plugs (2 steps colder) with a 0.030" gap
I will see how the week goes on testing, but seems good so far.
Old 06-21-2014, 04:39 PM   #35
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Very cool. Look forward to more testing .
Lil' Nasty is offline   Reply With Quote
Old 06-23-2014, 12:36 PM   #36
MagnumForceGB
I took this video on Saturday before I upgraded the meth nozzle, shows my boost going past 10. Right now my car runs 12:1 AFR after that initial rich condition. Today I drove the car with the windows down and right at max boost I can start hearing what sounds like the by-pass valve being forced open. I don't know if I have to upgrade my by-pass valve and if one will fit.
Also, I get 1.5 degrees of knock retard at 5000 RPM's, none after that. I'm running 20 to 18 degrees of timing, which is pretty damn good on 91 octane with 51/49 water/meth injection. Car feels great with this pulley, don't know if I would go any lower though without new internals.
Old 06-23-2014, 05:44 PM   #37
Ventmaster
Ventmaster's Avatar
Looks like 11.5 lbs of boost to me! Nice build- you're really making progress and breaking new ground!
I'm also envious of your amount of free time!
Old 06-24-2014, 11:18 AM   #38
MagnumForceGB
Thanks, car feels good with the extra boost down low. Pulls hard till red line also, might have traction issues at the track Friday.
I upped the 60 nozzle to a 100 and am down to 0.7 knock retard, will see if it stays that way. The next biggest nozzle I have is a 375, up from a 225. I may just swap my 175 and 225 nozzles around if the knock retard stays at 0.7.
Old 06-24-2014, 11:28 AM   #39
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
Looks like a great mod. So how much boost did you pick up in the end?
Jason@ is offline   Reply With Quote
Old 06-24-2014, 12:50 PM   #40
MagnumForceGB
2-3 psi, starts lower also at 2000 RPM's. Can't be completely accurate since I don't have a digital boost gauge, analog looks cooler at car shows. It is a good mod, but I feel you should have the supporting mods before it, namely good flowing headers and intake.
Turned off traction control and put the car in sport mode, from a 20 mph roll the tires started smoking at 5000 RPM's in 1st gear. Left 2 lines of tire marks on the highway for about 15 feet.
Old 06-24-2014, 01:56 PM   #41
KMPrenger
KMPrenger's Avatar
Wow...very cool! Sounds like its working very well so far! Gotta love that extra boost down low as well.
Sounds like maybe IPF should look into offering an 11 - 12 psi pulley in addition to the stock 9.
Old 06-25-2014, 10:45 AM   #42
MagnumForceGB
They could package a Boost and AFR gauge, smaller pulley, shorter belt, and updated PCV system together, make some money off that.
I've been dialing back my meth at low RPM to get the AFR back to 12, was 10 before. I need a digital meth controller though so I can accurately set the start and end points, the one I have is not accurate.
