Emblempros
Old 07-08-2014, 11:26 AM   #85
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Forgot to mention that this was with the V60C1C10 tune which is leaned out already. On a richer tune like V60C1D it might be better.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 07-09-2014, 12:50 PM   #86
MagnumForceGB
Just confirmed that knock retard is learned by the ECU and the only way to clear it fully after adjustments is to reset the ECU. I had 4.5 degrees of knock at 1130, I reset the ECU and had 0.0 degrees of knock at 1200, no other changes.
I also am running a 225 cc/min nozzle in front of the supercharger, boost went to 12 psi on my gauges, no knock. Temp was 77℉.
Old 07-09-2014, 06:13 PM   #87
MagnumForceGB
So weirdest thing happened today on my way back from work, zero knock retard anywhere. Usually I get a few degrees at low RPM's, but none today. I also had 12# of boost in 90 degree weather, so the IAT seal was leaking badly at the track. AFR was at 12:1, but the timing was only 16 degrees. With the IAT relocated to before the throttle body it might be possible to add more timing based on getting a more accurate reading.
Not touching the car anymore until Friday when I race at the track. Not even going to take my subwoofer out, so there will be an extra 70 lb's in the car.
Old 07-09-2014, 09:40 PM   #88
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
Really pulling for you to get some good times! Glad to see you seem to be nailing this mod down. I'll still be surprised if Arno/IPF decides to offer this, (especially with warranty) but I could be wrong, especially if they can supply the fuel.
You say after the ECM reset you had no knock, so that's great!
Maybe IPF should just offer a smaller belt right from the get go...something in between their current setup and yours to provide another 1 or 2 psi of boost. That, and if they do end up re-designing their evap system it would be a killer kit.
Old 07-10-2014, 11:51 AM   #89
MagnumForceGB
I'm hoping for a good night at the track too, but I've been down this road before where the car feels great on the street then falls flat at the track.
Good news is, the engine still has no knock and it looked like my boost gauge touched 13 psi. I need to get a PLX boost gauge that I can log with my torque app also so I can be sure. This is with a 225 cc/min meth nozzle in front of my supercharger, which is will be looked down upon by some.
I think IPF can do a 3.60" easily, I would test if the V60C1D tune could handle my 3.48" pulley but I don't want to run without meth again. Arno is going out to Arizona later this month so they might be doing some pulley runs, see if there is an improvement.
Old 07-10-2014, 03:32 PM   #90
Jason@JacFab
Jason@JacFab's Avatar
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Here's a 3.33 for sale if you think you can push it...
http://www.camaro5.com/forums/showthread.php?t=326446
Jason@JacFab is offline   Reply With Quote
Old 07-10-2014, 04:09 PM   #91
MagnumForceGB
He is asking too much for a used one, you can buy brand new for $81.
Old 07-10-2014, 04:42 PM   #92
Jason@JacFab
Thought they were more... It's been for sale for 8 months... Offer him $40
Old 07-10-2014, 04:55 PM   #93
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 Summit White 2LT/RS
^^ MOAR POWAAAAAAHHHHHHHHHHHHH
Mods: (VMAX Ported Throttle Body, old), K&N CAI, 1LE Strut Tower Brace, Solo High Flow Cats, Elite Engineering Catch Can, Apex Scoop w/ Washer Relocation Kit, CTS Front Caliper Conversion, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, Custom 3" Magnaflow Exhaust, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch
DSX_Camaro is offline   Reply With Quote
Old 07-10-2014, 07:04 PM   #94
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Do it! Do it! Do it!
Mods:
Roto-Fab Intake, WW Reservoir kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness.
Old 07-10-2014, 08:11 PM   #95
MagnumForceGB
I plan on doing a 3.33" pulley, want to get this 3.48" pulley down first to show the gains.
About to order 2 AFR widebands from PLX with the DM-6 gauges and a Vacuum/Boost sensor so I can log the data with my bluetooth device. Feels like I'm never going to get the money to do 3.91 gears.
Old 07-10-2014, 10:41 PM   #96
KMPrenger
KMPrenger's Avatar
You may not need to if this all works out. You should be running 12s around 110+ and maybe you'll be happy?? lol (always more power is better right)
I just don't think 3.91s have proven as a good mod for the 1/4 mile yet, so maybe don't get in a hurry for them.
Old 07-11-2014, 09:51 AM   #97
DSX_Camaro
DSX_Camaro's Avatar
I mean, no one that I've seen has actually used 3.91s to get themselves any better off compared to stock. 3.45 gears, though, would probably help a little bit.
Old 07-11-2014, 12:04 PM   #98
MagnumForceGB
My wife gained 0.5 seconds with 3.73 gears even with the car shifting 6 times from tire spin. The key is tires and mods that give you top end power. Anything that helps from 4500 RPM's and up is needed. That is why I'm looking at 3.33" pulley, will put a lot of boost in that area.
I'm doing the 3.91's to get the 1LE differential brand new, feels like my axles are going to break because of the awesome power my car has. If 3.91's are too much I will change them to 5.10's and do wheelies everywhere like a boss.
