SDTW Custom Wheels & Tires
Old 06-18-2014, 12:17 PM   #1
failingpig
failingpig's Avatar
Drives: 2011 1LS
halo problem
I walked out to my car and noticed that half of my halo kit wasnt lighting up on the passenger side. I get down and look at it and it looks like the headlight housing is starting to bow in and break the lights.
Anyone have any problems like this?
Thanks for any help
failingpig is offline   Reply With Quote
Old 06-18-2014, 12:18 PM   #2
failingpig
failingpig's Avatar
Drives: 2011 1LS
http://i.imgur.com/tUhqfHs.jpg
Here's what it's doing
Old 06-18-2014, 12:26 PM   #3
FrankieBee
Drives: 2010 Camaro 2LT
Looks like the halo came off the housing, it may have been attached to housing with silicone which came apart. The housing will not "bow", its your halo. Who did the install??
FrankieBee is offline   Reply With Quote
Old 06-18-2014, 12:46 PM   #4
failingpig
failingpig's Avatar
Drives: 2011 1LS
I bought the whole headlight assembly from AAC.
Old 06-18-2014, 12:47 PM   #5
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
As he said, the housing is clearly in tact, the aftermarket halo broke free of its glue.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 06-18-2014, 01:02 PM   #6
jgray1978
jgray1978's Avatar
Drives: '12 2SS/RS 45th vert, '14 2SS/RS
Send it back to them if under warranty.
jgray1978 is offline   Reply With Quote
Old 06-18-2014, 01:10 PM   #7
failingpig
failingpig's Avatar
Drives: 2011 1LS
I doubt it's still under warranty.
I've had then for almost a year
Old 06-18-2014, 01:55 PM   #8
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
Then they should be under warranty. Their adhesive should not fail in less than a year for what they charge. I would contact them ASAP about it.
Deke736 is offline   Reply With Quote
Old 06-18-2014, 05:12 PM   #9
FrankieBee
As long as you have your receipt they should honor the warranty. Just ask when the warranty for workmanship will end as it may happen again.
Old 06-18-2014, 05:57 PM   #10
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT & Fifty
Call AAC, it shouldn't be hard to take it apart and remount the halo
Sent from BLACKOUT using Tapatalk
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 128Mods: CAI CAI, Emblempros Dash Plaque, R/C Lic. Plate, Fbodfathers signature, AAC SMD SML, AAC P13 LED DRL, TF center console, Full dash ABL, Noweed Exhaust Diverters, Heritage Grille, Door Projectors, 20watt LED reverse lights with strobe features, S.S. black billet grille with air scoops, custom designed engine cover, custom designed "BLACKOUT" cross drilled / slotted rotors, Borla S-type exhaust, Elite Engineering oil catch can, Nitto Invo Tires WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
halos, headlights, oracle
