Old 08-09-2009, 12:28 AM   #1
FLYNNZL1
Wicked ZL1
FLYNNZL1's Avatar
Drives: 2017 ZL1 A10 HBM
Send a message via ICQ to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
How does onstar know what tire pressure I have?
How does onstar know what tire pressure I have? What on the car can read tis information?
2017 Hyper Blue Metallic ZL1 A10/CF Hood Insert/PDR/NAV MODS: Clear Bra/LED Reverse Light/Rock Guards/Lift Pads/Darkened Tail Lights/Ghost-Tinted LED Side Markers/Tinted 3rd Brake Light
FLYNNZL1 is offline   Reply With Quote
Old 08-09-2009, 12:30 AM   #2
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
I am fairly certain the pressure monitors are in the valve stems of the actual tires.
jpsuperman81 is offline   Reply With Quote
Old 08-09-2009, 12:58 AM   #3
FLYNNZL1
Wicked ZL1
FLYNNZL1's Avatar
I removed my back tires today to install my mud flaps and was just wondering, I didn't see anything???
I found this;
General Tire Pressure Information
Using data retrieved from your Tire Pressure Monitoring System, we'll let you know in your OnStar Vehicle Diagnostics* report if your tire pressure needs attention. You should check your tires monthly, at a time when you haven't driven for at least three hours.
* What is the Tire Pressure Monitoring System and how does it work?
Tire Pressure Monitoring System — If your vehicle is equipped with a Tire Pressure Monitor System (TPMS), it uses radio and sensor technology to check tire pressure levels in each of your installed tires. TPMS sensors monitor the air pressure in your vehicle's tires and transmit tire pressure readings to a receiver located in the vehicle. The TPMS is designed to alert the driver if a low tire pressure condition exists, and may also allow the driver to check tire pressure levels using the Driver Information Center (DIC) on your dashboard. If you have replaced your factory-installed tires or wheels, your TPM system may not be functioning properly. Check with your installer for compatibility.
Tire Pressure and Changing Temperatures — Tire pressure can change over time as temperature changes. The pressure goes up as temperature goes up, and pressure goes down as temperature goes down. (A good rule of thumb is that tire pressure changes 1 psi for a change of 10°F.) This can happen seasonally (from summer into fall), daily (from a cold night to a warmer afternoon), and while driving (the tires warm up as you drive).
You may notice during cooler weather conditions that the Low Tire Pressure indicator will appear when the vehicle is first started and then turn off as you start to drive. This is an early indicator that the pressure is getting low and tires need to be inflated to the proper pressure.
Old 08-09-2009, 03:50 AM   #4
soverydeb
Drives: 2010 2LT Camaro Blk/Blk
if you go and mess around with your vehicle information display, it will show you what each tire pressure is!
soverydeb is offline   Reply With Quote
Old 08-09-2009, 03:54 AM   #5
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
OnStar just uses the Tire Pressure Monitoring system information
Old 08-09-2009, 10:38 AM   #6
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
There are TPMS sensors inside the tire, they are connected with the valve stems
Old 08-09-2009, 12:39 PM   #7
FLYNNZL1
Wicked ZL1
FLYNNZL1's Avatar
Thank you
Old 08-09-2009, 01:52 PM   #8
BryanB
Drives: 2010 2SS CGM
yea, you're not going to see anything unless you take the tire off the rim
BryanB is offline   Reply With Quote
Old 08-09-2009, 02:11 PM   #9
Rockytophummer
Rockytophummer's Avatar
Drives: 2006 Hummer H2 2010 2SS Camaro
Im not exactly sure how it works but the parts department at my dealership told me to never use fix a flat on these tires because the have a little cube shaped censor on valve stem that can tell your tire pressure and sends it to onstar. They say the fix a flat blocks up the sensor and it costs $100 to replace it. Dont know if this is for sure but thats what they told me and figured if its true then it might help with your question.
Rockytophummer is offline   Reply With Quote
Onstar....a spy???? please comment dieseldave24v General Automotive + Other Cars Discussion 138 02-23-2012 01:12 PM
Tire Pressure Monitoring Dentyneice Wheels and Tires Talk Sponsored by The Tire Rack 8 08-14-2009 06:42 AM
Resetting TPMS Tire Pressure System jvmax Wheels and Tires Talk Sponsored by The Tire Rack 4 07-10-2009 12:37 AM
Tire Pressure toehead93 Dragstrip and Launch Techniques Discussion 4 06-09-2009 12:24 PM
Tire Pressure Monitoring System-Inside or external monitors? Fogey 5th Gen Camaro SS LS LT General Discussions 11 05-19-2009 10:50 AM
