Gen5DIY
Old 06-21-2014, 04:14 PM   #1
injector
injector's Avatar
Drives: LS3
Blown LS3 looking at lSX376 b15
Hi All,
As the title says, I've blown my engine and i've been reading a lot on lSX376 b15.
i've lived in the 840+ rwhp lvl for the past 2 years and to be honest i've not done any activity (track racing, drag racing) to utilize those 840 rwhp. I'm into street racing (which i know is wrong) but nothing crazy couple of times only. i'm a big fan of cruising and listening to my camshaft looping (Might sound crazy, but this is what i crave). Sometime i like to eat couple of GTRs
Now i've been looking at the LSX376, since i will be procharging it with a D1, but i've couple of questions for those experts in this forum. by the way nothing can be salvaged from my LS3. Real damaged happened.
1) is it a direct swap to LS3 or will i need to buy (manifold, harness, coils, LT headers).
2) is it a durable engine at 700-800 rwhp all year long.
To be honest the price caught my attention (as other options are 13000+) as well as a post by Adm team achieving what i believe a durable 800+ on this engine. I understand that to play we got to pay, but I'm looking for a great "bang for your buck".
Durability is the key to me not beating an underground 1000+ TT lamborghini.
Appreciate your input.
Texas Speed & Performance Custom Built Forged 408 CID, PRC LS3 260CC,Fast Intake & NW 102 TB, Alky Methanol kit, ID850, LPE Dual pumps,,Melling HV oil Pump. D1SC 10PSI, Stage 2 Air Intake,Magnaflow Axle back, Mcleod clutch, Pedders XA coilovers and sway bars, HD bushings, Hurst shifter, ACS bumper and hood ports, DSS aluminum drive shaft, CSF radiator .
injector is offline   Reply With Quote
Old 06-21-2014, 04:26 PM   #2
Unreal
Drives: 2006 Z06
It would work but I would also check out other options like a forged 402/408 ls2/3. Shouldn't be $13k.
Nick
Corvette Z06 -1200ish rwhp
Old 06-21-2014, 05:02 PM   #3
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I didn't pay 13k for my 417 stroker from ADM by a long shot. It should be a good motor but I would look into a bigger cube stroker if I was you.
MODS:
Old 06-22-2014, 12:05 AM   #4
SuperchargedStealth
Drives: '11 Camaro Supercharged Convertible
I just did a LSX 427. However, I did that to make 1000whp. I can praise how great the LSX motor is, but if you're looking to just stay at ~850, then you should look into a forged motor. There really is no point in spending more on a motor if there isn't a need for it. Look into Texas-speed. They offer a lot of different blocks with multiple ways of configuring it.
SuperchargedStealth is offline   Reply With Quote
Old 06-22-2014, 01:44 AM   #5
injector
injector's Avatar
Drives: LS3
To be honest I did not say 13000+ until I've received two quotation from vendors. Looking at TSP and as mentioned nothing over 13000. I will check them out more.
Old 06-22-2014, 12:21 PM   #6
2012InfernoSS
2012InfernoSS's Avatar
Drives: 93GMC sierra stepside/2012 SS
http://www.thompsonmotorsports.net/i...cPath=21_51_52
Im having a lsx 416ci built by Thompson motorsports it was around 13k but they have other options that are chraper.. look at the lq9 block or if you wanna stay aluminum block you can get a stoked ls3..
like said above if your going to get a new engine id go with more ci to get more torque
2012InfernoSS is offline   Reply With Quote
Old 06-22-2014, 01:02 PM   #7
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Sorry to here that, was your LS3 motor forged?
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 06-22-2014, 01:16 PM   #8
jrhagen
Banned
Drives: Camaro
The B-8 will handle what you are trying to accomplish at a far cheaper price.
jrhagen is offline   Reply With Quote
Old 06-22-2014, 01:36 PM   #9
injector
injector's Avatar
Drives: LS3
All forged except crank.
Old 06-22-2014, 02:19 PM   #10
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Do you know what caused the engine to blow? Was it a mechanical failure, or tuning? A forged internals LS3 should handle 850whp without much of a problem. Detonation will kill $13+k built motor just as easy as a $6k one.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-22-2014, 03:14 PM   #11
Unreal
Drives: 2006 Z06
$13k installed maybe. A solid long block stroked/ls3 with nice heads should be in the $10k range. Of course options go up and down. When I priced one at TSP it was $9200 with aftermarket PRC heads. Better pistons, rods, more cubes, better heads, better cam than the b15. Check out Livernois, they make excellent motors. LME is also one of the top LS engine builders and is priced well.
Nick
Old 06-22-2014, 04:11 PM   #12
injector
injector's Avatar
Drives: LS3
Axis the reason was one of the fans stopped working, and i did not notice the gauge until the warning sign was on. Then it was too late for me.
i'm in the middle east. Temp was 54 C that day.
Old 06-22-2014, 04:13 PM   #13
injector
injector's Avatar
Drives: LS3
Thanks i was thinking the same. Adm, LME, Livernois, HKE or TSP. Will not do it else where.
Old 06-24-2014, 06:03 PM   #14
thebeast916
Drives: Blown G8 GT
Texas speed hooked me up on my forge ls3.
So many options and blocks to choose from for any budget. Can't go wrong with anyone you listed.
thebeast916 is offline   Reply With Quote
