JUICEDMOTORSPORTS
Old 06-22-2014, 02:01 PM   #1
camarossdusk
whippled 5th gen
Drives: 2013 camaro ss
fuel for supercharged 2.9 whipple am i ok
keep seeing where some supercharged cars, with adm FPCM, and ZL1 fuelp pump running out of fuel, in examples of magnuson 2.3 applications, wondering if should add the boost a pump if run into this issue, have 63lb. injectors and running 9-10 lbs of boost with 2.9 whipple that came with my kit, should i be ok with zl1 fuel pump and adm fpcm.
camarossdusk is offline   Reply With Quote
Old 06-22-2014, 06:10 PM   #2
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I think you should be fine but I went twin pumps for extra insurance.
MODS:
Old 06-22-2014, 06:39 PM   #3
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
I ran the whipple kit for 2 years at 12LB of boost with stock pump and BAP running 10.40 am not saying to do that. I had a good tuner to keep me safe. Am now running twins
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 06-22-2014, 06:46 PM   #4
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
I have the stock pump, Whipple and MSD BAP that came with the kit. I'm at 580rwhp and it's topped out. But I'm only at 100% at redline
franknbeans is offline   Reply With Quote
Old 06-22-2014, 08:01 PM   #5
camarossdusk
whippled 5th gen
ok thanks just tuned it and is running great at 567/553 on a mustang dyno, planning to go meth injection next, then maybe a twin pump once get to higher boost and bigger injectors. hoping to go to 13 lbs of boost next.
Old 06-23-2014, 07:52 PM   #6
Slowhawk
Drives: 1999 Trans Am
We usually run the ZL1 pump and 85lb injectors. Many cars 600-650rwhp on our mustang dyno with no fuel issue's. I've never tried an ADM setup.
Slowhawk is offline   Reply With Quote
