Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Interior Parts & Accessories
Interior Parts & Accessories All interior parts and accessories.
Old 08-09-2009, 10:22 AM   #1
AACstyle
C5 Lighting Specialists
AACstyle's Avatar
Drives: www.CamaroLighting.com
Arrow ORACLE LED Strip Lighting: LED Ambient Footwell Lighting Kit ($35/Pair)
*NOTE: The Footwell Lighting is no longer CCFL, it is improved to SMD/LED Strips!
ORACLE LED Footwell Lighting (Pair) Only $35!
http://www.automotivelightstore.com/...ROD&ProdID=338
These are great for footwell lighting, grill lighting, trunk lighting, speaker boxes, etc.
Installation FAQ:
You simply connect the Red wire to any 12V power source and the Black wire to a ground. Then connect the white output wires to the CCFL tube via the included connector.
These strips can be mounted anywhere on the car including the grill, trunk, under the dash, under the seats, etc. We will concentrate on the footwells here.
First you will need to determine what power source you want to activate the tubes. In this case we will use a switch to turn them on/off. We will get the power for the switch from the fuse block in the driver side dash.
1) First locate the fuse panel cover
2) Then remove the fuse box cover
3) In this case we are going to tap our power off of the fuse box to power our switch:
Here is a quick diagram to illustrate the wiring:
EDIT:
Here is a quick tip to get power on the camaro:
Here is a quick tip for you guys doing the footwell lighting installation. We originally suggested to use an add-a-circuit but turns out that GM left an open circuit in the fuse panel for us to use
Using red female terminals you can make a quick jumper for a in-line fuse.
Attach a female terminal on the other end to tap the open circuit on the fuse panel.
Now you have 12V power ready to go
4) Switch Location
You can mount the switch wherever you wish, we chose to put it on the driver right side kick panel near the console.
This way it is out of sight but easily accessible to the driver.
5) Mounting the CCFL Tubes.
In this case we used the adhesive pads to contact under the dash and a small tie strap to add support in the middle so that the tube does not sag. You do NOT want to tighten this strap, simply use it for support. If you tighten it you run the risk of damaging or cracking the tube.
6) Your finished installation will look something like this:
AACstyle is offline   Reply With Quote
Old 08-09-2009, 10:38 AM   #2
AACstyle
AACstyle's Avatar
Works Inside OR Outside the vehicle!
Examples used as grill lighting:
Old 11-07-2009, 06:35 PM   #3
AACstyle
AACstyle's Avatar
Old 11-10-2009, 11:45 AM   #4
irvinecamaro
Drives: Used to be 2010 2SS
Can these be wired to turn on with the interior lights (only on when the door is open)? How hard is that to do?
irvinecamaro is offline   Reply With Quote
Old 11-10-2009, 11:47 AM   #5
AntivenomSS
I hate snakes!
AntivenomSS's Avatar
Drives: 2010 Camaro 1SS/RS
+1
AntivenomSS is offline   Reply With Quote
Old 11-11-2009, 07:50 PM   #6
AACstyle
AACstyle's Avatar
Yes, you can power them off of the dome light lead so that they come on with the interior lights.
I can make a DIY if this is something you guys are interested in.
Old 11-11-2009, 08:09 PM   #7
DocHolliday
DocHolliday's Avatar
Drives: SIM 2SS/RS '11 Jag XF Supercharged
A DIY for this would be very cool...thanks!
~Say When
Airaid CAI, JBA Shorties, JBA Axle Back, MGW Shifter
DocHolliday is offline   Reply With Quote
Old 11-11-2009, 09:41 PM   #8
beegroovie
Drives: 2010 Black 1SS/RS
I would be interested in this too.
beegroovie is offline   Reply With Quote
Old 11-12-2009, 07:41 AM   #9
tlnewell0426
Drives: 1SS ABM
Yes a DIY with pics would be awesome...these look great!
tlnewell0426 is offline   Reply With Quote
Old 11-12-2009, 07:57 AM   #10
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
YEP show us how man!! GM is supposed to offer something like this for the footwells so the hookups should be down there somewhere.
Scott@Bjorn3D is online now   Reply With Quote
Old 11-12-2009, 11:01 AM   #11
cybercoaster
cybercoaster's Avatar
Drives: '12 ZL1 AGM
I want to order these but have them work off the dome light switch. Do you provide a wiring diagram for where to hook them up?
Plasma DRL, footwell LED, Technostalgia taillights
cybercoaster is offline   Reply With Quote
Old 11-12-2009, 11:53 AM   #12
bluecamaroguy
bluecamaroguy's Avatar
Drives: 2010 2LT/RS ABM!
Yes!
bluecamaroguy is offline   Reply With Quote
Old 11-12-2009, 12:08 PM   #13
garcmol
garcmol's Avatar
Yes please on the DIY!!
Old 11-12-2009, 12:16 PM   #14
Mr Smith
Born again Hot Rodder
Mr Smith's Avatar
Drives: Black 1SS/RS LS3 M6
Yeah baby! I want the footwell lighting....
Black 1SS RS MT: Powder Coated Bow Ties, Blacked out windows, Debadged, 4 Pack gauge cluster. Pure perfection.
Mr Smith is offline   Reply With Quote
Old 11-13-2009, 11:25 AM   #15
lellowSS
lellowSS's Avatar
Drives: 2010 Rally Yellow 2SS M6
I'm going to order the LED conversion kit today and am considering the footwell lighting. How difficult of an install is it. DIY would be real helpful.
Deliv. 8/20/09 SOLO Mach X Catback, SOLO HF cats, CAI Cold Air
lellowSS is offline   Reply With Quote
Old 11-13-2009, 01:11 PM   #16
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
word how do they install
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 11-13-2009, 02:13 PM   #17
AACstyle
AACstyle's Avatar
Hello, We are installing on a Camaro tomorrow and I will take pics for you guys as we go
Old 11-14-2009, 11:51 PM   #18
cerberus
cerberus's Avatar
Drives: 2010 CGM
When you guys talk about the interior lights are you also referring to having them dimable too? I would think you would want to be able to dim them.
2 SS CGM RS, IOM interior, Customized by Clean Cut Creations St. Louis, MO
cerberus is offline   Reply With Quote
Old 11-15-2009, 01:10 PM   #19
miltp
Jim Pappas
miltp's Avatar
Drives: Rally Yellow 2SS/RS,Auto,G/X
Yes i am also very interested in ordering the footwell lights.But i need to know what kind of installation is needed.If you can show us ahead of time tp prepare.Will they come on when the door is opened,are they going to be dimmable. Thanks for any info you can send us would be muchly appreciated.
miltp is offline   Reply With Quote
Old 11-15-2009, 01:27 PM   #20
bluecamaroguy
If they are like the dome LED lights then they are not dimmable.
Old 11-16-2009, 11:45 AM   #21
mrbrans5
mrbrans5's Avatar
Drives: IOM Bahia Int. 2LT RS M6 SR BH
I'm looking forward to reading the DIY instructions before ordering the footwell lighting.
mrbrans5 is offline   Reply With Quote
Old 11-16-2009, 11:50 AM   #22
Orange5thGen
Orange5thGen's Avatar
Drives: 2011 Convert
Send a message via Yahoo to Orange5thGen
The footwell lighting is great! Justin can you post any pics of mine you did over the weekend? The lights are awesome too, they don't cause any night blindness as White light does. They were really nice on driving my car back home all night!
Orange5thGen is offline   Reply With Quote
Old 11-16-2009, 12:10 PM   #23
rforbes
rforbes's Avatar
Drives: IOM SS
I am going broke with these guys! but me like it!
rforbes is offline   Reply With Quote
Old 11-16-2009, 04:56 PM   #24
AACstyle
AACstyle's Avatar
We took some pictures over the weekend, just need to put together the DIY
Old 11-16-2009, 04:58 PM   #25
TonyNo
TonyNo's Avatar
Drives: 2010 Camaro 1LT, IBM
Pics, please! Post write-up when done!
TonyNo is offline   Reply With Quote
aac, ambient, ccfl, footwell, led, lighting
ambient lighting kozzmo49 Cosmetics and Lighting Modification Discussions 45 02-10-2010 05:13 PM
Ambient Blue/Orange Interior Lighting Around the Door, Rings, Gauges, and Dash(maybe) pglover19 5th Gen Camaro SS LS LT General Discussions 23 07-13-2009 09:05 PM
No ambient lighting in my 2SS/RS :( 2Muchmark 5th Gen Camaro SS LS LT General Discussions 23 06-11-2009 09:05 PM
Ambient Lighting QUESTION SuperSport2010 5th Gen Camaro SS LS LT General Discussions 18 06-11-2009 12:37 PM
Ambient Lighting! blakeequalshyphy 5th Gen Camaro SS LS LT General Discussions 116 12-29-2008 12:44 PM
