Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 08-09-2009, 02:50 PM   #1
BlackSunsine
BlackSunsine's Avatar
Drives: 1967 Custom Camaro
Question - LS6 and T56 Transmission
I currently have a 97LT1 and a T56 Transmission in my 67 Camaro, but I have an opportunity to get a new LS6 Crate motor.
Will the LS6 match up to the 97 T56 Transmission?
Thanks
Current Cars -
1967 Chevrolet Camaro (1983)
2004 Harley Davidson Road King(2004)
Ex 2001 Chevrolet Tahoe (2007) (Totaled Labor Day)
2004 Chevrolet Tahoe (Thursday)
2010 Chevrolet Camaro SS(2009)
Colorado Fall - Beautiful - Cool - Snow is soon!!!
BlackSunsine is offline   Reply With Quote
Old 02-26-2010, 02:56 AM   #2
LS1Proud
LS1Proud's Avatar
Drives: 2002 35th Anniversary LS1 Z28
Not sure if this will help, but 4th gen Camaros with the LS1 that have the 6 speed manual are T56 trannys. Most T56 trannys will bolt up to most SBCs with some minor modifications even LS1s from the 70s. Drivelines and their length come into play, but I would suspect it would bolt right up.
LS1Proud is offline   Reply With Quote
Old 03-03-2010, 12:59 AM   #3
Vega
Vega's Avatar
Drives: 91' Camaro RS
Send a message via Yahoo to Vega
Im with him, i think it should bolt right up, especially if its a new LS6 and if you already have an LT1 bolted up, all the LS engines are made to be easily interchangeable like that and as far as i know all of GM's modern muscle cars use those Tremecs so any LS engine should bolt right up easily, maybe not even any work involved but the bolting process haha, id go for it! Modern power and mileage in a classic body, thats the perfect car.
PS: Isnt Black Sunshine supposed to be a 400hp Mustang? xD
Vega is offline   Reply With Quote
Old 03-03-2010, 08:24 AM   #4
will69camaro
will69camaro's Avatar
Drives: 1969 and 2010 Camaros
No it wont. The LT1 style T56 is setup to bolt to any early model Chevy engine (SBC/BBC) HOWEVER this changed when they went to the LS1. Doesn't bolt up the same and takes a different clutch. LS1 T56 uses a concentric slave mounted to the faceplate of the transmission itself and uses a "push" style clutch (same as just about everything). The LT1 T56 uses a bellhousing mounted external slave and utilizes a "pull" style clutch.
You can buy the stuff to convert it to work or I'm sure there is an adapter to make it work but it wont be a straight swap.
Regards,
William
Planetlsx.com online magazine rep
will69camaro is offline   Reply With Quote
Old 03-04-2010, 09:42 AM   #5
ONyX711
ONyX711's Avatar
Drives: 1968 Camaro
Regards,
William
This is correct if i remeber, the ls1 and lt1 t56's have different lenght input shafts if i remeber correctly too.
1968 CAMARO
-383 SBC, 4SPD M20, 3.42's
-Weeeeeeeeeee!
ONyX711 is offline   Reply With Quote
Old 11-17-2010, 05:58 PM   #6
ScottRod
1991 Camaro W/ Tremec T56
Drives: 1991 Camaro W/ Tremec T56
Will69 and Onyx are right. The LS1 T56 has a little bit longer input shaft and the bell housing is different – needs adapting. There’s a pivot for a clutch fork setup on the LT1. From my memories of this there is also a spline count difference on the early style but I don't remember. There are several kits out there for this.
ScottRod is offline   Reply With Quote
Old 12-28-2010, 08:58 PM   #7
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
you can convert your lt1 setup to ls1 setup you need.
input shaft for an ls1
front trans cover to use the hydraulic release bearing
new master cylinder with the proper line for the ls1 style throw out bearing
bellhousing for ls1
flywheel
clutch
pilot bearing
I think that is about it
xx_ED_xx is offline   Reply With Quote
Old 01-21-2011, 10:09 PM   #8
lcoughran
lcoughran's Avatar
Drives: 1970 Big Block Camaro
Send a message via AIM to lcoughran Send a message via Yahoo to lcoughran
I am running the Tremec T-56 six speed in my 1970 behind an LS6, best choice I ever made for that car. However, I ordered mine just for my setup, so I can't help with the swap part, but it makes my 3:83 running gear streetable/highway(able).
lcoughran is offline   Reply With Quote
