JUICEDMOTORSPORTS
Old 08-10-2009, 03:00 AM   #1
salohi
salohi's Avatar
Drives: 90 Black Camaro, 02 Sable
Exclamation The difference between ???
hello,
guy's, what is the difference between Axleback Exhausts & Catback Exhausts ??
Thanks
2SS/RS
Black/Black
6Spd. Aut.
salohi is offline   Reply With Quote
Old 08-10-2009, 05:40 AM   #2
SleepWarz
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS
One sits behind the axles and one sits behind the cats?
=o Logically that's what it should be....
I dunno though.
SleepWarz is offline   Reply With Quote
Old 08-10-2009, 06:17 AM   #3
salohi
salohi's Avatar
I dunno though.
:bangdesk:
2SS/RS
Black/Black
6Spd. Aut.
Old 08-10-2009, 06:29 AM   #4
Verio
Taking it 1 day at a time
Verio's Avatar
Drives: 2010 Chevy Camaro 2SS/RS Auto
Send a message via MSN to Verio
Originally Posted by salohi View Post
hello,
Thanks
For the LS3, you do not gain much with a cat-back...since the standard system is basically wide-open. The only reason you would swap out the LS3's cat-back or axle-back system is for preference of noice level and type.
For the L99's, swapping out the cat-back removes quite a few extra resonators, and additional equipment. This would greatly improve the flow through the system with a cat-back. However, since the resonators are removed, be ready for some drone.
If you just want it to sound good, for a cheap price, go for the axle-back mod.
Order#: NJWGTF
1100, Preliminary order accepted 04/27/2009
6000, Delivered to the customer 07/23/2009 - 3 Months (worth the wait!!)
Verio is offline   Reply With Quote
Old 08-10-2009, 06:59 AM   #5
khislop007
ZEUSS
khislop007's Avatar
Drives: Hard!
j/k
here's a visual example
Cat back
Axle back
Old 08-10-2009, 07:09 AM   #6
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
Drives: Sky Redline & Camaro 2SS/RS
Also put, A "Cat" Back means replacing the factory exhaust system from the "Cat"alytic converters back to the exhaust tips.
An "Axle" back system, means replacing the factory exhaust components from the "axle" back. Usually the axle back systems replace mainly jut the mufflers and tips.
ITS HERE! : 2010 Camaro 2SS / 6 Speed Manual (No other way) / Silver Ice Metallic / Inferno Orange Interior Accent / RS Package / Polished Wheels / SOLO MACH X CAT BACK
Xmicro_SS is offline   Reply With Quote
Old 08-10-2009, 07:39 AM   #7
salohi
salohi's Avatar
mine is automatic so it's L99. I understand that both will increase the power right ?
2SS/RS
Black/Black
6Spd. Aut.
Old 08-10-2009, 07:48 AM   #8
Verio
Verio's Avatar
The only thing you're going to gain from an axle-back is increased sound, and a slight reduction in weight. I believe 10lbs = 1 HP? So, with 18 points in each Muffler, you're looking at almost 4HP increase...
I'm no expert, so feel free to correct me if I'm wrong.
The area that is constricting on the L99 is the resonator boxes in the middle of the exhaust underneath. This portion is where you could (potentially) see some increased HP if it was swapped out for a straight-through pipe (i.e., Cat-Back).
Order#: NJWGTF
Old 08-10-2009, 08:29 AM   #9
Outlaw
Outlaw's Avatar
Drives: 2SS M6, IBM w/ Silver Rally
Yeah, what they said. Axle back is mostly for sound and way less expensive. But doesn't a cat back still only boost by 8-10 HP at most even on the L99?
IT HAS ARRIVED 8/05/09!!!!:
Outlaw is offline   Reply With Quote
Old 08-10-2009, 09:27 AM   #10
gmag21
gmag21
gmag21's Avatar
Drives: 2010 Camaro 1SS/RS
Send a message via AIM to gmag21 Send a message via Skype™ to gmag21
You can delete the cats and it will be roar fast loud
L99 | Billyboat Exhaust, American Racing Headers, Pfadt Springs and Sways, Tune | 350 whp / 371 tq
gmag21 is offline   Reply With Quote
Whats the difference between Camaro SS vs. SS w/RS package? JBsC6 Camaro Price | Ordering | Tracking | Dealers Discussions 41 07-14-2015 06:07 PM
Difference in performance between X-pipes ???? Jekyll-N-Hyde Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 07-28-2009 03:31 PM
SLP exhaust, Loudmouth and Powerflo, what's the difference?? JDBeck23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 07-03-2009 11:33 AM
Difference in LS and 1LT and 2LT ? VeNoM Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 10 03-13-2009 09:37 AM
Exhaust Note difference between L99 and LS3? Supermans Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 11-09-2008 07:51 PM
