HURST
Old 04-11-2008, 09:40 AM   #1
96CAMaro
96CAMaro's Avatar
Drives: '02 Impreza 2.5RS
Performance question - gains from pulleys?
Just a thought: if the Camaro does come with a supercharger - is it only a pulley swap and tune away from incredable power gains like the '03-'04 Cobras?
96CAMaro is offline   Reply With Quote
Old 04-11-2008, 09:53 AM   #2
Camaro_Corvette
36.833283,-76.021958
Camaro_Corvette's Avatar
Drives: Team 1LE
unsure...
Old 04-11-2008, 11:33 AM   #3
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Quick answer is yes. However the more boost you make the more you have to do to protect the engine. So with a modest pulley increase and a tune you can get real positive gains When you start getting over 10 pounds of total boost, you should probably be looking to help the rest of the engine keep up.
Old 04-11-2008, 03:47 PM   #4
The_Blur
Rock Chalk
The_Blur's Avatar
Drives: Demon Super Sport
What are the breaking points of the potential Camaro motors? When I was on the Cobalt forums, I remember that the piston rings could only handle 250 hp on the 2.2L. What kind of abuse can LS3 internals take?
Old 04-11-2008, 04:07 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'm not sure it's going to be accurate to compare LS3 components to assumed FI engines for Camaro.
The LS3 is NA and has hypereutectic pistons to my recollection, a kind of forged rod, and a nodular iron crankshaft. I am very sure if GM does go with FI for an opotional engine, it will share it's crankshaft with the forged steel cranks that are in the LSA and LS9. I doubt it would get the Ti rods from the LS9 since the LSA doesn't get them, and I doubt there are going to be forged pistons since the LSA doesn't get them either.
With the way GM tests things, I'm sure it would be safe to say and LSA will crank out and hold up very easily to 600 horse as long as it's been tuned well. I remember hearing about Cobra engines easily cranking out 450 RWHP with just intake, pulley, tune, and exhaust, so I can't imagine Camaro making too much less with half those additions. With the way GM has been underrating as of the last couple years, I'm sure the CTS-V will put down to close to 500 RWHP and if not, I know it will be super easy to get there with a pulley.
Another thing to consider is the LS9 is running 10+ pounds of boost; LSA isn't pushing quite that much. I'm sure since it's bottom-end is built stronger than the LS3 that it will easily handle the abuse of similar boost numbers to the LS9, afterall, that LS9 is engineered to live on the track.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 04-11-2008, 04:21 PM   #6
GTAHVIT
Blessed
GTAHVIT's Avatar
I have no idea, Obviously Rad has made a pretty good comparison for us.
I don't know if GM will release this information or we'll learn through trial and error from people pushing the limits. Probably the latter
LSA in my Camaro, LSA in my Camaro, LSA in my Camaro.... If I keep saying it they will hear me right?.... Seems to work for my daughter.
Old 04-11-2008, 05:27 PM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
AMEN!!!
Old 04-11-2008, 08:22 PM   #8
SSNIGHTMARE
SSNIGHTMARE's Avatar
Drives: 2002 SS Camaro
LSA in my Camaro, LSA in my Camaro, LSA in my Camaro.... If I keep saying it they will hear me right?.... Seems to work for my daughter. [/QUOTE]
X2
SSNIGHTMARE is offline   Reply With Quote
Cadillac CTS-V!!!! (oh, and the 6.2L LSA...) Mr. Wyndham General Automotive + Other Cars Discussion 11 03-11-2008 01:18 PM
Noob Camaro Question goose7919 5th Gen Camaro SS LS LT General Discussions 13 09-23-2007 09:26 PM
Toyota fears U.S. backlash over gains KILLER74Z28 General Automotive + Other Cars Discussion 6 02-14-2007 09:49 PM
