Old 07-04-2014, 12:33 PM   #15
sycraft
COTW 5/06/2013
sycraft's Avatar
LFX guys use a 061075 or a 061073 belt, remove the 2 idler bolts, loosen and remove 3 small bolts over pulley with spacers, loosen the lower 2 mounting bolts and then you can route the belt off the SC pulley and replace, reverse is opposite of removal, I torque pulley bolts last, don't know if it matters though.
Old 07-04-2014, 12:34 PM   #16
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
For you nerds out there, the SCi compressor map:
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 07-04-2014, 01:07 PM   #17
MagnumForceGB
Which belt is it for the standard pulley on the LFX?
Old 07-04-2014, 01:32 PM   #18
sycraft
COTW 5/06/2013
sycraft's Avatar
it comes with the 061075 = 06 is 6 rib, 107.5 inches...
Old 07-04-2014, 03:22 PM   #19
MagnumForceGB
Updated the main post, probably a K061066 would be for a smaller pulley when one of you LFX guys go balls out for more boost.
Old 07-04-2014, 03:50 PM   #20
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Originally Posted by MagnumForceGB View Post
Mine faces away from the intercooler, horizontal, when I searched for how others do it they do it with the valve being pushed on by the boost pressure. It is also how Snow Performance recommends with their Safe Injection Bypass Solenoid, it will prevent pressure from building up if no meth is flowing.
It also looks better since how the internals look on the valve, the side opposite of the vacuum port looks like it seals a lot better than the other side.
I gotta look at those internals- I'm wondering if the idea in having the valve down is to maintain some pressure in the intake tract for quicker/better return to on-throttle response.
If this is true, maybe the vertical position would reduce the chance of the dreaded off-throttle stalling (assuming a little air is slipping thru). My valve is in the downward position and I've never stalled. I know Sycraft's had infrequent stalling, but not enuff to be an issue.
Obviously if you're running meth you gotta follow their instructions. But for those that aren't, maybe one works better than the other.
Just spitballing here...
Old 07-04-2014, 03:54 PM   #21
sycraft
COTW 5/06/2013
sycraft's Avatar
with the valve in line, I think the boost could force open the valve, so a sideways orientation could hold boost better, again spitting in the wind...
Old 07-04-2014, 04:05 PM   #22
MagnumForceGB
The thing is though the boost from the vacuum line will be pushing back on it, and the spring will help hold it close also. It takes a lot of force to push that piston open. Come Saturday or Sunday I will put my boost leak tester on the car and pressurize it to 15 PSI, that should see if it will pop open or not.
Old 07-04-2014, 04:07 PM   #23
MagnumForceGB
I could actually try it both ways, see if one of them leaks. They probably won't though, I've had it both ways with my smaller pulley and I see the same pressure.
Old 07-04-2014, 06:24 PM   #24
ASH@IPF-TUNING
ASH@IPF-TUNING's Avatar
Drives: 4x4 Turbo
Hi everybody !
great post !!
i love that interest that our development is creating in the market ... its like yesterday in my memory as we mashined parts for the first SC kits in the night before traveling to Vegas to the 2011 Sema show ! :-)
Greets ASH@IPF-TUNING (Arno Schindler)
ASH@IPF-TUNING is offline   Reply With Quote
Old 07-05-2014, 02:15 PM   #25
MagnumForceGB
Originally Posted by ASH@IPF-TUNING View Post
Hi everybody !
great post !!
Thanks, if there is anything that you want me to add to the FAQ just let me know.
Old 07-07-2014, 08:38 PM   #26
Jason@JacFab
Jason@JacFab's Avatar
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Nice write up.
Jason@JacFab is offline   Reply With Quote
Old 07-07-2014, 10:40 PM   #27
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Great write up.
This is just what I needed.
I'm saving up for this kit now. I'm getting my 1LE track pack suspension installed later this month. Once that's done the IPF kit is next.
I do have some question though. Does anyone have any track experiences with this kit?
Any major differences in daily driving with this kit?
Mods:
Roto-Fab Intake, WW Reservoir kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness.
Old 07-07-2014, 10:47 PM   #28
sycraft
COTW 5/06/2013
sycraft's Avatar
Track, yes I have done both, I like road course most
