| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() Drives: C6 Zed-oh-six Join Date: May 2009
*Official* L99 Dyno Thread
Can someone make this a sticky?
Seems like with all the L99 talk theres alot of variation on what they put down, I have seen from 295-330rwhp So post up your results and some basic info on your car (mileage, break in procedure ect ect ) my results are posted, stock vs tuned
Moderator.ca
Thread stickied
__________________ Quote: In 2014 the camaro will have ... a twin turbo v6 ... around 350 to 360HP No. Let me repeat that. No. FbodFather __________________ Camaro5 Fest III Information Camaro5 Fest III pre-registration |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS & 2008 C6 Join Date: Mar 2008
Stock , 600 miles, pulled 319rwhp back to back twice, then removed ECM fuses for 5 minutes to reset LTFT`s (Long Term Fuel Trims), immediatley ran it again and picked up close to 8 rwhp. This is that last pull.
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s! Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list.. |
#4 | |
everything thing I have read concludes the real restriction is way before the mufflers and that an axle back adds nothing but sound
Here is my stock vs. tune dyno. As you can see in the south Florida heat and humidity my car pulled about 332rwhp/345FT# stock.
With the tune it looks to be about 345rwhp/357FT#. Considering the weather I'm happy, I'd like to get it back on the dyno once it cools down. I have just over 5,200 miles on the car. I was at the drag strip with 300 miles...what break in?
2SS A6 Black
360 RWHP/382 FTLBS - tune only Mods on: Dynatech LTs, Vararam Intake, Pedders Xa's, DiabloSport tuned |
#6 |
![]() ![]() ![]() Drives: Twin Turbo Camaro Join Date: Feb 2009
Here's mine stock and with a tune (ECM). 500 miles driven semi-hard.
#7 |
Drives a Maro
#8 |
![]() Drives: Black 2SS/RS Join Date: May 2009
First one is stock, and the second is stock with only tune. about 85 degrees in north jersey. gained around 27 hp and 45 tq
Black 2SS/RS 6A
Vararam/Ported TB/ARH LTs/Loudmouth 2/Dyno tuned BMR sways/full bushings/trailing arms and toe rods/dropped an inch Interior/exterior accents that make the car bangin |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
94 - 99 degrees and very high humidity (also drove 130 miles to get there).
Stock and tuned (no mods).
#10 |
Tampa Gulf Coast Family
Drives: Grey Beast Join Date: Jul 2009
Another Slow L99
Car has 3000 miles first 1500 took it kind of easy. Changed the oil and since then I have been driving it like i stole it!
#11 | |
H-Town Camaro Club
Now your 130 miles and hot motor would lower the numbers a tad |
#12 | |
Drives a Maro
![]() Are my numbers actually lower or what? |
#13 |
![]() ![]() Drives: 2013 ZL1 # 2195 Join Date: Jun 2009
That one is UGLY!
#14 |
Yes it is sad but true.
I also posted my 0-60 times around 6.8 seconds. I just came from the dealer and they where unable to do anything but open a case. The tech told me there was only one other case like mine and it was closed and marked as normal. He also told me that there where no PIs I think is what he called them. Which means they are not activally working on the issue that he could tell. Long story short While some are saying sit and wait GM will make good. I think everyone that has an underperforming L99 needs to get in and have a case open to put a fire under GM to resolve the issue. |
#15 |
No, SAE corrected will increase the numbers unless you're below sea level and somewhere really cold and dry.
2SS A6 Black
#16 | |
Drives a Maro
I'm confused. I should be running faster. Delete if needed.
#17 |
![]() Drives: 1991 Camaro RS Join Date: Mar 2009
Probably. SAE-corrected does take into account temperature and humidity to theoretically provide a standardized number. Given you dyno'd in the south and in the summer, it's likely that if it were SAE-corrected it would be a higher number.
2010 Camaro SS in black/beige: Sold. | '91 Camaro RS: Still the dream car!
'98 Camaro SS: Incon twin turbo. Sold | '99 Camaro SS: Heads/cam/bolt-ons. Sold. |
#18 |
Emerald Coast Camaros
Drives: 2010 2SS/RS Camaro IOM/IO Join Date: Aug 2009
Two questions...does anyone know somewhere in NW FL I can go to dyno my car, and what tuners are you guys using? Someone mentioned a Diablo Sport, but what else? Thanks guys!!
#19 | |
www.fasterproms.net He also visits different tuning shops in other area of Florida.
#20 |
OBX
Drives: 2010 2SS / RS, Black on Black, L99 Join Date: Jun 2009
Advertised 400 HP
How does GM get away with advertising the HP at 400 for the L99 and 426 for the LS3 when no one has dyno'd that? Did I miss something in the fine print?
Glenn Rainey
Outer Banks, North Carolina |
#21 |
![]() Drives: 2010 2SS RS L99 Rally Yellow Join Date: Aug 2009
These Dyno's calculate RWHP (rear wheel Horse power) Chevy calculates Horse Power at the crank.
This car is amazing...
#22 |
Drives: Cargo van. Join Date: Jul 2009
Might as well post mine here.
First run is stock at about 700 miles. Second run is with rotofab cai and a tune done about two weeks later.
#23 |
Moderator.ca
Because despite what Top Gear tried to promote in their dyno test of a GT500, the number that is advertised is not the same as what you will be testing when you strap it down for a dyno run. GM and every single other automaker out there rates their engines with an engine dyno. This is a test rig that measures the output of the engine. A chassis dyno, which is what you most often see, measures the power at the wheels. This is the power at the crank minus any losses from the drivetrain.
#24 |
OBX
Thanks guys. I better understand the process now. Great explanations!
Glenn Rainey
#25 |
![]() Drives: '10 Camaro 2SS/RS CGM LS3 A6 Join Date: May 2009
Just dyno'd mine tonight, complete stock to the filter, 1050 miles, easy first 450, then having fun. Pulled fuses at about 600 miles.
About 85 degrees, first run 321hp, 336tq. Second run (about 1 minute idling rest) 313hp, 319tq
- 2010 Camaro 2SS/RS CGM LS3 A6 "Lurch" - FLYNGSS -
![]() Some ECS, Alky, CompCams, Kooks, JDP Motorsports, Pfadt, BMR, Prothane, RKSport, RX, ACS, Garys, Street Scene, Defenderworx, Anvil, etc.- 1995 Camaro Z28 Turbo'd 383 LT1 - FLYNZ28 - 2001 Silverado 2500HD CCSB 8.1L |
| Thread Tools | |
| L99 Love | Mod4SS | 5th Gen Camaro SS LS LT General Discussions | 79 | 12-19-2009 06:07 AM |
| Dyno Dynamics AWD Dyno @ Hennessey Performance | Hennessey Performance | USA - Texas | 0 | 08-08-2009 10:03 AM |
| LS3 Tune Only Results .. Also stock LS3 vs. L99 dyno graph | LPFSTheFett | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 08-05-2009 07:04 AM |
| Tuning LS3 vs L99 | Evilangel | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 10-30-2008 10:22 AM |
| L99 engine specifications | Tran | Wiki | 0 | 10-19-2008 11:40 AM |
