Jason 98 TA
Old 08-10-2009, 07:57 PM   #1
LSP2010
IM A GURL
LSP2010's Avatar
Drives: 2010/2SS
Has anyone use this product to fix scratches
Does this stuff works 4real?? Have anyone use it?? I think it will last for a week or so an the scratch appear again. What's your intake??
https://www.fixitsale.com/?MID=557093
1100, Preliminary order accepted - 13oct08
2000, Order accepted by GM ----- n/a
3000, Order acc. by P.R---------- n/a
3100, Order available to sequence- n/a
3300, Order sch. for production--- 21may09
3400, Order broadcast------------ 28may09
3800, Order produced ------------ 2jun09(2G1FT1EW8A9114199)
4000, Available to ship
4200, Shipped--------------------9june09
ITS HERE 18JUNE09
LSP2010 is offline   Reply With Quote
Old 08-10-2009, 08:12 PM   #2
jdanza
jdanza's Avatar
Drives: 2010 2SS/RS VR-BLACK
This stuff works real well
http://www.drcolorchip.com/
2010 2SS/RS VICTORY RED / BLACK LEATHER - 6 SPEED M TRANS
6000 = Delivered To Customer-8/22/2009
jdanza is offline   Reply With Quote
Old 08-10-2009, 08:19 PM   #3
LSP2010
IM A GURL
LSP2010's Avatar
Drives: 2010/2SS
Originally Posted by jdanza View Post
Now i can believe that
ITS HERE 18JUNE09
Old 08-10-2009, 08:40 PM   #4
Thrillz
Thrillz's Avatar
Drives: 2012 Charger R/T / 2012 Dodge Ram
When u people gona learn. Remember color magic in the 80's? Want to fix a scratch correctly gota use a PC with correct chemicals. All this stuff u see on TV is just snake oil all crap.
Thrillz is offline   Reply With Quote
Old 08-10-2009, 08:54 PM   #5
dursin
Drives: Suburban
How bad a scratch are you looking to fix? I've used Meguiar's Swirl-X with excellent results for removing (not simply hiding) very very light scratches and swirl marks. They also have a product called Scratch-X for removing light scratches. Also heard that Quixx is good.
I'd avoid that shit that Billy Mays is pitching.
dursin is offline   Reply With Quote
Old 08-10-2009, 10:39 PM   #6
BabyBee2010
BabyBee2010's Avatar
Drives: 2011 Rally Yellow 2LT/RS
Does Dr Color Chip work?? Anyone use it??
2LT/Rally Yellow/Black Leather/Sunroof/Automatic VIN 4711 Bought 5-9-09--Totalled 6-21-11
2LT RS/Rally Yellow/Black Leather/Sunroof/Automatic
Bought 7-29-11
BabyBee2010 is offline   Reply With Quote
Old 08-10-2009, 11:37 PM   #7
RAdams
Car Guy
RAdams's Avatar
Drives: '08 Mustang GT, '01 Isuzu VehiCROSS
I love HDTV.
It seems to de-emphasize the scratch on the commercial, but it also puts on a wide swath of "clear coat" that looks just as distracting which makes the paint around the scratch look "wrong." The end result will actually look worse - especially when the surface isn't in "the perfect TV lighting" like in the commercial. You will wind up with an obvious "filled in scratch" and an obvious "cheap fix" of clear globbed on around it.
RAdams is offline   Reply With Quote
Old 08-11-2009, 11:37 AM   #8
Steve P
Drives: None
Winner, winner, chicken dinner.
Hand buffing attempts may only provide short term relief or remove the mildest scratches and dull haze on the surface. Using the Porter Cable buffer with the appropriate pads and chemicals will do everything from applying a wax or sealant to removing the mild-moderate scratches. The machine is very safe, user friendly and will not burn the paint or clear coat. The key is to use the least aggressive combination to get the desired effect.
Steve P is offline   Reply With Quote
Old 08-11-2009, 12:33 PM   #9
Rikarus
I can't tpye!
Rikarus's Avatar
Drives: 2010 RS/SS Victory Red
ordered Drcolorchip yesterday, gonna try on my door ding, will post pics.
Rikarus is offline   Reply With Quote
Old 08-11-2009, 05:52 PM   #10
LSP2010
IM A GURL
LSP2010's Avatar
Drives: 2010/2SS
i dont have any scratches jus wonderin
ITS HERE 18JUNE09
Old 08-12-2009, 08:38 AM   #11
fmdog44
Drives: 1965 impala
Define "sratch". If you can feel the scratch with your fingernail then it's time for the body shop. If it is visible only then start with the least aggressive polish so you don't over-fix the scratch. If that does not work then progress on to a little stronger agent until it is gone.
fmdog44 is offline   Reply With Quote
2010 Camaro PRODUCT SAFETY RECALL: Positive Battery Cable Rerouting mcernik Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 171 01-08-2011 03:09 AM
Will the V6 have DBW or a good old fashioned cable throttle? theholycow Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 41 08-02-2009 09:25 PM
MT: "The Product GM Needs If it Survives Bankruptcy" Scotsman General Automotive + Other Cars Discussion 3 06-02-2009 03:03 AM
What do you use to fix scratches? MRK III Z28 General Automotive + Other Cars Discussion 7 01-03-2009 03:12 AM
