Cold Air Inductions
Old 08-13-2009, 03:10 PM   #29
calflan
calflan's Avatar
Drives: 1LT; IBM; 6 Spd Manual
Royal Purple is on neither list.
What's the deal ?
.. and seeing how the manual says only use of 6094 (V6) is recommended, I'm sure warranty might be jeopardized by an oil not held to that standard. Does RP have any identifcation on a label talking about these qualifications ?
1LT; Airaid CAI; Flowmaster American Thunder Axelback; Int Floor Lts; RS Spoiler; Radio Controls; Sequential tail lights; Oil Catch Can; VMAX Throttle Body; MACE plenum spacer; Mace manifold insulator[/I]
calflan is offline   Reply With Quote
Old 08-13-2009, 04:40 PM   #30
Chrisrp454
Chrisrp454's Avatar
Drives: 2010 ABM 2SS/RS M6, 98Z28 M6
Well my DD 98Z28 at 244,000+ has had nothing but castrol syntec since I bought it new.
And I have never had any motor issues and still running strong, to me that
says a lot.
Always Remember! Rest in Peace Brothers
9/11/2001. And thanks to all those who defend and serve!
Ordered 5/23/2009
3400 with TPW of 08/03/09
3800 8/11/2009
Arrived 8/21/2009 2SS/RS/Aqua Blue/Grey Interior
Chrisrp454 is offline   Reply With Quote
Old 08-13-2009, 06:03 PM   #31
chrisgalles
TEXAS FIGHT!
chrisgalles's Avatar
Drives: Awesome
Originally Posted by Ranger 75 View Post
Tom Cat, So to get back to the point! I have 2500 miles 0n my LS3 can I now switch to Royal Purple?
Yes. You will be fine. I changed my oil for the first time right at 1500 miles and put in RP 5w-30. I don't care what anyone says....I backed my car up out of the shop where I changed it and the car just felt smoother. RP is the real deal. It is the only oil that my Camaro will see.
chrisgalles is offline   Reply With Quote
Old 08-13-2009, 06:11 PM   #32
FI4T0MCAT
FI4T0MCAT's Avatar
Drives: 1969 SS Camaro
Yes you can, and you will be fine. I incourage everyone to research their own products, and decide what you want to use, and what you feel is best for you. I just go by what i have learned, and the advice of a couple of professional engine builders. i DO NOT run RP alone, nor will i ever.
FI4T0MCAT is offline   Reply With Quote
Old 08-14-2009, 12:06 PM   #33
SaintTimothy
Drives: 2010 Camaro
What zinc additive do you use? How much?
2LT/RS IBM, White Rally Stripes, Gray Int, M6
Ordered 10/18/08
Delivered - 6/19/09
SaintTimothy is offline   Reply With Quote
Old 08-14-2009, 12:16 PM   #34
Paperer
Ragin' Cajun
Paperer's Avatar
Drives: '02 Camaro SS - '10 CGM 2SS/RS
I've been using Mobil 1 forever, they're the only reason I never used Royal Purple, I thought they were just as good. Welp, looks like I'm buying a bunch of purple bottles in a few miles.
http://img.photobucket.com/albums/v202/paper2302/Siggy.jpg
Paperer is offline   Reply With Quote
Old 08-14-2009, 03:49 PM   #35
oilman63
rjt ordered 10-15 2ss
oilman63's Avatar
Drives: 2010 2SS badass camaro
Originally Posted by ROBBDOGG1986 View Post
But what do you do when your dealer says that ut will void your warranty if you don't use mobile1, what would you do?
Sue! When they tell you that you have to use a specific brand than they better dam well supply it.
oilman63 is offline   Reply With Quote
Old 08-14-2009, 03:56 PM   #36
oilman63
oilman63's Avatar
Royal purple, and yes, but thats just my opinion. With all new engines I add zinc initially (adds cushioning properties to the oil) then make my first oil change at 1500. leave the filter though, Then my second at 3000, and change the filter. Then continue on the every 3000 schedule. I always add a zinc addative, oils now cant have enough zinc in them (thanks uncle sam) to provide proper cushioning. So i basically make my own blend.
I disagree.The oil filter in the first oil change is crucial.That's when your getting the most metal particles.That's why I do 500 miles first 2500to 3000 on second.The filter is most important anyone who says different I wouldn't listen to much they have to say.
Old 08-14-2009, 07:18 PM   #37
Shadowmind
Drives: 2010 2SS - IOM, fully loaded
Can we put 10w30 in the SS?
Shadowmind is offline   Reply With Quote
Old 08-14-2009, 09:50 PM   #38
FI4T0MCAT
FI4T0MCAT's Avatar
Your right i was a bit tired when i wrote that. This applies to break in on an engine only (that you yourself built), and this is for the first oil change that is no more than 500 miles not 1500. Leave the filter and run the full synthetic. Reason being is the filter still contains some of the break in oil, and will mix in some of the high zinc and phosphoris, that are great for cushioning. (im sure the factory does this sort of process before we ever recieve the car however). So for my first oil change on the 2010 its RP with ZDDP addative.
please forgive me, im on alot of forums, and my sbc thought process flairs up here from time to time.
oilman if you feel different than what i have posted then by all means do not listen to me. As i stated before everyone should do their own research. I have found what works for me and that is what i do. I have IMO a nice fleet of cars, all run as perfect as when they were new. If you do something different then great, but i will certainly never try to make a fool out of you by indirectly saying your thoughts are not worth a damn.
Old 08-18-2009, 02:02 PM   #39
GEN-IV
HEMI Hunter
GEN-IV's Avatar
Drives: 06 GTO / 79 Z28
I agree that ZDDP is crucial for some engines, especially flat tappet SBC/BBC applications. Does an engine like the LS3 benefit from ZDDP? It has a full roller valvetrain that certainly doesn't benefit from added zinc.
I thought ZDDP primarily helped boundary layer lubrication, it doesn't do anything for hydrodynamic bearings.
2010 2SS/RS M6 CGM E-Force + 2015 1LT V6/A6
GEN-IV is offline   Reply With Quote
Old 08-18-2009, 04:32 PM   #40
toehead93
Drives: 2014 2SS/1LE
5W30 or 10W30?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-18-2009, 05:03 PM   #41
ssarrival
ZUL8TR
ssarrival's Avatar
Drives: 94 Z28
5w30
ssarrival is offline   Reply With Quote
Old 08-19-2009, 01:02 PM   #42
Moth
Drives: 2010 Black 2LT/RS camaro
when should i change ? i have 75% oil left and 2500 miles ..
Moth is offline   Reply With Quote
Engine break in methods two_wheel_mayhem Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 39 08-19-2009 10:22 AM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
