Cold Air Inductions
Old 07-12-2014, 10:49 AM   #15
bandit38
bandit38's Avatar
Drives: Camaro SS - Trans Am - Silverado
Originally Posted by ChrisBlair View Post
I can't help myself
LOLLOL
That is FUNNY !
bandit38 is offline   Reply With Quote
Old 07-12-2014, 12:06 PM   #16
My Caroline
My Caroline's Avatar
Drives: Black 2011 Camaro LS
Originally Posted by RollaMo View Post
That is what I am hearing too.
Nope, does it when AC is off
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob
SS Fascia, Factory RS HIDs, Plasma P13W fog lights
Non-RS to RS and fog light harness by Gen5DIY
LED Interior, Trunk, and Licence Plate lights in white
ZL1 Spoiler with Gen5DIY harness
Factory NPP cat back
Blacked out tail light bezels
Factory 20 inch wheels wrapped in Nitto Motivos
Lowered 1.25inch on Eibach Pro springs
My Caroline is offline   Reply With Quote
Old 07-12-2014, 12:12 PM   #17
My Caroline
Originally Posted by Comrando View Post
Is it set to defog? That can activate the A/C.
Nope.
Old 07-12-2014, 12:12 PM   #18
My Caroline
http://youtu.be/v8Yy4HHUsBQ
From last night.
Old 07-12-2014, 02:02 PM   #19
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
My guess is right along with these guys, it could be a fuel pressure issue.
Unrelated but kinda similar, my Yamaha FZ1 tends to do this after it's been sitting for awhile after being hot. I'll go hop on and it will start then die a few times before it will stay running.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 07-13-2014, 08:07 PM   #20
TheSmokingSuns
TheSmokingSuns's Avatar
Drives: 2011 Camaro 2LT
Here is my video of same issue OP is having
TheSmokingSuns is offline   Reply With Quote
Old 07-13-2014, 11:12 PM   #21
My Caroline
That doesn't explain why it's fine on cold starts.
Old 07-13-2014, 11:31 PM   #22
TheSmokingSuns
Yeah I guess we are the only two with this problem and happen to be 2011 models.
Old 07-15-2014, 02:39 AM   #23
TheSmokingSuns
Here is a video of a POP sound when starting the car. Any people on this helpful forum possibly know what may be the issue??? It sounds pretty bad and does it randomly when car is warm.
Please excuse messy garage. In the middle of cleaning it.
Old 07-15-2014, 02:54 AM   #24
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Man... sounds like rod knock but obviously is not. A knock that loud would manifest more than that.
I'd say maybe you have a header or exhaust hitting under the car?
But since there is more than one of you I'd say starter?
The audio is great but I can't think of anything. I'm just throwing them out there.
Exhaust headers and back will expand when hot and the motor shakes the most at start up.
Old 07-22-2014, 05:41 PM   #25
Master Shake
Drives: Camaro LS
2010 LS, Auto - mine does this as well. Only when warm (but not every time) and never on a cold start (where the engine revs higher for ~10 seconds).
Occasionally, it will make a backfire pop as well -- but it usually just sounds like a single, regular engine knock when it happens. It does not cause the car to stall out or anything, and it runs fine once started.
It generated a code one time, so I took it into the dealer. The code translated to a bad spark plug, which they replaced under warranty. However, the problem still continues every once in a while (never when at the dealer of course!).
Master Shake is offline   Reply With Quote
Old 07-23-2014, 11:18 AM   #26
My Caroline
Still hoping for a fix
Old 07-23-2014, 11:47 AM   #27
Phail
Phail's Avatar
Drives: 2011 2LT/RS M6 IOM
I get the same thing every once and awhile when starting - never even made note of it honestly until this thread - I guess it probably only happens when shes hot.
Why does it matter? The choking doesnt even last for as long asyou turn the key - and it definately doesnt stall or bog out.
Phail is offline   Reply With Quote
Old 07-23-2014, 12:05 PM   #28
RobertRS
RobertRS's Avatar
Drives: 2014 2SS L99
That knock sound seems to only happen while cranking. I'd suspect something to do with the starter. A rod knock would persist beyond cranking. Possible heat soak issue with respect to starter.
RobertRS is offline   Reply With Quote
wrong subforum
