Old 07-11-2014, 09:26 AM   #1
skulka222
skulka222's Avatar
Drives: 2012 M6 Victory Red Camaro ZL1
LFX engine questions
So Ive been trying to find this for quite a while, and couldnt come around to it. I will be adding IPS motorsports twin turbo kit to my 2014 V6 camaro. The kit will put me around 460-470 on the flywheel. I'm just skepticle and doubting that my stock internals and transmission will be able to handle this power increase. Anyone wanna fill me in on the details of the max torque/horsepower limit my transmission will hold and such.
skulka222 is offline   Reply With Quote
Old 07-11-2014, 09:32 AM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Go here:
http://www.camaro5.com/forums/forumdisplay.php?f=98
FSP tuned: 377/389
Old 07-11-2014, 09:33 AM   #3
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
I would ask that question of IPS Motorsports, if I were you.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint
PalmerGA is offline   Reply With Quote
Old 07-11-2014, 10:50 AM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 Summit White 2LT/RS
GretchenGotGrowl's twin turbo build had a few failure points
-HPFP couldn't supply enough fuel past about 600hp flywheel (~550whp?)
-Transmission was wearing heavily but had not grenaded
-Blew stock piston? on a drag run.
I should hope he could comment soon. Check out his build thread - that's easier. Its in the V6 FI section.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can, Apex Scoop w/ Washer Relocation Kit, CTS Front Caliper Conversion, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, VIS Terminator Hood
DSX_Camaro is offline   Reply With Quote
Old 07-11-2014, 12:20 PM   #5
Desertion
Drives: 2010 1LT/RS Transformer Edition
I thought the IPS TT kit put out ~460 to the wheels?
Desertion is offline   Reply With Quote
Old 07-11-2014, 12:26 PM   #6
Desertion
http://www.camaro5.com/forums/showthread.php?t=308593
575 crank
460 rwhp
Old 07-11-2014, 02:09 PM   #7
DSX_Camaro
DSX_Camaro's Avatar
Yes, GretchenGotGrowl is a custom build. But it's still twin turbo. You were wondering about the failure points of the engine or transmission.
My point being the kit should be perfectly fine.
Old 07-11-2014, 02:50 PM   #8
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Desertion is right, the IPS kit makes about about 460 RWHP; perhaps you are confusing it with the IPF supercharger.
Like DSX_Camaro is saying, I've pushed mine well beyond what the IPS kit does if you don't modify it (run more boost). If you have an automatic transmission I would suggest you put in an aftermarket transmission cooler. If you have a manual then you should expect to go through clutches a lot faster than normal. Sycraft has an aftermarket clutch that is working well for him.
As far as engine internals, I don't think you will have any issues at that power level if you buy good gas.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 07-11-2014, 03:02 PM   #9
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
What transmission cooler would you recommend? Probably should be looking at that before I go higher in boost.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is online now   Reply With Quote
Old 07-11-2014, 03:11 PM   #10
GretchenGotGrowl
I just picked up one at an auto parts store. They are cheap insurance.
Old 07-11-2014, 03:27 PM   #11
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I was thinking of the same thing before I put the IPF S/C kit on mine.
I'd love to got form this TT kit but being in Cali I'm not sure I could pass smog?
Mods:
Old 07-11-2014, 09:52 PM   #12
13umble13ee
13umble13ee's Avatar
Drives: 2012 1LS V6 LFX
From my understanding they replace the cats with the snails so that right there means fail on smog. unless you build a custom exhaust and house the cats somewhere else.
13umble13ee is offline   Reply With Quote
Old 07-11-2014, 10:18 PM   #13
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Perhaps install smog cut outs!
Switch on = pass smog (bypass through the cats)
Switch off = TT power! (bypass the cats)
Mods:
