Old 08-11-2009, 12:25 PM   #1
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
Stock L99 Dynograph w/ some interesting info
I just dynoed mine to get a baseline (600 miles) and it put down 319rwhp twice then we pulled the pcm fuses for it to forget the LTFT (Long Term Fuel Trims), engine had more heatsoak than the first two pulls and it put down 327rwhp...Let me tell you picking up 8rwhp by doing that, this computer has a serious nanny program. The trans tune alone is going to be awesome. It really woke up my A6 Vette. I put ARH headers on it the day after and as soon as the Vararam is ready that will go on and I will get it tuned. So have faith o L99 bretheren...The curious thing I`ve noted is how there is a slight sip in the graph after 5250rpm`s then it picks back up, I`m assuming this may be when the VVT kicks out and is no longer making that extra midrange power. Any tuners can explain that? I`ve seen it on other L99 graphs, but not on the LS3 graphs...
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 08-11-2009, 12:36 PM   #2
Terrellford12
Drives: 2010 SS/RS
What can i do to gain the extra 8 hp i have a l99 and what does this take from the car itself
Terrellford12 is offline   Reply With Quote
Old 08-11-2009, 12:42 PM   #3
GMRULZ
GMRULZ's Avatar
Remove the ECM fuse to clear the LTFT memory, then reinstall after a couple of minutes, it will relearn it though after some time and will need to be done again to get the power back. It is some sort of GM nanny thing evidently. The car won`t run w/ out the fuse being reinstalled if that was your question regarding what would it take away from the car.
You could install a Dash Hawk to clear it at the touch of a button from inside the car, but I`m hoping this bad learning can be tuned out or made not so sensitive so it doeesn`t take away so much power. I`m going to post this in the tuning section as a question.
Old 08-11-2009, 12:50 PM   #4
shroomjohn
shroomjohn's Avatar
Drives: Golden Eagle
Man just wish theyd let these cars run like theyre meant to and stop trying to take away the power in these badboys
Loving this car!
shroomjohn is offline   Reply With Quote
Old 08-11-2009, 12:51 PM   #5
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I see your fuel/air mixturre stayed constant at a normal level during that pull. Was it the same on the other pulls?
Old 08-11-2009, 12:53 PM   #6
GMRULZ
GMRULZ's Avatar
I beleive it was the same, I`m trying to get the graph of all 3 overlayed, but the dynoguy gave me only the best one. If and when I can get it I will post it.
Old 08-11-2009, 01:03 PM   #7
PQ
Booooosted.
PQ's Avatar
Mine took 'the plunge' and at one point dropped off of the cart.
Old 08-11-2009, 06:36 PM   #8
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
The L99 isn't the first car to make more power (very short term) with an computer re-set.
But it doesn't take all that long for the computer to correct itself go back to stock HP levels.
Old 08-11-2009, 09:17 PM   #9
GMRULZ
GMRULZ's Avatar
You gotthat right. It needs to be tuned out as much as possible or a dash hawk to reset it from the cabin.
Old 08-12-2009, 12:04 AM   #10
Tomato
G-Force Addict
Tomato's Avatar
Drives: 2010 SS/RS A6
Which fuse did you pull? I looked in my manual and found an "ECM" fuse as well as an "ECM Battery" fuse. I'm assuming the battery fuse keeps power and memory for the ECM...
Thanks!
Tomato is offline   Reply With Quote
Old 08-12-2009, 08:32 AM   #11
live2well
Drives: 2010 VR 2SS/RS A6
Thanks!
+1
Intelligence plus character that is the goal of true education.
BrianC. :flag2:
live2well is offline   Reply With Quote
Old 08-12-2009, 08:46 AM   #12
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Old 08-12-2009, 08:49 AM   #13
GMRULZ
GMRULZ's Avatar
Thanks!
I pulled both of those for good measure, wasn`t sure which one would rest the ECM. I would also assume ECM battery fuse to be correct, but just to be sure I pulled both.
Old 08-13-2009, 10:01 PM   #14
Tomato
G-Force Addict
Tomato's Avatar
Not to be a pain, but...You pulled your trunk apart to get to the ECM Battery fuse?
Thanks again.
Headers for an L99 Automatic.....17/8 or 1 3/4 ? Jekyll-N-Hyde Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 08-02-2010 02:54 PM
L99 Camshaft Info HaveBlue Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 08-08-2009 05:43 PM
Some interesting info about LS3 testing oldfart1941 5th Gen Camaro SS LS LT General Discussions 55 07-23-2009 11:05 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
