BeckyD @ James Martin Chevy
Old 07-15-2014, 12:55 PM   #1
crateish
crateish's Avatar
Drives: 45th Anniversary 2LT/RS Coupe
Broken Key
My warranty is about to run out and I have to take my 45th in for service. One of my switchblade keys broke, so now I only have one working one, which I will have to use to get the car there.
It sounds here like I do not have to surrender the intact key for their wonderful solution to the recall.
Is that true?
Can I assume that they will not replace the fob on the broken key, and will automatically stick the blade into a cheap plastic head?
Any other solution to fix my broken fob?
crateish is offline   Reply With Quote
Old 07-15-2014, 01:01 PM   #2
BellamyGirl71
BellamyGirl71's Avatar
Drives: 2014 Red Hot Camaro 2SS/RS
I don't know if you would have to do that, as from what I've read if you already have the key before the recall you can opt out of the recall. On the other side of this, you can buy just the replacement blanks on ebay for around $8 w/free shipping. Or the whole thing for around $25. Good luck! I hate the new keys, so I've been looking at putting the blade back in.
BellamyGirl71 is offline   Reply With Quote
Old 07-15-2014, 01:05 PM   #3
Squillo
Squillo's Avatar
Drives: 2013 Camaro 2SS/RS BRM LS3
http://www.ebay.com/itm/New-Oem-Chev...3ce6fd&vxp=mtr
You're welcome.
Performance
AirAid CAI
Apex Motorsports ported spiraled Throttle Body
Kooks 1 7/8" LT headers and 3" mid-pipes (cat delete)
Hurst shifter
Dyno Tune
Cosmetic
Camaro badge GOBO door lights
"SS" badge GOBO hood and trunk lights
Blacked out side markers with 30% tint
Blacked out tail lights with 30% tint
Afterburner tail lights
Blue / white color changing headlight and foglight HALOs
Blue LED upper and lower grille accent lights
30% tint windows
Plasma fog light bulbs
DRL harness
"BDMFER" Hawaii state issued license plates
"Bad Mother****er" custom blue lighted door sills
Blacked out bow ties
Squillo is offline   Reply With Quote
Old 07-15-2014, 01:50 PM   #4
SSJ455
SSJ455's Avatar
Drives: "Blue Saber" 2017 2SS HBM
Can anyone who makes keys cut the blade?
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!!
What?
Dangerzoooooone.
SSJ455 is offline   Reply With Quote
Old 07-15-2014, 02:03 PM   #5
87GNX
87GNX's Avatar
Drives: Alot
Local hardware stores (Ace) usually cut keys
87GNX is offline   Reply With Quote
Old 07-15-2014, 02:04 PM   #6
Squillo
Squillo's Avatar
You can re-use the existing blade. It has a pin that you can remove and then just place it back in the new key.
Performance
AirAid CAI
Hurst shifter
Dyno Tune
Cosmetic
30% tint windows
DRL harness
Old 07-15-2014, 02:44 PM   #7
i2disturbedSS
i2disturbedSS's Avatar
Drives: 2010 SS L99 IOM
Happen to me also. Cheap ass key...
Anyways short story you can still use that broken key. Just put the actual key part in and turn it with the fob. I had to do this cuz I was away from home. But you still can get another one with the link above.
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins
i2disturbedSS is offline   Reply With Quote
Old 07-15-2014, 03:32 PM   #8
Kopterman
Kopterman's Avatar
Drives: 2014 Bright Yellow 2SS/RS
Get some JB Weld and glue that sucker back together!
Kopterman is offline   Reply With Quote
Old 07-15-2014, 05:52 PM   #9
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
They probably do not have the laser cutting machine needed to cut the key.
Caddy
Caddyroger is offline   Reply With Quote
Old 07-16-2014, 07:20 AM   #10
crateish
crateish's Avatar
Cheap Chinese metal, most likely. Democrats in Congress are working on a plan to block illegal cheap metal sales. Hopefully they will be successful.
Old 07-16-2014, 07:39 AM   #11
Natebrod
Natebrod's Avatar
Drives: 2014 2SS 1LE Summit White
What so now congress makes nearly impossible to produce metal in the states because of the EPA and now they are going to disallow the sales metal made else where? And don't get me wrong I hate china as much as the next guy but I don't not need the government to make decisions for me. I hope that they are not successful. It's about time our government take a huge step back and stop making new laws and maybe get rid of some instead.
Natebrod is offline   Reply With Quote
Old 07-16-2014, 08:10 AM   #12
Bowtie-Bri
Bowtie-Bri's Avatar
Drives: 2013 Camaro 2SS RS Convt.
Link saved to my watch list if this ever happens to me. Thanks!
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. FOR SALE
Bowtie-Bri is offline   Reply With Quote
Old 07-16-2014, 11:06 AM   #13
Mean Green Z28
Drives: 2010 2SS
my local GM dealer has the laser cutter required to cut these keys! Call around and ask a couple dealers if they have the machine, it's pretty expensive, so not many dealers buy it.
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline   Reply With Quote
Old 07-16-2014, 12:49 PM   #14
GreaseMonkey
GreaseMonkey's Avatar
Drives: 2011 2LT/RS Camaro
I think cadillac dealerships usually carry them , The one I went to in houston did .
GreaseMonkey is offline   Reply With Quote
wrong subforum
