JUICEDMOTORSPORTS
Old 07-19-2014, 12:04 PM   #15
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 NPP BRM
Originally Posted by sinisterZL1 View Post
Huh?
The key in your last picture looks just like the eom key. What changed?
camguynj is offline   Reply With Quote
Old 07-19-2014, 12:21 PM   #16
DJ A
DJ A's Avatar
Drives: Cammed 2010 SS
He put the new separate key in the old switchblade keyfob.
2010 Camaro 2SS/RS LS3 - 450rwhp and 425tq
- TSP 231/236 Cam, Dynatech 1 7/8" LT Headers, Dynatech Cat Delete, CAI Intake, BMR 1.4" Drop Springs, Hurst Short Throw Shifter, Magnaflow Street Series Axle-Back w/X-pipe
- Tuned by Ivan @ SouthwestSpeed
DJ A is offline   Reply With Quote
Old 07-19-2014, 12:26 PM   #17
sinisterZL1
sinisterZL1's Avatar
Drives: 2014 ZL1
The last pic is of the key shaft installed on the black fob I received when I picked up my camaro yesterday.
sinisterZL1 is offline   Reply With Quote
Old 07-19-2014, 12:26 PM   #18
sinisterZL1
Drives: 2014 ZL1
Bingo.
Old 07-19-2014, 12:57 PM   #19
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
Did the car start after you broke the key out of the original holder? The RFID signal to recognize the key and start the car was in the key holder you demolished to get the key.
If you destroyed the original RFID device, you should have had to relearn the modified keyfob, as there is also an RFID device in the fob.
jeffa is offline   Reply With Quote
Old 07-19-2014, 01:28 PM   #20
camguynj
camguynj's Avatar
Why did you bother? Isn't that the same thing as having the eom switchblade key?
Old 07-19-2014, 01:50 PM   #21
DJ A
DJ A's Avatar
Because the switchblade is cooler than the recall key
Old 07-19-2014, 02:04 PM   #22
camguynj
camguynj's Avatar
AGREED, but didn't SinisterZL1 start with an eom switchblade key fob?
Old 07-19-2014, 02:13 PM   #23
sinisterZL1
Drives: 2014 ZL1
Yes is started with a switch blade fob but the factory recall removes the key blade and sticks it in an rubber end key nub. I ground the nub off and installed it on the empty switchblade fob as they leave the factory hinge in place in the fob. I hate having the standard key and a fob after have the switchblade on my 2012 ss. So much nicer. I left the second set of keys alone for now.
Old 07-19-2014, 02:23 PM   #24
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
The plastic he broke the key out of has no electronics in it. I just did the same thing. Nothing but plastic
meshamey is offline   Reply With Quote
Old 07-19-2014, 02:28 PM   #25
sinisterZL1
Drives: 2014 ZL1
Actually mine had a anti theft chip in it. I cut into it by accident. I tried using the key with a pair of vise grips after and the anti theft tripped. But once I put key blade into fob body it started up so the plastic nob and the fob must both have a anti theft chip. This is a Canadian 2014. Don't know if there different for different years or if it makes a difference in a USA delivered car.
Old 07-19-2014, 02:50 PM   #26
meshamey
Meshamey
meshamey's Avatar
Oh dam, I missed that, i will go back and look. But mine started up fine after I removed the key and re installed it in the FOB. I did not try it while it was out.
Old 07-19-2014, 03:06 PM   #27
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
My service center is Cadillac so I doubt they'll even bother, but if they do, fine. I'll use the new key when I get service and my spare original for regular use.
ChrisBlair is offline   Reply With Quote
Old 07-19-2014, 03:13 PM   #28
sinisterZL1
Drives: 2014 ZL1
That's my plan as well.
