HeadlightArmor
Old 08-11-2009, 09:22 PM   #1
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
Dyno results, LS3 w/AHR headers running E85
Ok guys, I finally got to the dyno tonight. My car is an SS M6 with American Racing Headers and tuned for E85. The testing was done on a Mustang dyno that supposedly reads low and the numbers are corrected for temp and weather conditions.
Max HP 420
Max Torque 400
The next mods will be a cam and Vararam CAI. . .
E85LSX is offline   Reply With Quote
Old 08-11-2009, 09:23 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
very cool.
I piss excellence
and fart awesomeness
Old 08-18-2009, 12:15 AM   #3
ADM PERFORMANCE
Drives: 2016 CAMARO SS
Max HP 420
Max Torque 400
Who did the work?
What dyno was this?Looks like some shop in new york based on the plates.
Andy
ADM PERFORMANCE is offline   Reply With Quote
Old 08-18-2009, 07:50 AM   #4
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
I do the installs and tuning, the dyno is kaltech's. Kaltech tuning is located in seatauket new York, these guys are great to work with and very knoweldgable, I definitly recommend them.
Next engine mods r cam and heads, I just have to figure out how to get this baby more fuel. I'm flowing around 40% more fuel than stock and this is the end of the stock fuel systems capabilities. The injectors r an easy fix, I have bigger ones, but the pump is a little tricky because if the Fuel Pump Control Module fitted on these cars. I'll keep everybody posted with my progress on the fuel pump.
P.S. My pedders system arrived today and I'm pschyed!! Pics will b up this weekend!
Old 08-18-2009, 10:53 AM   #5
A.R. Headers
A.R. Headers's Avatar
Drives: Pontiac G8 GT
Guys, Great Job! Keep us posted on your mods and the results. Thanks for choosing ARH.
Nick
A.R. Headers is offline   Reply With Quote
Old 08-18-2009, 10:56 AM   #6
toehead93
Drives: 2014 2SS/1LE
Did you get any base dyno numbers before the headers and tune?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-18-2009, 01:48 PM   #7
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
Nick, great set of headers. They fit perfect and sound AMAZING, no one believes how good and LOUD this beast is when they hear it. I don't have the carted system and I really think that's makes the difference in the sound cause she really screams!
I did not get baseline numbers before these mods but after researching everyone elses I'm guessing around 36X rwhp and torque stock. She definitly pulls much harder than stock though!
Old 08-18-2009, 08:09 PM   #8
Ltdodge
Ltdodge's Avatar
Drives: 2008 Z06
are the fuel hoses on the camaro set up to run e85 without messing them up or did you run new lines?
Ltdodge is offline   Reply With Quote
Old 08-18-2009, 08:56 PM   #9
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
I am not sure if the lines are designed for E85 but I do know they are designed for at least E10 which is what most gas stations offer. I am not an expert on every different materials compatibility with ethanol but I am a mechanical engineer and I'm assuming that if they used materials that could withstand 10% ethanol chances are these same materials can withstand a much higher ethanol content. Material analysis of the different fuel system components can confirm this theory but I really do not think it is necessary.
Instead I am going to keep an eye on the fuel system and if ethanol starts spraying out everywhere than I think it would be safe to say the fuel system was not designed for it. If this doesn't happen than it looks like I assumed right lol.
Old 08-18-2009, 10:07 PM   #10
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The Camaro's fuel line and the fuel injectors are not E85 compatible. They will need to be replaced eventually.
Old 08-18-2009, 10:24 PM   #11
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
the lines will last a long time,, i run my equinox on e85 when gas prices go up , i use a maft,, no problems ,, and i had an s-10 5.3 running on e85 with steel lines and rubber multi-fuel hose with no problems
Old 08-19-2009, 10:17 AM   #12
IsoTorque
Drives: 2010 Camaro 2SS/RS
What numbers did you enter for the dyno, weight, HP @ 50 ?
Max HP 420
Max Torque 400
I am going to run on our dyno at work which is a mustang but we dont have the weight or the HP @ 50, what was used during your test, since the look up tables dont have the camaro?
IsoTorque is offline   Reply With Quote
LS3 CAM AND HEADERS DYNO ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 53 02-13-2016 07:15 PM
irpq11, L99 Dyno results. PQ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 483 01-11-2010 02:56 PM
Texas Speed Long Tubes & Rumbler 5 Cat-Back Dyno Results! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 47 09-06-2009 04:36 PM
E85 and ls3. my2010camaross USA - Southwest 6 07-11-2009 11:08 AM
LS3 & headers kdbolt70 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 03-21-2009 07:23 PM
