Old 07-22-2014, 01:40 PM   #1
SinfulCamaro
Sinful Camaro
SinfulCamaro's Avatar
Drives: BLACK 2010 2SS RS
2010 Camaro SS wont turn over..
I have read as many of these issues and I can research but still cant figure it out..
I have a very modified Camaro but have not changed wiring..
I go to car with battey fully charged and everything comes on dash and aftermarket radio but when I compress the clutch there is no turn over (absoutley so noise or attempt)
I will wait hours and try again and sometimes it turns over and sometimes it still wont.
I have tried a brand new key and moving gears and clutch and no change.
I have also had car battery fully charged along with jumper cables running on it and still nothing. It randomly starts and does not when it wants.
Sometimes after the car starts and while im driving all of the sudden the dash gauges shut off and engine obviously works fine but all digital gauges just drop off as if car is off..
ANY ADVICE?? Heres my cell too (954)696-6988 THANKS GUYS
SinfulCamaro is offline   Reply With Quote
Old 07-22-2014, 01:51 PM   #2
SS Blinder
SS Blinder's Avatar
Drives: 2011 SS (Sparrow Spearer???)
full battery and issues starting...seems the starter is a good place to start. maybe trying test the starter and charging system. i believe auto zone can do it while in the car but that means you got to get it there. gl
Black magic woman, don't turn your back on me baby.
SS Blinder is offline   Reply With Quote
Old 07-22-2014, 01:54 PM   #3
SinfulCamaro
Sinful Camaro
Theres something thats not even allowing the started to turn. The starter makes no noise or attempts.
Old 07-22-2014, 01:59 PM   #4
SS Blinder
SS Blinder's Avatar
maybe intermittent clutch depress switch. but i don't think this would cause the loss of power while driving. last time that happened to mean, i lost the drive belt.
Old 07-22-2014, 02:09 PM   #5
SinfulCamaro
Sinful Camaro
where is this intermittent clutch switch located?
Old 07-22-2014, 03:59 PM   #6
95birdible
95birdible's Avatar
Drives: 2012 1SS Camaro Convertible
I don't know if the Camaro's have a starter solenoid or not but that is where I would start. Seems juice isn't getting to the starter. If they do have a solenoid, you can always touch the positive and negative at the same time with a screwdriver to get it to jump. Used to have to start my 77 Volare that way.
2012 1SS Crystal Red Convertible
"Cherry Bomb"
Winner of the #NameThatCamaro Spring Special Edition
"Green Flash"
95birdible is offline   Reply With Quote
Old 07-22-2014, 04:32 PM   #7
SinfulCamaro
Sinful Camaro
Seems like something loose somewhere cause it stated randomly and the RPM gauge started going on and off along with cluster gauges and all of the sudden they all went off while engine was still running..
Old 07-22-2014, 04:36 PM   #8
roadblock
roadblock's Avatar
Drives: 2014 2SS 1LE BRM
My first suspicion would be the VAT System. Bypass that and see what happens. You should be able to find a means to accomplish that online, doing a search. good luck.
roadblock is offline   Reply With Quote
Old 07-22-2014, 08:59 PM   #9
SS Blinder
SS Blinder's Avatar
i meant that in order for a manual car to start, the clutch must be depressed fully. thereby making the switch. if the switch does not work, the car will not turn over. so maybe it is only working intermittently. but that shouldn't cause all the other issues you are having. might be time to take it to a mechanic
Old 07-23-2014, 11:51 AM   #10
lawdog
Drives: 2010 SSII w RS & Sunroof Yellow
Location: West Suburbs of Chicago, in a Courthouse Somewhere
Sounds like a ground issue, check your grounding carefully.
lawdog is offline   Reply With Quote
Old 07-26-2014, 09:57 PM   #11
lawdog
What's the word, did you resolve the issue ?
Old 07-31-2014, 10:59 PM   #12
SinfulCamaro
Sinful Camaro
Been outta town damn Uncle Sam I'll letcha know
Old 07-31-2014, 11:37 PM   #13
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Check for voltage at the starter. If there is, jump the signal wire and see if it tries to start. If it does. It will tell you if the starter is the issue or something else in the circuit.
Caswell239 is offline   Reply With Quote
