Frankenstein Engine Dynamics
Old 04-13-2008, 09:03 PM   #1
CaptianSam
Car Garage
CaptianSam's Avatar
Drives: 350z,A4,SRT8...see sig
What gas will you be pumping?
Curious... what octane did forth gens require?
when you get your camaro will you be pumping 91?
what are the bad/good affects of using 10% ethonal fuel...
example sunoco 94 10% ethanol...
2012 2SS RS Ordered
Black on Black 6 speed Coupe Artic Lid Stripes
Yes I Supercharge Everything
On My Ipad
Xbox McLovin1515
Ps3 McLovin1555
Current Autos:68z28,03viperSRT10,04escalade,05RangeRoverSport SC
Project Autos:80corvette350-500hp 6speed,06charger S'C 6-speed posi,74Firebird400blue,69chevelle572 707
New Autos:2012CamaroSSRS,09ChallengerSRT8
Past Autos:....too many to list
"i told you it was gettin' an LS3"
Go down deep enough into anything and you will find mathematics. Dean Schlicter
B.Sc. Hons. Mathematics
CaptianSam is offline   Reply With Quote
Old 04-13-2008, 09:15 PM   #2
Jeff
~ANTI-FORD~
Jeff's Avatar
Drives: Cadillac CTS
Send a message via MSN to Jeff
GM states 89 Octane gas is good for all their vehicles. Even the Corvette, so I'm not wasting more money than I have to.
My Z28
sorry guys.. sold Camaro and got a Cadillac CTS, waiting for a few years to get a 2010 SS used ;]
Jeff is offline   Reply With Quote
Old 04-13-2008, 09:19 PM   #3
JaysonAych
JaysonAych's Avatar
Drives: 2002 Dodge Stratus
Yeah, whatever the owner's manual calls for is what I'll put in. No more, no less.
JaysonAych is offline   Reply With Quote
Old 04-13-2008, 09:28 PM   #4
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
The higher the octane, the slower the combustion burn (less volatile). When you use a higher octane, the engine computer (ECM) can keep pushing the ignition timing advance for more horsepower.
Detonation (pinging) occurs when the combustion burn is too fast and the explosion of combustion slams down on the still coming up piston.
Most GM V8's have been using ESC (Electronic Spark Control) for many years. It uses a piezo-electric microphone to listen for detonation, and when it hears a certain amount (ECM see's this as a voltage from mic) it will back off the advance.
It uses an intricate logarithm you wouldn't beleive.
So, the higher the octane - the more spark advance and horsepower. As long as the engine uses ESC or similar.
We get 93 in Florida, that's all my Camaro will ever see. Ethanol does boost octane ratings, too.
Throw a can 104 octane boost (any auto parts store) in the gas tank and hold on!
Or you can use lower octane (more volatile) - (check owners manual) and save money for less horsepower.
camaro5 is online now   Reply With Quote
Old 04-13-2008, 09:48 PM   #5
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I've heard that you can use a lower octane fuel durring winter months. That would help if you drive your Camaro in the witer. I won't, so it doesn't mean a whole lot to me.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 04-13-2008, 09:56 PM   #6
Scotsman
Auto Pilot
Scotsman's Avatar
Drives: Gunmetal
Whatever makes cents for my annual gas budget.
"Let the rest of the world dream of Ferraris, Lamborghinis and dinky little British two-seaters. In this country speed doesn't look like that." Got SS?
Scotsman is offline   Reply With Quote
Old 04-13-2008, 11:04 PM   #7
CaptianSam
Car Garage
CaptianSam's Avatar
i know the way octane ratings affect your power and emissions... but will 10% ethanol have a negitive or positive effect...
2012 2SS RS Ordered
On My Ipad
Xbox McLovin1515
Ps3 McLovin1555
Old 04-13-2008, 11:14 PM   #8
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
In terms of performance...it'll be a minor positive effect (Ethanol = 105ish Octane rating, so figure 10% of your fuel is like that). Emissions...well, that 10% will burn with ~30% less emissions than the same quantity of gas - so that's negligible.
In terms of fuel economy, in case you were wondering, you may loose 1mpg.
Old 04-13-2008, 11:19 PM   #9
CaptianSam
Car Garage
CaptianSam's Avatar
will it have long term effects on the enigne? if i use it every day...? if th car isnt ethanol compatable...
im not concerned with the performance... but more the reliability and constant usage affects?... are there any long term negatives?
2012 2SS RS Ordered
On My Ipad
Xbox McLovin1515
Ps3 McLovin1555
Old 04-14-2008, 07:36 AM   #10
OzCamaro
OzCamaro's Avatar
Drives: Holden Commodore
I've found over here in australia you pay more for the higher octane fuel but you get better fuel economy so it really pays for itself. Now I don't use anything else.
OzCamaro is offline   Reply With Quote
Old 04-14-2008, 10:15 AM   #11
Jay
Jay's Avatar
Drives: Audi A4
Well im used to paying to for higher octane because of driving a german car all the time.... so im just going to stick with it.... and what Oz said above is true as well.... I find that you get better gas milage as well..... in the end i found that you end up paying about an extra 5 bucks tops for higher octane fuel to a tank after it all works out.
So I dont think its that bad. Its sorta like the synthetic oil vs. regular oil in your engine.... both are fine when it comes down to it.
"HEAVEN JUST COULDN'T HANDLE ALL THE NOISE"
JAY
Jay is offline   Reply With Quote
Old 04-14-2008, 02:16 PM   #12
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
everyone has good points about things, but the OP question about octane req for 4th gens. the LT1 was designed to run 91 octane. you can run a lower octane fuel such as 89 and 87 but it will mess up your hp and your overall fuel economy.
with the reverse flow cooling incorporated on the LT1 engine, it allowed for a higher compression ratio which basically required the use of higher octane fuel to operate at peak efficiency
i run nothing but 93 in mine. gets expensive i know, but i like to run strong. lol
on the odd chance that i stop somewhere that doenst have 93, i keep a bottle or 5 of race only octane boost.
I piss excellence
and fart awesomeness
Old 04-14-2008, 02:21 PM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I've used 91 octane in both my Zs and 87 in my Jetta and 4Runner. I'll run whatever GM says the engines require
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 04-14-2008, 02:25 PM   #14
Bucksbadz
Drives: 02 NBM Z28
92 octane is all mine will ever see, weather its a 4th gen to a 09. Only the best for my baby.
Bucksbadz is offline   Reply With Quote
Tips on pumping gas Sterling General Automotive + Other Cars Discussion 16 03-15-2008 11:14 AM
Gas Guzzler Tax Roflmao Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 02-29-2008 05:29 PM
Gas is 3$ a gallon for good. 28Dennis General Automotive + Other Cars Discussion 35 10-02-2007 12:00 PM
