07-24-2014, 10:05 PM | #1 |
Drives: 2010 2LT Bumblebee Join Date: Apr 2013
IPF + Iceolator = Boost Leak?
I've heard that having an iceolator intake manifold spacer with an IPF setup can lead to boost leak. Do I have to take out my iceolator? I just installed it a month ago and am going to install the IPF next week and would REALLY like to keep the iceolator since I would have only had it for a month and it really did a lot for the car at around 3500 rpms. Is it guaranteed I am going to have problems if I do?
07-24-2014, 10:06 PM | #2 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
I have mine installed and I don't have a boost leak, even have a boost leak tester for it. I did have a leak from the Plenum gasket though.
07-24-2014, 10:09 PM | #3 |
Cool, I was going to get the plenum spacer but backed out since I don't want any extra problems
07-24-2014, 10:24 PM | #4 |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
I think it varies from car to car imo. I asked Andy, and asked his boss and their reply was just take it off.
Not to say to take yours off...just a personal decision..
07-24-2014, 10:57 PM | #5 |
Drives: Supercharged LLT Join Date: Aug 2012
I took my mace 25mm spacer off aswell , Didt wanna risk having a leak.
07-24-2014, 11:04 PM | #6 |
Ya I really would take it off but it took me 3-4 hours to install and I even broke a couple bolts that were a PITA to replace and I have only had a month so unless I completely have to I would rather keep it on. Of course if problems occur after the IPF install the spacer would be the first to go for good measure
07-24-2014, 11:25 PM | #7 | |
KaBoom1701
I think the "P" is getting cut of some how. lol
Mods:
07-24-2014, 11:38 PM | #8 | |
I never even noticed |
07-25-2014, 11:09 AM | #9 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
I think if you are going to run the Ice-olator and the IPF kit, then you should make sure you are running the ICE with a GM gasket on top and on bottom, and get longer than stock bolts.
I don't think I'd chance running the ICE with gasket maker and the stock bolts. Just my opinion.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
07-25-2014, 11:16 AM | #10 |
ya I'm already getting longer bolts because I feel the stock ones aren't threading all the way. do you know the exact specs of those 4 center bolts on the plenum to order?
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
07-25-2014, 11:53 AM | #11 |
I use RTV on the top with an OEM gasket on the bottom with no leaks. But I also make my RTV by clubbing baby seals and using their skin.
07-25-2014, 11:54 AM | #12 | |
I got mine at AutoZone but I'll keep this in mind next time I'm at the zoo
07-25-2014, 02:40 PM | #13 | |
I've raced with and without the spacers on and I don't think there was much of a difference. I will be racing again without them to see how it does though since I have my meth nozzles correct now. |
07-25-2014, 03:14 PM | #14 | |
sounds awesome, interested to find out if there is any change
Thread Tools | |
