| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
![]() Drives: 2010 Camaro SS Join Date: May 2009
MTI Racing 500ci Dominator Engine Assembly
MTI RACING 500ci Dominator Engine Assembly
MTI Racing is PROUD to announce the release of our 500ci Dominator LS Engine. If you want the ULTIMATE in NA power, or are planning on HIGH boost so that 6 bolt heads are necessary, the Aluminum blocked MTI Racing 500ci Dominator is the Power Plant for you. Based around RHS’s all new LS Race Block, Which if full of plenty of cool tricks of its own (Larger in block oil galleys that have been moved outboard for increased crank clearance, Block prefitted with -12 oil feeds, raised CAM location, Works with Gen 3 or Gen 4 CAM and Knock sensors, Billet main caps designed for strength and improved windage, Improved cylinder to cylinder breathing throughout engine). MTI Racing is dedicated to using the highest quality parts we can put together to make a Reliable, HIGH Horsepower monster for your favorite LS Based Vehicle. MTI RACING 500ci Dominator LS7 Based - RHS A357-T6 Aluminum Tall Deck Race Block -4.165” Bore -4.600” Stroke - Callies Forged Dragon Slayer Crankshaft - MTI Racing Custom Forged Pistons - H11 Tool Steel Wristpins - MTI Custom built Ring packages by Total Seal - Clevite Bearings - MTI Racing CNC Ported LS7 Heads -Severe Duty Double Springs - Titanium Retainers -MTI Racing Hardened Spring Seats and Locks - LS7 MLS Severe Duty Head Gaskets - Application Specific Chromoly Pushrods -MTI Racing/Comp Cams Camshaft Ground per Application -MTI Racing/Cloyes Dominator Timing Chain Set -Micro Polished Gears - Timing Chain Damper For added Longevity -MTI Racing Ported LS7 Intake Manifold with Adapter Spacers - MTI Racing Ported LS7 Oil Pump - MTI Racing Extrude Honed Oil Pan - MTI Racing Modified Oil Tank - GM Racing High Performance Lifters - LS7 Crank Damper - ARP Hardware - All Applicable Seals and Gaskets LS7 Options -FOR THE TRACKDAY HERO IN ALL OF US - Color Matched Powder Coated Intake Manifold - Fast LSX Intake Manifold (Available with Custom Porting) - ARE Oil Pan - ARE Dry Sump Tank - MTI Racing Tack Oiling System - Jesel 1.85 Ratio Shaft Rocker Arm Upgrade - Custom Cut Spring Seats for Larger Diameter Valve Springs - PCV Vent Tank - SFI Rated Crank Damper - Super Cool High Capacity Aluminum Radiator Changes for Non LS7 Vehicles - MTI Racing Ported Melling Oil Pump - Oil Pan that Matches Your Specific Vehicle - SFI Rated Underdrive Damper Options for Forced Induction Applications - MTI Racing Custom Tall Deck TVS Kit - 8 or 10 Rib Belt Drive systems - Cog Drive Belt Drive System (For Drag race application only) - 6 Bolt per Cylinder, Cylinder Heads - Gaskets and ARP Hardware for 6 Bolt Applications - Overdrive Dampers Available For LS& and Non LS7 Applications - Custom Sheetmetal Intake Manifolds for Turbo and Procharger Applications - Piston Oil Squirters Options for Race Cars or Your SERIOUS Tackday Car - Straight Runner Fuel Injection - MTI Racing Ported Melling High Volume Oil Pump - MTI Racing Track Oil System - Full Race Ready Dry Sump System (Doesn’t Work With AC) - ARE Oil Pan - ARE Oil Tank - Vent Tank - Razor 2 Stage Scavenge Pump - Custom Oil Lines (Startlite or Steel Braided) - ATI Dry Sump Damper - Piston Oil Squirters - Stage 5 Camshaft - Solid Roller Lifters - Jesel 1.85 Ratio Shaft Rocker Arm Upgrade - Custom Cut Spring Seats for Larger Diameter Valve Springs ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
![]() ![]() ![]() Drives: 1969 LS1 Camaro Join Date: Aug 2009
How much would we have to lighten our pockets to get one of these monsters?
My boredom isn't safe
oh...my...gawd...
![]() Drives: 95 bbb impala ss Join Date: Apr 2009
it looks expensive
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS ADM/LPE 417 with ported heads/inconel vavles gt11 cam ADM ported maggie with 14 rib rear 10 rib front pulleys ADM fuel system and race air intake ADM/LPE ZR1 clutch /pedalreturn spring ADM billet aluminum valve covers /RPM LEVEL 6 TR6060 LPE HD 241mm diff with 3:45 gears HD axles and d/s ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers 683RWHP/650RWTQ ![]() |
#6 |
Thank you all for your interest on our newest motor project.
The price is still being finalized. I will add pictures and hp numbers of the motor when we are done testing cam profiles on our engine dyno. For now I have pictures of the intake manifold spacers needed to work with the taller deck height of the block. Thanks. Chris at MTI Racing. ![]()
#7 |
What kind of HP are you expecting out of these engines?
Lets say with the TVS2300 kit, running 10 rib 3.6 pulley, 6 bolt, and the serious track day mods? - SK
- 2G1FT1EW9A9132212
![]() - Life is hard when destiny believes in you. - As coherent as a pit bull in a spin dryer. A dribbling tartan frothbucket. - Good money, bad girls. How can life be any better? - God saves. The devil invests. - This may be the ultimate guide to problem solving. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: The Imperial Army Join Date: Feb 2009
Very very nice!!
#9 |
We are still in the NA engine testing with different cam profiles as of right now. We will be testing with a supercharger soon. I do not have solid hp numbers at this time but will post them as soon as I get them. As a rough estimate we are looking at around 850-900 hp with a mid level cam. Chris at MTI Racing.
#10 |
just can't seem to leave
holy schneikies!!
#11 | ||||
The Jalopy Jedi
Drives: anything I can get my hands on Join Date: Sep 2006
Spikey Likey!
| Thread Tools | |
| MTI Racing Camaro Shifter Now Available | MTI Racing | V8 Bolt-Ons & Tunes | 2 | 10-12-2009 08:38 AM |
| MTI Racing TVS1900 601rwhp | MTI Racing | Forced Induction - V8 | 36 | 09-01-2009 07:32 PM |
| MTI Racing 500ci Dominator Engine Assembly | MTI Racing | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 08-27-2009 10:59 AM |
| MTI Racing Stage 2 Camaro Dyno VIDEO | MTI Racing | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 07-24-2009 04:11 PM |
