Gen5DIY
Old 07-29-2014, 08:39 PM   #1
Mr Twisty
Mr Twisty's Avatar
Transmission, MM6? or MG9?
Is the transmission the MG9, same as the ZL1? The Chevy media site doesn't show the RPO, but it does have the ratio's matching the MG9. Have any owners checked the codes to make sure which one it is?
-- Benjamin Franklin
Old 07-29-2014, 08:44 PM   #2
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
As far as I knew the trans in the Z/28 is the same trans used in the 1LE (MM6). The ZL1 has a different trans yet.
Nick S is online now   Reply With Quote
Old 07-29-2014, 08:48 PM   #3
ksupkt87
ksupkt87's Avatar
Drives: 2014 Z/28
Just looked at my build sheet and it says MM6 - 6-Speed Manual Transmission and MN6 - Transmission, 6-Speed Manual.
ksupkt87 is offline   Reply With Quote
Old 07-29-2014, 09:55 PM   #4
Mr Twisty
Mr Twisty's Avatar
http://media.chevrolet.com/media/us/...l#transmission
Website shows gearing same as the MG9 in the ZL1... odd
Old 07-30-2014, 10:48 AM   #5
radrace19
Drives: Pontiac G8 GXP
The Z/28 has the MM6 option code transmission with the MG9 gear ratios.
-Greg
1998 Pontiac Grand Prix - 11.24 @ 121
2009.5 G8 GT (Liquid Red)
GXP fascia conversion, GXP diffuser
2009 GXP M6 (MSM) #405 586rwhp/495tq
TVS2300, CTS-V Fuel System, Cam 222/230 116 lsa, Monster Lever 4 Clutch, American Racing 1 7/8 headers, rear Brembo's w/working Parking brake
11.91 @ 119
radrace19 is offline   Reply With Quote
Old 07-30-2014, 11:55 AM   #6
Nick S
Nick S's Avatar
It looks like the only difference gear ratio wise between the MM6 and the MG9 are the overdrive (5th and 6th) gear ratios. Otherwise 1st-4th gears are the same ratios between the two transmissions.
MM6 (1LE)
1st 2.66
2nd 1.78
3rd 1.30
4th 1.00
5th 0.74
6th 0.50
MG9 (ZL1 & Z28)
1st 2.66
2nd 1.78
3rd 1.30
4th 1.00
5th 0.85
6th 0.67
Old 07-30-2014, 05:05 PM   #7
United_727
Parts Guru Extraordinair.
United_727's Avatar
Drives: '02 SS 'Vert M6
Z28's use MM6 . ZL-1's use MG9 . The LS3 also uses a version of the MM6.
Please check out my other hobby ; http://jetphotos.net/showphotos.php?userid=1008
United_727 is offline   Reply With Quote
