HeadlightArmor
Old 07-30-2014, 11:24 AM   #1
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Time to replace hfc need some info
Long story short hfc are failing looking for a test pipe that may look like a hfc any more know of a place.
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 07-30-2014, 11:35 AM   #2
crc91
crc91's Avatar
Drives: '14 1LS
Did you have solo hfc? I hear ARH is suppose to be coming out with some quality hfc I think some one on here will be receiving them with about a week if you can wait that long
crc91 is offline   Reply With Quote
Old 07-30-2014, 11:48 AM   #3
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
I can't say for sure, but I don't know if ARH is doing anything for the LLT engine, you may call them? They have developed both a high flow catted set of pipes, and an uncatted set of pipes for the LFX.
Jason@JacFab is offline   Reply With Quote
Old 07-30-2014, 01:24 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 Summit White 2LT/RS
Gut your current cats. Easiest way to achieve what you're asking.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, VIS Terminator Hood, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I
DSX_Camaro is offline   Reply With Quote
Old 07-30-2014, 01:46 PM   #5
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
This. I did before I added my sc to not have to worry...
Lil' Nasty is offline   Reply With Quote
Old 07-30-2014, 02:50 PM   #6
hunterv6
Always bet on Black
hunterv6's Avatar
No pypes.
Old 07-30-2014, 03:44 PM   #7
hunterv6
Always bet on Black
hunterv6's Avatar
Trying to avoid gutting hfc don't want to increase rasp.
Old 07-30-2014, 05:09 PM   #8
DSX_Camaro
DSX_Camaro's Avatar
I don't think gutting the cats will increase the rasp... But then, gutting the cats and using true test pipes will have the same sound effect, never mind if the test pipes were worse.
Old 07-30-2014, 05:16 PM   #9
sycraft
COTW 5/06/2013
sycraft's Avatar
gutted my SOLO HFC, and it sounds great
Old 07-30-2014, 05:46 PM   #10
hunterv6
Always bet on Black
hunterv6's Avatar
Interesting so let me think a two 2.5 exhaust pipe is the same as a gutted cat? I think that as far as exhaust flow that incorrect statement. The sound may be the same but the flow is a different matter. Instead of using a piece of exhaust pipe I need the impression a that cats are on the car for inspections.
Thank all found it
http://www.siliconeintakes.com/dsm-i...ter-p-331.html
Sent from my iPad using Tapatalk HD
Old 07-30-2014, 05:53 PM   #11
Jason@JacFab
I've seen some pictures of a gutted cat setup in the v8 section once... The guy actually welded the shell of the stock cats to a new exhaust tube, it looked factory, but was straight through. Would probably pass visual, but I doubt it would pass the sniffer test.
Old 07-30-2014, 07:13 PM   #12
DSX_Camaro
DSX_Camaro's Avatar
Thank all found it
Sorry. Don't believe you said flow was an issue.
Old 07-30-2014, 07:23 PM   #13
hunterv6
Always bet on Black
hunterv6's Avatar
Its all good. And I didn't my fault. The more I thought about the effects of the turbo the more I realize that gutting a cat is breaking up the flow of the exhaust.
Old 07-31-2014, 06:16 AM   #14
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
LOL- that Allflow is the prettiest non-cat I've ever seen!
Better grab that while you can- test pipes are frowned upon by you-know-who! Also speaking from experience (OK, it was 30yrs ago...) test pipes don't tend to last long, so plan accordingly.
I've been strongly considering Kooks Green Cats. Any feedback on those particular to the LLT with FI?
