Emblempros
Old 08-01-2014, 01:30 PM   #1
wutshotDJroomba
wutshotDJroomba's Avatar
Drives: 2012 Camaro LS/SC
Ipf after install issue
Not sure if this is common or if I may have been a bit off on my installation, whenever I'm sitting idle, and I turn on the air conditioner the belt squeaks something fierce for a bit then kind of comes and goes. Sometimes it will do it for a bit whenever I'm sitting at a light even without the a/c on. Is this something I should be worried about, anyway to fix the noise? I've had the kit on my car for a little over a month now. Runs fine without issue aside from the occasional stall, but I know that's expected without the proper catch can.
"....Empty your mind, be formless. Shapeless, like water. If you put water into a cup, it becomes the cup. You put water into a bottle and it becomes the bottle. You put it in a teapot, it becomes the teapot. Now, water can flow or it can crash. Be water, my friend.”
-Bruce Lee
wutshotDJroomba is offline   Reply With Quote
Old 08-01-2014, 02:52 PM   #2
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Check the tensioner to make sure the indicator window says there's enough tension. Could be the wrong size belt.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 08-01-2014, 05:25 PM   #3
gutterball
gutterball's Avatar
Drives: 2011 1LS M6 Supercharged
Send a message via AIM to gutterball
With the supercharger, there's a lot of pressure buiilt up, next time it squeals, remove the oil filler cap, if the squeals goes away, you have to much pressure, you can eliminate that by drilling a small hole (5/64) on the side of your oil filler cap.
gutterball is offline   Reply With Quote
Old 08-01-2014, 06:18 PM   #4
wutshotDJroomba
Yea IPF had originally sent me the parts for an LLT. When I received the LFX parts there was a replacement belt, but I will on check that.
-Bruce Lee
Old 08-01-2014, 06:19 PM   #5
wutshotDJroomba
I will try this as well... haha
-Bruce Lee
Old 08-01-2014, 06:21 PM   #6
Nutbutt
Nutbutt's Avatar
LLT Belt 06-1066, LFX Belt 06-1075
Not much difference in size but the LFX is a bigger.
Old 08-04-2014, 04:00 AM   #7
Nawkoutt
Drives: 2lt
I really like the idea of the s/c and I'm only a couple hundred $$ until i have enough for everything.. but I hate that i keep reading about these little problems..
Nawkoutt is offline   Reply With Quote
Old 08-04-2014, 08:37 AM   #8
Nutbutt
Nutbutt's Avatar
I installed at 43k and now have 76k on my IPF. The only issue I had was the idler bearing and that was because a lesser grade bearing was used and has now been fixed by IPF. If you are not modding the system even more you should have no problems. I have had more problem with my vert top than I have had with the super charger.
