| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS - Black - GFX Join Date: Nov 2008
Forced induction by other means
just a thought...
if a supercharger simply raises the air pressure in the intake.... why can't you just plumb up some tubing that goes to the intake from an air (or pure o2) cylinder with a pressure regulator. Then you could add pressure on demand with a valve. seems like a no-brainer, but there must be a reason that noone does it this way. thoughts?
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @115°), LTs, VR CAI, Cutouts |
![]() Drives: 2010 Camaro SS Join Date: Apr 2009
This is not a good idea lol. You cant just add pressurized air into the intake to make more power. Power is made by adding air and fuel. I cant imagine what your ecu will think if it senses a burst in air pressure all of a sudden with no extra fuel to compensate
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, JRE tuned
3000 hp 648 ci beast
Drives: 86 Outlaw 10.5 Camaro, 2SS/RS LS3 Join Date: Jul 2009
that is kind of what nitrous does with a little nitrogen to buffer the mix.
![]() ![]() Drives: 2010 Camaro 2SS/RS, VR, PW, WR Join Date: Jul 2009
Volume/pressure prohibitive if I had to guess.
Work through the math to see just what volumetric flow rate an LS3 has at say 4000rpm. You can then backsolve to determine what volume of tank you would have to have at what pressure in order to supply that flow rate @ say 20 psi (6psi boost) for any amount of time. Not having worked the math, I'd be willing to bet my eng. degree you're looking at either a big tank or one at REALLY high pressure, neither of which is very practical. Now if you just want a few seconds of boost, then that might be feasible.
2010 2SS/RS, M6,VR,White Rally's,Polished Wheels
Mods: skip shift eliminator (hey everybody's gotta start somewhere )crappily painted engine cover... |
#5 | |
Moderator.ca
__________________ Quote: In 2014 the camaro will have ... a twin turbo v6 ... around 350 to 360HP No. Let me repeat that. No. FbodFather __________________ Camaro5 Fest III Information Camaro5 Fest III pre-registration |
#6 | |
PV=nRT (ideal gas law)... (btw, I'm a ChemE)
As "P" increases, "n" increases n = number of air molecules (air is 79% N2 and 21% O2) So, if the reason for a supercharger is to increase the number of oxygen (O2) molecules supplied to the throttle valve... knowing that the PCM uses the O2 sensor to control the amount of fuel added to the chambers (to keep the reaction optimized)... Then adding O2, by any other means, should yield the same result. Quote:
... and even if you cant get to 6psi..... It should still increase the pressure by a very decent amount. I am not going to try it and void my warranty... I was just wondering if anyone else has tried this in the past before spending $7000 on a fancy air compressor... "permanent" air compressor I might add.
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @115°), LTs, VR CAI, Cutouts Last edited by Bell040; 08-14-2009 at 01:46 PM. |
#7 | |
you would add the air (or O2) line before the throttle valve and MAF sensor, but after the air filter... the PCM would compensate... just as it does with ram air or a supercharger and if it doesn't, you would just have to put a second valve on the air line that mimics the throttle valve
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @115°), LTs, VR CAI, Cutouts Last edited by Bell040; 08-14-2009 at 01:48 PM. |
#8 |
Remember that FI is just that. Forced in, with some kind of backpressure that prevents the increased volume of air from flowing back outside the engine.
In an SC or turbo the spinning fan/lobes are this prevention, with a BOV there for the times there can be an overpressure. With a nitrous system, the only pressure is enough to force the nitrous out against atmospheric pressure, the flow of air into the engine does the rest. Oxygen injection systems try to combine this with the FI part. You would (I think) get a small increase in O2 content of the air, similar to running at lower altitude (quite possibly MUCH lower altitude) but not the same kind of boost as in an FI or nitrous system. Exceptions to this occur when the 'natural' air pressure is already much higher than normal. RAMJET and SCRAMJET systems where you are either feeding LOX or O2 and there is a HUGE pressure differential from the front (intake) to the turbines or combustion chamber. I think it would be a simple and interesting experiment to hook an O2 bottle up to the air intake on a basic EFI engine at high altitude and see what the before and after numbers are. - SK
- 2G1FT1EW9A9132212
![]() - Life is hard when destiny believes in you. - As coherent as a pit bull in a spin dryer. A dribbling tartan frothbucket. - Good money, bad girls. How can life be any better? - God saves. The devil invests. - This may be the ultimate guide to problem solving. |
#9 | |
![]() Yeah, now that I think about it, you're probably only talking 350-400 cfm @ 4000. I've been dealing with turbines and their huge mass/volume flow rates I'm out of practice swagging recips.
#10 | ||
Original Bumblebee Owner
Drives: 265hp ZX-14, 500hp Silverado, V-ROD Join Date: Apr 2009
How about ditching the intake system entirely and doing a variation of a Directly Injected Engine that also directly injects high-pressure air into the cylinders along with the fuel?
Use the engery that was required to run the intake valves and instead, use that energy to run a very large air compressor? Move this to Half-Bakery.com?
#11 |
As long as we're talking unorthodox ideas, how about a hybrid recip/gas turbine system.
Basically add a turbocharger with a modified install to the recip. The compressor output would be split between the recip intake and the turbine intake. In between the compressor and the turbine would be a small combustor with a fuel injector. Using some sort of solenoid actuated valve setup, your recip exhaust would go to the turbine until it got spooled up, at which point you would ignite the combustor and re-direct the recip exhaust to somewhere else. At that point the turbocharger is a self sustaining gas turbine engine, providing a continuous boost to the recip. Completely and utterly impractical but it would be cool to say "MY Camaro has a turbine in it."
#12 |
![]() Drives: 2013 Camaro ZL1 Black Join Date: Jun 2009
Using compressed air would work...but two major issues. One is flow. The CFM needed would require some major piping sizes. 2nd would be capacity the volume of air would require some major tanks. NOS is a liquid and the amount of oxygen per volume is a bunch higher than straight air. So there is no real advantage to use bottled compressed air. For compressed air use a infinite air bottle AKA supercharger or turbo.
As for liquid O2. The germans tried it in WW2. If you attempted it please record the attempt because the resulting explosion would be awesome.
2013 ZL1 BLACK on BLACK
Roto-Fab CAI 2010 2SS/RS BLACK on BLACK <SOLD> 3" MBRP 304 Stainless Exhaust Roto-Fab CAI |
#13 | |
Ordered: 10-13-08
#14 | |
But yea... if the pressure was increased to >14.7 psia, then I can see how reverse flow would be a problem. also, could you explain the nitrous part a little better? I am not familiar with nitrous at all. Are you saying that the pressure is not increased in a nitrous system? ... just the combustion chemistry?
Ordered: 10-13-08
#15 |
#16 | ||||
The Jalopy Jedi
Drives: anything I can get my hands on Join Date: Sep 2006
#17 |
![]() Drives: Nissan Altima SE-R Join Date: Sep 2008
I've thought about this for a while, and I dont mean to sound like an idiot, so i thought id speak my idea...how about a supercharger cranked by a belt attached to an electric motor that can be recharged via electric outlet? It doesnt have to use the belt run by the engine nor is there any turbo lag concerning turbos...I dunno...idea? lol
#18 | |||||
The Jalopy Jedi
the problem then is getting an electric motor capable of powering the s/c without having to go to an industrial sized motor. plus you have to look at charging the power source for the motor properly which would mean a bigger/more powerful alternator. then you would have to tune the electric motor to spin the s/c at the proper speed relative to engine rpm.
#19 | |
#20 | |||||
The Jalopy Jedi
but what do you do when the battery dies when you are on the road?
#21 |
![]() Drives: Fast ones Join Date: Jul 2009
Shop-Vac in reverse into the intake tube is the way to go.
#22 |
#23 |
Moderator.ca
Not that I know of. Oxygen injection would work, the problem is storage. Its easier to cram the same amount of oxygen into a bottle of nitrous than it is to use pure oxygen. Probably cheaper too.
#24 | ||
Here is a demonstration of what liquid O2 can do. Look what it did to a grill 1 minute into the video. That was in a non sealed environment. The grill (steel not aluminum) was completely melted. Like I said anyone that care to attempt this... 1) Please do it on a Mustang not a Camaro. ![]() 2) Please please record it as the result devastation will be awesome.
#25 |
Moderator.ca
Obviously oxygen has more oxygen, pound per pound, than nitrous does. But oxygen has a significantly lower boiling point than pure oxygen which makes it much more difficult to store in any reasonably amounts. But I was screwing one thing up ... I had it in my head that nitrous oxide was N02, not N20. That changes things quite a bit.
| Thread Tools | |
| ENGINE & FORCED INDUCTION | Milk 1027 | Wiki | 1 | 08-06-2012 11:48 PM |
| Forced Induction on a DI 3.6L V6 | 09CobaltSS/Turbo | Forced Induction - V6 | 47 | 01-17-2010 10:08 AM |
| All this talk about forced induction got me thinking... | TheClassicCarKid | Forced Induction - V8 | 23 | 07-20-2009 07:44 AM |
| Forced Induction | Stamm316 | 4th Generation Camaros | 4 | 04-13-2008 07:47 PM |
