JDP Motorsports
Old 08-06-2014, 07:31 AM   #1
Z/28Dan
Z/28Dan's Avatar
Drives: 2015 Red Hot Z/28
Brake fluid replacement
Forgive me Forum Police, but I've tried search...
I am going to replace my DOT3 with DOT4 in my ZL1.
How much fluid should I need to buy <initially> to make this fluid exchange?
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan
Z/28Dan is offline   Reply With Quote
Old 08-06-2014, 07:42 AM   #2
sycraft
COTW 5/06/2013
sycraft's Avatar
2-3 of these... should have the ABS pump bled too to get out all the DOT3, this requires a tech 2 or special tool to complete properly
Old 08-06-2014, 09:03 AM   #3
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Drives: 2SS/RS - IBM LS3 M6
How much fluid is in the ABS pump? Would there be a problem if the two were mixed, ie. if the pump is not purged before adding dot 4?
gr8daneh is offline   Reply With Quote
Old 08-06-2014, 09:07 AM   #4
sycraft
COTW 5/06/2013
sycraft's Avatar
They can mix. I would have 4 on hand
Sent from my SPH-L720 using Tapatalk
Old 08-06-2014, 11:10 AM   #5
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I had my dealer do a full dot4 bleed and ABS purge for $80 after i upgraded to SS brembos.
Mods:
Old 08-06-2014, 12:13 PM   #6
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
We use and recommend the Motul RBF600. You'll need 3 pints to complete the job.
The fluid can be mixed. The Motul is compatible with DOT3 fluids. Also, a cheap way to flush the ABS is to go activate the ABS on a wet or gravel road, then give them another short bleed.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 08-06-2014, 12:23 PM   #7
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Best regards,
Tyler
888-308-6007
Thanks T
Old 08-06-2014, 12:31 PM   #8
BLTZKRG
Drives: 2014 Camaro SS
Ive used ATE Blue in the past....how does this compare to the Motul and what other options are there?
2014 Ashen Gray Metallic 2SS/RS M6
CAGS Skip-Shift Eliminator
1LE Strut Tower Brace
GMPP Track Pack Axleback
Halltech CAI
Fuse Pull Mod
BLTZKRG is offline   Reply With Quote
Old 08-06-2014, 03:54 PM   #9
sycraft
COTW 5/06/2013
sycraft's Avatar
ATE Blue is no longer legal in the states.... It is a great fluid. RBF600 is much more readily available
Old 08-06-2014, 04:57 PM   #10
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
We need to find someone overseas that is willing to ship us ATE super blue. I really liked being able to alternate colors, makes bleeding the system easy.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 08-06-2014, 07:09 PM   #11
tw78911sc
tw78911sc's Avatar
Drives: 14 1SS Camaro 1LE, NPP, Recaros
http://www.amazon.com/ATE-706202-Ori.../dp/B003VXRPL0
They used to make the same fluid in yellow as well, then you could really tell when new fluid was there. All euro cars use this in my experience. I like the Motul as well, easier to find.
tw78911sc is offline   Reply With Quote
Old 08-06-2014, 08:42 PM   #12
giant_g2
giant_g2's Avatar
Drives: '13 1LE, '89 Caprice
ATE Type 200 is the yellow version and you can still get it. The blue is outlawed because it isn't yellow/clear. You can get a liter for $20. I think the Motul has a higher boiling point by about 60 degrees.
giant_g2 is offline   Reply With Quote
Old 08-06-2014, 11:29 PM   #13
intensifi
Drives: '12 2LT Convertible
Castrol SRF
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 08-07-2014, 10:54 AM   #14
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
ABS Bleed at Shop $80
ABS Bleed on a Gravel Road $2,600 at the paint shop.
ABS Bleed on isolated wet roads PRICELESS
