BeckyD @ James Martin Chevy
Old 08-10-2014, 12:00 PM   #1
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
brake fluid in Z28
What brake fluid comes in the Z28? Since it is built for the road course is it a very high dry boiling point racing fluid like people say you need to put in the ZL1 if you do HPDE events.
tnspd is offline   Reply With Quote
Old 08-10-2014, 12:18 PM   #2
Synner
Drives: not stock
No its crap like every other camaro and needs to be swapped.
Old 08-10-2014, 12:33 PM   #3
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
Any car going to the track.... get yourself some best of the best Dot 4. Not cheap dot 4. It will be around $20 a 500 mil bottle or more or it's junk.
I had great luck with Motul RBF 600 Dot 4.
Old 08-10-2014, 12:36 PM   #4
tnspd
tnspd's Avatar
So you think GM puts different fluid in the cars when they go make runs at the RING?
Old 08-10-2014, 12:51 PM   #5
Synner
Drives: not stock
It says right in the manual to swap it for tracking.
Old 08-10-2014, 01:14 PM   #6
tnspd
tnspd's Avatar
Page number?
Sent from my SPH-L710 using Tapatalk
Old 08-10-2014, 01:33 PM   #7
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
page 3 of the pdf “Z:28 OM Sections.pdf” here http://www.camaro5.com/forums/showthread.php?t=323419
"PTM11" Search & Destroy
backtotintops is offline   Reply With Quote
Old 08-11-2014, 02:51 PM   #8
Russell James
There is a number of things to track prep a car. Anybody buying the car for actual race track use will know how to track prep a car, and will have the instructions in the owner's manual.
The manual gives you a list of stuff to do... change the alignment to race spec align, bed the brake pads, change the brake fluid to a spec boiling pt or above fluid, change the diff fluid, reduce coolant to 30% (70% water), remove under hood deflector...
You're not going to take the car off the showroof and go set record laps on a race track without going through race prep... before every event.
It would be interesting to know the percent buying the car that are actually going to track it. If it is not going to be tracked, I'd guess a pretty high percent.... the way it came is perfect. 50% coolant, DOT 3, street alignment..... all stuff you want for street driving and the Sunday show and shine.
DOT 3 is more forgiving for street use. Absorbs moisture. Forget about it for many years. Any tiny amount of moisture that gets in over the years is absorbed.
Racing brake fluid is resistant to absorbing moisture. It is also changed often as part of track prep.
Kind of like racing oil vs SAE oil. Racing oil has huge amounts of zinc/phos anti wear additives and no detergents. SAE oil has huge amounts of detergents for long change intervals, environment... One could argue..... how come it didn't come with racing oil.
Some thing, those that will be racing it, will know how to race prep it.
DOT 3 and DOT 4 both have their intended uses. Pros and Cons to both.
