Emblempros
Old 08-11-2014, 08:50 AM   #1
hcsi99
Cadillac Service Manager
hcsi99's Avatar
Drives: 2014 Camaro 1SS, 1LE, NPP, RECAROS
Question about CTS-V 6 Piston Caliper Swap
I'm looking to upgrade my front calipers on my 14 SS 1LE to the CTS-V 6 piston calipers. I've seen a number of swaps on here, and I know there is a company that sells a kit as well. I've figured that I can put the kit together myself for less money. I've found raw calipers on rock auto for $150.00 each. I plan on powder coating the calipers red to match the rear caliper, so getting them in raw form seems to be a good idea. My question is has anyone else used theses A-1 Cardone Calipers?
hcsi99 is offline   Reply With Quote
Old 08-11-2014, 09:23 AM   #2
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
Never seen a thread about these or anyone use them. If they are real brembo's it will be stamped brembo and made in Italy. Although I am sure there are fakes out there.
I got mine from amazon, if I knew about these I probably would of given these a shot.
CHMSC is offline   Reply With Quote
Old 08-11-2014, 09:46 AM   #3
hcsi99
hcsi99's Avatar
The description says they are a rebuilt factory Brembo.
Old 08-11-2014, 11:57 AM   #4
BLTZKRG
Drives: 2014 Camaro SS
Interesting. Subscribing...looking to do same upgrade on the cheap....is there a rock solid parts list anywhere on here?
2014 Ashen Gray Metallic 2SS/RS M6
CAGS Skip-Shift Eliminator
1LE Strut Tower Brace
GMPP Track Pack Axleback
Halltech CAI
Fuse Pull Mod
BLTZKRG is offline   Reply With Quote
Old 08-11-2014, 12:00 PM   #5
hcsi99
hcsi99's Avatar
As far as I know it's calipers, rotors, pads, CTSV brake lines, am I missing something?
Old 08-11-2014, 12:54 PM   #6
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Pin kit, caliper bolts, brake fluid.
Everything you need to know can be found here.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 08-11-2014, 01:38 PM   #7
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
make sure you can find the crossover tube and bleeder valves.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 08-11-2014, 02:03 PM   #8
hcsi99
hcsi99's Avatar
That's a good point about the crossover tube. I can't tell if it comes with it or not. I have sent an email to Cardone tech support.
Old 08-11-2014, 03:49 PM   #9
soup070
soup070's Avatar
Drives: Pontiac G8 GT
Auto Zone, Oriellys, and other auto part suppliers have the same rebuilt caliper. However they are an exchange only, you send yoursm rebuild them, and then send them back for that price-a little high for that. I got mine from Amazon you can find all three (red, yellow, silver) sets for half oem price - just be sure to use the AcDelco part number.
soup070 is offline   Reply With Quote
Old 08-11-2014, 03:50 PM   #10
hcsi99
hcsi99's Avatar
Rock Auto gives a price with and without the core. They are $150 each without the core.
Old 08-12-2014, 03:52 AM   #11
cabbe
Drives: 2014 2ss 1le
What's the part #?
cabbe is offline   Reply With Quote
Old 08-12-2014, 05:53 AM   #12
Synner
Drives: not stock
They typically have crappy and cheap aftermarket seals and pistons and they last a lot shorter time span than original. I've never had great luck with parts store calipers for those reasons. For the minimal price difference I would buy new every time in this application.
Synner is online now   Reply With Quote
Old 08-12-2014, 05:54 AM   #13
hcsi99
hcsi99's Avatar
That's good to know. Thank you.
Old 08-12-2014, 07:57 AM   #14
hcsi99
hcsi99's Avatar
Originally Posted by cabbe View Post
What's the part #?
The part # from Rock Auto is 185200, and I did hear back from Cardone, they do not come with the cross over tube. I also found out that I can not get that crossover tube as from Cadillac, it's only comes with the caliper.
