Old 08-12-2014, 11:57 AM   #15
cabbe
Drives: 2014 2ss 1le
So it's a total no go then?
cabbe is offline   Reply With Quote
Old 08-12-2014, 11:58 AM   #16
td195f
td195f's Avatar
Drives: 2015 Z/28 #786
Originally Posted by hcsi99 View Post
I'm looking to upgrade my front calipers on my 14 SS 1LE to the CTS-V 6 piston calipers. I've seen a number of swaps on here, and I know there is a company that sells a kit as well. I've figured that I can put the kit together myself for less money. I've found raw calipers on rock auto for $150.00 each. I plan on powder coating the calipers red to match the rear caliper, so getting them in raw form seems to be a good idea. My question is has anyone else used theses A-1 Cardone Calipers?
Are you sure they have stock on these? When I was researching this mod earlier this year, there was no stock available.
I bought yellow calipers from Amazon for about $250 each and bead blasted and repainted.
2015 Z/28 #786 - Black
2004 Silverado 3500 Dually - D'Max - Suncoast - Banks - Edge - Custom Tune by D'Max Tuner / Spitzer '32 Bantam Altered Drag Car - Blown Alcohol 380 CI Small Block Chevy
td195f is offline   Reply With Quote
Old 08-12-2014, 12:18 PM   #17
hcsi99
Cadillac Service Manager
hcsi99's Avatar
Drives: 2014 Camaro 1SS, 1LE, NPP, RECAROS
It's looking like I'll be getting the Yellow calipers and have them redone in red. Those look great by the way!
hcsi99 is offline   Reply With Quote
Old 08-12-2014, 12:21 PM   #18
hcsi99
hcsi99's Avatar
td195f, What rotors are you using? DBA 4000?
Old 08-12-2014, 01:40 PM   #19
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
Where did you get the Chevrolet/Brembo decal? Sizes?
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 08-12-2014, 01:43 PM   #20
White_SS/RS
Drives: 14 1LE
I found all my CTS-V stuff on amazon. about 230 for each caliper, 250 for each ZL1 rotor, pads 150 and pins for 20. had them powder coated red.
LMS Engineering
Old 08-12-2014, 07:29 PM   #21
BLTZKRG
Drives: 2014 Camaro SS
So we are looking roughly $1200 all said and done...pretty darn cheap.
2014 Ashen Gray Metallic 2SS/RS M6
CAGS Skip-Shift Eliminator
1LE Strut Tower Brace
GMPP Track Pack Axleback
Halltech CAI
Fuse Pull Mod
BLTZKRG is offline   Reply With Quote
Old 08-12-2014, 09:51 PM   #22
td195f
td195f's Avatar
They are StopTech slotted cryogenically treated rotors for the CTS-V from Tire Rack
Old 08-12-2014, 09:55 PM   #23
td195f
td195f's Avatar
E-Bay. I don't remember now who was selling them, but it's a regular company. A set comes with two each of three different sizes of Chevrolet and Brembo. Search the C5 threads for painting these calipers, that's how I found out about them.
Old 08-12-2014, 10:17 PM   #24
umiami2312
Drives: 2013 2SS/1LE Blue Ray Metallic
When you get stainless steel lines, make sure you get the ZL1 kit and not the CTS-V kit. The rears won't fit if you get the CTS-V kit.
I found my calipers on ebay, rotors on brakerotorshop.com, lines/pads from tire rack. Sent the calipers to Mike the powdercoater and they look great.
The link to my upgrade:
http://www.camaro5.com/forums/showthread.php?t=352955
umiami2312 is offline   Reply With Quote
Old 08-13-2014, 12:58 AM   #25
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I'm sorry but the brakes are not where you should go cheap for a mod. Especially if you drive hard or go to the track.
Mods:
Old 08-13-2014, 07:07 AM   #26
hcsi99
hcsi99's Avatar
I agree. All of my questions have been answered and I will not be going with the raw caliper.
Old 08-13-2014, 07:29 PM   #27
td195f
td195f's Avatar
Do you understand that what we're talking about here are the same brake calipers that are on the ZL1?
I track my 1LE and switching to the 6 piston CTS-V calipers and with the stock Brembo pads I pulled my braking points in 200' at some places at Watkins Glen. Next time out I'll have Carbotech XP10s and XP8s.
This is not going cheap. This is just a very economical mod to get a great set of brakes.
Old 08-14-2014, 07:55 AM   #28
hcsi99
hcsi99's Avatar
I think he's referring to the rebuilt calipers I was asking about not the idea of the CTSV swap.
