BORLA
Old 08-11-2014, 10:21 AM   #1
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
BRAKE PRESSURE SENSOR?
http://www.camaro5.com/forums/showthread.php?t=372719
"PTM11" Search & Destroy
backtotintops is offline   Reply With Quote
Old 08-11-2014, 11:58 AM   #2
McRat
McRat's Avatar
Drives: 2010 ZR1 "Satan"
Are you referring to the hyd pressure, or the pedal pressure?
The fuel rail pressure sensor on Duramax diesel engines will read 0 to 30,000 psi.
And they make gauges that read it directly without using the ECM data, or if you have a datalogger that take external sensor output, you can read it that way. Like ISSOPRO, etc.
2002 Z06 "Blue Meanie" 11.36 ET
2003 Z06 in progress
2009 CTS-V "Spooky" 12.36 ET, bone stock at 1600 mi. Rainy day in Sacramento. Sadness.
2010 ZR1 "Satan" no times yet.
2013 Volt SCCA Solo2 #771 HS3.
And a bunch of Duramaxes.
McRat is offline   Reply With Quote
Old 08-11-2014, 12:27 PM   #3
backtotintops
Drives: 14 Z/28 0#
hydraulic. Traqmate has additional inputs that work with the analog 0-5v pulse of various AIM and AEM sensors. Just trying to find one that would work easily in the z.
