Old 08-11-2014, 05:24 PM   #1
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
coolant mix?
I'm going with a 30 coolant to 70 distilled water mix and 1 bottle of Water wetter. I bet I'm down 20 degrees.
Anyone suggest a better coolant than oem?
After reading posts on here just removing the rain guard is good for 20 degrees.
...or maybe this http://goo.gl/npUUNi
"PTM11" Search & Destroy
backtotintops is offline   Reply With Quote
Old 08-11-2014, 05:34 PM   #2
zcarczar
Drives: 14 Z/28
I'm interested in this too, my car was getting HOT last weekend at the track. I did drain out some coolant and replace it with water but it didn't make much difference. The rain guard is off on mine and I was hitting 250 coming off the big front straight into turns 1 and 2 on the speedway.
I know in my off road car(700 HP 418 LS3) I run just a gallon of dexcool, water wetter and the rest water and the engine stays perfectly fine at 210-215 when racing it hard. I'm going to give that a shot next, if that doesn't work then I will look into a bigger radiator.
One thing I do know is that a big engine oil cooler will help reduce the engine temp on these engines as well. I saw the factory has a massive one up front, I wonder if there is a way to move it into a secondary air source away from the radiator with its own fan?
zcarczar is offline   Reply With Quote
