Old 08-13-2014, 12:19 PM   #1
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Timing Bushings
Hey Guys,
I am having trouble finding an alignment shop that will time my bushings, or that even knows what it means. Is there a different term/terminology I should use? Also I have the below that I found in this section:
Step 1. Lift the car on a two post lift and raise it.
Step 2. Loosen the following bolts/nuts:
Front:
---Inner Control Arm Bushing
---Inner Radius Rod
Rear:
---Trailing Arm Bushings (both ends)
---Toe Rod Bushings (both ends)
---Lower Control Arm Bushings (Inner)
---Upper Control Arm Bushings (Rearward)
---Lower Strut Bushings
Step 3.
Lower the car and drive it around the parking lot SLOWLY and on to the alignment lift.
Step 4.
With the weight of the car on the wheels tighten all of the nuts/bolts to spec.
Step 5.
Align the car at the new ride height.
Is this what needs to be done for a basic lowering spring install bushing/alignment? Can anybody send me pics of the suspension for the 2013 that shows the bolts/bushings that need to be timed? Thanks a lot for any help guys!!
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 08-13-2014, 12:44 PM   #2
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Here's a good thread BMR put together a few years ago:
http://www.camaro5.com/forums/showthread.php?t=153188
On the 1LE, don't worry about the toe rods as they have spherical bearings in them. Also, if you have any aftermarket bushings in any of those arms, they do not need to be timed as the inner ferrule should spin freely within the bushing.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 08-13-2014, 12:56 PM   #3
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Thanks Tyler, you are always so helpful!
Old 08-13-2014, 01:06 PM   #4
JDP Sales
JDP Sales's Avatar
Anytime, my friend!
Best regards,
Tyler
888-308-6007
Old 11-24-2014, 06:50 PM   #5
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
Here's a question... Apologize if I'm thread jacking. What if you've installed your bushings a while (beginning of summer) back would it make sense to time your bushing at this late in game? Curious?
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
Old 11-24-2014, 07:09 PM   #6
JDP Sales
JDP Sales's Avatar
Aftermarket bushings have a ferrule that spins freely within them and do not need to be indexed. It's only the factory bushings that are bonded together. But yes, it would still be worth it to time factory bushings after lowering even a few months down the road.
Best regards,
Tyler
888-308-6007
Old 11-24-2014, 07:10 PM   #7
ActNup NY
ActNup NY's Avatar
Thxs Ty
