Haddad Motorsports
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 10-12-2011, 11:47 AM   #251
PQ
Drives a Maro
PQ's Avatar
Drives: Hybrid SS Camaro
Ok. Fine......
What total outside diameter is are those tires?
Stock diameter?
How tall would a 305/30 R20 be?
305/35 R20 is stock height and outside diameter.
Old 10-12-2011, 11:53 AM   #252
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
Drives: #22 Tom Henry Racing 2010 2SS/RS
Ok. Fine......
Stock diameter?
seriously bro...
Originally Posted by Nine Ball View Post
I will list tire sizes that are similar to OEM diameter, as this should help tire shoppers. The heights shown below are approximate, based on calculations. Refer to tire manufacturer's specs for the most accurate tire diameters. We recommend you stay within 0.5" (plus or minus) of the factory tire height in order to maintain accurate vehicle systems. This gives you an acceptable range of 28.2-29.3" diameters. Wheel widths shown are recommended, and only serve as a suggestion for proper fitment/appearance/performance.
Factory 2010 Camaro SS tires and wheels
Front 245/45-20 = 28.7" tall, 8.0 wheel
Rear 275/40-20 = 28.7" tall, 9.0 wheel
Recommended 18" Tires for 2010 Camaro
245/55-18 = 28.6" tall, 8.0-8.5 wheel
255/55-18 = 29.0" tall, 8.0-8.5 wheel
265/50-18 = 28.4" tall, 8.5-9.0 wheel
275/50-18 = 28.8" tall, 9.0-9.5 wheel
285/45-18 = 28.1" tall, 9.5-10.0 wheel
295/45-18 = 28.5" tall, 10.0-10.5 wheel
305/45-18 = 28.8" tall, 10.0-11.0 wheel
315/45-18 = 29.2" tall, 10.5-11.0 wheel
Recommended 19" Tires for 2010 Camaro
245/50-19 = 28.7" tall, 8.0-8.5 wheel
255/50-19 = 29.0" tall, 8.0-8.5 wheel
265/45-19 = 28.4" tall, 8.5-9.0 wheel
275/45-19 = 28.7" tall, 9.0-9.5 wheel
285/45-19 = 29.1" tall, 9.5-10.0 wheel
295/40-19 = 28.3" tall, 10.0-10.5 wheel
305/40-19 = 28.6" tall, 10.0-10.5 wheel
315/40-19 = 29.0" tall, 10.5-11.0 wheel
Recommended 20" tires for 2010 Camaro
245/45-20 = 28.7" tall, 8.0-8.5 wheel
255/45-20 = 29.0" tall, 8.0-8.5 wheel
265/40-20 = 28.4" tall, 8.5-9.0 wheel
275/40-20 = 28.7" tall, 9.0-9.5 wheel
285/40-20 = 28.9" tall, 9.0-10.0 wheel
295/35-20 = 28.1" tall, 9.5-10.5 wheel
305/35-20 = 28.4" tall, 10.0-10.5 wheel
315/35-20 = 28.7" tall, 10.5-11.0 wheel
Recommended 21" tires for 2010 Camaro
245/40-21 = 28.7" tall, 8.0-8.5 wheel
255/40-21 = 29.0" tall, 8.0-8.5 wheel
265/35-21 = 28.3" tall, 8.5-9.0 wheel
275/35-21 = 28.6" tall, 9.0-9.5 wheel
285/35-21 = 28.9" tall, 9.5-10.0 wheel
295/35-21 = 29.1" tall, 10.0-10.5 wheel
305/30-21 = 28.2" tall, 10.0-11.0 wheel
315/30-21 = 28.4" tall, 10.5-11.0 wheel
Recommended 22" tires for 2010 Camaro
245/35-22 = 28.8" tall, 8.0-8.5 wheel
255/35-22 = 29.0" tall, 8.0-8.5 wheel
265/30-22 = 28.3" tall, 8.5-9.0 wheel
275/30-22 = 28.5" tall, 9.0-9.5 wheel
285/30-22 = 28.8" tall, 9.5-10.0 wheel
295/30-22 = 28.9" tall, 9.5-10.5 wheel
305/30-22 = 29.2" tall, 10.0-11.0 wheel
315/25-22 = 28.2" tall, 10.5-11.0 wheel
Recommended 24" tires for 2010 Camaro
245/25-24 = 28.8" tall, 8.0-8.5 wheel
255/25-24 = 29.0" tall, 8.0-8.5 wheel
265/20-24 = 28.2" tall, 8.5-9.0 wheel
275/20-24 = 28.3" tall, 9.0-9.5 wheel
285/20-24 = 28.5" tall, 9.5-10.0 wheel
295/20-24 = 28.7" tall, 10.0-10.5 wheel
305/20-24 = 28.8" tall, 10.0-10.5 wheel
315/20-24 = 29.0 tall, 10.5-11.0 wheel
Hope that helps!
Tony
Don't worry I'll search the boards for you...
Old 10-12-2011, 11:59 AM   #253
PQ
Drives a Maro
PQ's Avatar
seriously bro...
Hey.....
I edited my last post........ jerk......
And the point is made. Smaller sidewall.
Stitch is running 25% sidewall.
Stock height on 305s would be 35%
Old 10-12-2011, 02:49 PM   #254
Stitch
Stitch's Avatar
Drives: SS, CTS & SRT-4
I believe the overall tire/wheel combo had a diameter of about 26.5", but I'd have to check my notes to make sure, and they're kinda far away...
I choose that tire size because it was the closest in overall diameter to the diameter of the Pedders car's tire/wheel combo, that way, I'd know there wouldn't be any clearance issues.
...and it's probably not wise to refer to one of most knowledgeable moderators on here as "jerk". Let's try to keep Pete's threads clean and informative.
Stitch is offline   Reply With Quote
Old 10-12-2011, 04:48 PM   #255
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
Thanks for the back up Stitch... But PQ and I have history.
Old 10-13-2011, 12:42 PM   #256
JusticePete
Needs Lowering
JusticePete's Avatar
Drives: Pedders USA Camaro Justice
Hee hee hee...
Old 10-13-2011, 12:53 PM   #257
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
Hee hee hee...
LMAO!
295/35 20X10 right?
Old 10-13-2011, 01:06 PM   #258
PQ
Drives a Maro
PQ's Avatar
As far as informative goes, I may have rehashed some things but it did bump the thread and I did learn something and we did learn why you chose the tire sizes you have.
I wondered why you chose such thin sidewalls. Now I know.
Let's extend classtime a little here.......
Pete? I have about the same sidewall as stitch does. Problem for me is (other than needing to lose the donk wheels all together) I have NO traction due to thin sidewalls.
Why are thin sidewalls ok on smaller rims? Why is there not as much traction loss?
And future in wheel purchase......
Old 10-13-2011, 03:04 PM   #259
JusticePete
Needs Lowering
LMAO!
295/35 20X10 right?
Yes sir!
Old 10-13-2011, 04:16 PM   #260
JusticePete
Needs Lowering
We choose the tire and wheel size in large part based on the availability of the RE-11 Bridgestones. IMO, they are hands down the best combination of a street / track tire. Weight plays a role as well. The smaller OD worked for us as well effectively creating a rear gear change.
On the new 'Pedders' Camaro we are running 20x10.5 with Michelin 305/35ZR20/XL Pilot Sport PS2s. I poked around looking for an illustration of tire sidewall flex and found this Tire Sidewall Flex Animation Too much tire side wall flex causes instability. Too little side wall flex causes a loss of traction. If the tire can't roll the sidewalls, then the contact patch slips.
What is the perfect tire size? The new ZR1 has Michelin Pilot Sport 2 tires P285/30ZR19 in front and P335/25ZR20 in the rear. The rear rim is a 20x12 the front is 19x10. In these low aspect ratios the tire itself is mission critical. For the ZR1 Chevrolet worked with Michelin to create a Pilot Sport with characteristics for optimum performance. In a practical sense, a taller side wall will protect the rims from impact damage i.e. the unexpected major pot hole. On the drag strip tall side walls that wrinkle are desirable.
The Bridgestone Potenza S001 - 305/25R20 that Stich selected carry a dry performance rating of 8 from the MFG. The RE-11s have a MFG dry performance rating of 10. The S001 wet performance rating is a 9 compared the RE-11 with a 7. The Bridgestone S001 is a good choice, unless you are looking to max out a lap time and prove a point. Nitto NT 05s are very good, but are not available in a 305. Selecting the tire size for your Camaro is a balancing act between tire weight, revs per mile, stiction, brakes and RWHP. If you would like to stay between the lines on a rainy day wet performance could be important too Especially with a 305 up front.
If I have my choice, the Bridgestone RE-11 305/19/30s are on my Camaro, unless some dumb-axx rule prohibits their use because they are too good. Then we go to Michelin Pilot Sport PS2.
Did I just
Old 10-13-2011, 04:27 PM   #261
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
wait wut??? dumb ass rule????
Old 10-13-2011, 05:03 PM   #262
PQ
Drives a Maro
PQ's Avatar
So my 22s are not your first choice then. Got it.
Old 10-13-2011, 10:30 PM   #263
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
damn those rules,
Rob Anderson - Business Development
rob@peddersusa.com
Info@PeddersUSA.com is offline   Reply With Quote
Old 10-14-2011, 05:45 PM   #264
JusticePete
Needs Lowering
Originally Posted by Info@PeddersUSA.com View Post
damn those rules,
Those would be the OPTIMA Challenge
Lingenfelter L/28 Camaro
We wanted this to be a full amenity daily driver with a bad attitude on a road course. We think we have it covered from the normally aspirated N/A LS7 to the Pedders Supercars and everything in between.
• LPE LS7 Engine, 681HP @ 6700 RPM / 588 LB/FT @5600
• LPE Dry Sump Oiling System
• Tremec 6060 6 Speed Manual Transmission
• LPE Dual Disc Clutch and Flywheel
• LPE Clutch Return Spring Kit
• MTI Short Throw Shifter
• LPE Leather Shift Knob
• LPE 9.5” Differential, 373 Ratio with no preload TracRiteŪ GT – Helical Gear Limited Slip
• Driveshaft Shop HD 1400HP Axle Shafts
• LPE HD 2 Piece Driveshaft
• LPE Twin Fuel Pump Module with Electronic Control
• LPE Power Steering Cooler
• Be Cool Radiator
• American Racing Headers
• Custom Side Exit Exhaust with Magnaflow Mufflers
• LPE / Pedders SportsRyder Supercar Coil-over Suspension System, Sway Bars, Complete Bushing Package
• Brembo Brake System. Front 15” 2 Piece Rotor with 6 Piston Caliper, Rear 14” 2 Piece Rotor with 4 Piston caliper
• Forgeline Wheels, 20”X10.5”
• Michelin Tires, 305/35ZR20
• Lingenfelter Signature Body Kit, including front splitter, side skirts, rear diffuser, and rear spoiler
• Specter Werkes Extractor Hood
• Lingenfelter L/28 Graphics
• RPM Six Point Roll Bar
• Corbeau TRS Leather Seats and 5 Point Belts
• Lingenfelter CNC Pedal Pads
How good is the L/28. We'll all know very soon.
Optima Announces Second Half of The Ultimate Street Car Invitational Competitors
Optima’s Ultimate Street Car Invitational pits all types of Pro-Touring cars, trucks, and hot rods against each other in autocross, road rally, braking, and hot lap competitions. This is the event’s fourth consecutive running and as usual, it will take place in Pahrump, Nevada at the Spring Mountain Motor Ranch following the SEMA show. This year’s event will be held on November 4th and 5th. The cars entered thus far have earned their spots through various autocross events across the country, but there’s still one spot that has yet to be filled. A team of judges will select one addition entrant from the vehicles on display at this year’s SEMA show at the Las Vegas Convention Center. The latest class of entrants are:
· Jason Childress, ‘69 Ford Mustang
· Mike Copeland, ‘11 L/28
· Matt Farah, ‘98 C5 Chevy Corvette
· Rob Ferreti, ‘01 Chevy Corvette
· Mitch Greenblatt, ‘08 Mercedes CLK63
· Andrew Herold, ‘72 Chevy Camaro
· Scott Hoag, ‘11 Ford Mustang
· Randy Johnson, ‘69 AMX
· Albert Melchior, ’70 Pontiac Formula
· Allan Miller, ‘10 Chevy Camaro
· Carlos Monterrubio, ‘73 Nissan 240Z
· Terry Neuville, ‘68 Chevy Camaro
· Joe Shown, ’90 Corvette ZR1
· Marty Sokulski, ‘68 Dodge Charger
· Filip Trojanek, ‘66 Ford Mustang
· Curt Ukasic, ‘62 Nova Runt
· Mark Wetterau, ‘69 Chevy Camaro
Read more: http://blogs.hotrod.com/optima-annou...#ixzz1anWFu48z
Old 10-14-2011, 07:52 PM   #265
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
this thread is smoking...Pete..u are the MAN
ipimpthisc is offline   Reply With Quote
Old 10-14-2011, 11:06 PM   #266
Info@PeddersUSA.com
going to be a good time!
rob@peddersusa.com
Old 10-15-2011, 06:59 AM   #267
Stitch
Stitch's Avatar
I've ran 2 sets of RE-11's for past events, and I can agree that they are a phenominal tire, but in rainy hills of Western PA, they can be a little scary in the wet. I'll be picking up a second set of wheels for the SS for track days, and either RE's or A6's are going on, depending on what class I decide to shoot for ( unless Nitto comes out with the 305 ). The S001's feel very confident, even in standing water. Even got stuck on the highway in stopped traffic while I was home, because the rain was so bad that visibility was almost nill, and the S001's never gave way. I know they're not the best performing, but I'm very happy with it as a street tire.
My sidewalls are definitely shorter than what I wanted, but my initial measurements were based of the first set of wheels on the Pedder's car, which were 19's. After seeing how everything came together, and now knowing that I have some extra clearance, my next set of tires will be taller. Just wanted to be safe, not sorry. Never good to be the guy who get's a blowout from his own fender. Guess I'll just have to burn through these faster...
Anyone willing to help?
Can't wait to see what the L/28 can do.
Old 10-16-2011, 12:31 PM   #268
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
Stitch,
I'm thinking the same... I'm gonna go 10" wide so I need to be in a 295 wide tire.
there are a couple 295 30 20 out there. One is a continenetal and the other a P Zero...
otherwise I'll be in a 295 35 and there are a ton of options out there for that tire...
Need Pete to chime in on a 295 30... See if he's cool with that setup.
Old 10-16-2011, 12:41 PM   #269
ipimpthisc
Banned
I would love to do a 305 or in the front but i notice something...tell me if u guys have the same issue. When i put the larger tires of front my car wanders side to side on roads that look like rail road tracks... What i mean is that in nyc due to so many cars and heavy vehicles the soad looks like a hump in the middle and to the left and right like a valley all the way down. It make my car track with the shape of the road. I hate it.
Old 10-17-2011, 04:01 PM   #270
JusticePete
Needs Lowering
Stitch,
Old 10-17-2011, 04:05 PM   #271
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
Sweet! I'd say that's a go for the 295/30...
Oooorrr... there is a titanic Iceberg reference in there and I'm headed for disaster.....
Old 10-17-2011, 04:15 PM   #272
JusticePete
Needs Lowering
Endorphins enhance you driving skills
Old 10-17-2011, 04:22 PM   #273
ipimpthisc
Banned
any one in their wisdom care to address this concern?
Old 10-17-2011, 04:23 PM   #274
JusticePete
Needs Lowering
Tire tread and alignment will make the search in the ruts better or worse. A bit of caster offset, just a half a degree will help minimise it.
305s up front will search the ruts, but it shouldn't be that much worse. My guess is that the caster offset will keep it about the same as you have now. The easiest way to test this on your roads is to install a set of caster eccentrics and dial in that .5 degree stagger. Drive the worst roads and see how it feels. It won't be gone, but it should be much improved. If the result is good then you can move to a 305 front.
Old 10-17-2011, 04:23 PM   #275
JusticePete
Needs Lowering
It may not be wisdom, but I addressed it
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Pedders December Dollar Days for the 2010 Camaro and Brand X Vehicles JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 85 07-26-2009 05:20 PM
SEMA, Pedders Conference, GS Camaro, New Products JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 25 12-01-2008 01:25 PM
JP Got Bored or Maybe Lost His Mind JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 0 11-26-2008 04:18 PM
Pedders partnering with GM Racing on Camaro suspension Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 6 09-30-2008 12:14 PM
