| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
#76 |
On a list for a 2014 Z28
![]() Drives: 2010 Camaro 2SS M6 Join Date: Oct 2008
Are you not concerned of the tire's load index number, For this tire compered to OEM, 98 for this tire and 106 for OEM.
#77 | |
Needs Lowering
![]() Drives: Pedders USA Camaro Justice Join Date: Jun 2007
The OEM Load Rating Totals 8,376 pounds. The Re-11 Load Rating Totals 6,612 pounds. I cannot say that GM is wrong to have a truck like load rating for the tires nor would I say that Bridgestone is wrong in calling this a non-conforming application. I can say, that in my opinion a total load of 6,612 pounds is more than I will need in this particular vehicle. Many of the things we do at Pedders are done on customer vehicles. Pedders is no different than Bridgestone and GM so we call this a non-conforming application as well.
![]() Camaro Information | Buy Pedders Parts | Pedders Dealers | The 5th Gen Book | GMPP | SEMA Hot Wheels Camaro Brochure | EOD Fund Facebook Pedders Head Office 248.522.8021 Last edited by JusticePete; 08-18-2009 at 04:26 PM. Reason: Longer Answer |
#78 |
Pete thank you for the answer it makes sens to me. If you can what do you think the lowest load index number tire we can go with is for a Daley driver is and for the track.
#79 | |
Needs Lowering
Camaro 4,000 Additional Load at 50% 2,000 Tire Load Rating 6,000 as a minimum Once again, this is just my opinion. It is a common sense approach and not the recommendation of any of these companies. The Camaro in this thread is my personal vehicle and not owned by Pedders. You should always follow the manufacture recommended tire and wheel fitments. Speaking as a car guy and not for any company or with any inside information, GM selected the tire and wheel packages for the Camaro based on heavy influence from the design team. The OEM tires and wheel fill the huge wheel arches and look great. There is no question about it -- the Camaro looks great. That said they are rather large. These large wheels and tires provide benefits:
There are negatives;
It is my opinion that the style drove the Tire Load Rating for the Camaro and not an engineering parameter that generated a potential 4 TON load for a four seat passenger vehicle. The Pedders USA Camaro has a mission. We intend to break the performance ranges of a C6 Corvette for LESS than price of a Corvette and do it with space for four people. We need to get more rubber on the ground, especially up front to do this. We need to improve braking without spending money for six pot brakes. We need more power with a goal of 600 RWHP on a budget. We need more alignment adjustment range to improve turn in and tracking. We need to get the car over 1G on the skid pad and on the track in real turns at speed. To do all this we will bend a few rules. In bending these rules we do not want to compromise safety. No one I have discussed this with had any concern over safety with my tire selection. Everyone I spoke with did raise the issue of being below the manufacture recommended Tire Load Rating -- in my opinion -- solely for CYA reasons. Is the tire safe? Off the record the answer was unanimously yes. On the record, no one said it was not safe. They all said it was below the MFG spec and a non-compliant application. We will follow our own judgment when our goals conflict with a rule. Having said that, my family rides in this vehicle so my personal measure of safety for my family trumps everything else. In the end, it is incumbent on me to make the final decision for this project and to make certain that the vehicle is safe for my family and for my professional drivers on the track. In doing so the liability becomes 100% mine. Why I am I writing all of this? To make certain you all understand that the mfg has made decisions that involve vehicle safety and you should ALWAYS follow them. That I have bent or broken the rules does not make me right. My professional recommendation is no different than all the advice I received. Always follow the manufacturer's specifications for your vehicle. If you deviate from them, you and only you take on full responsibility for the safety of everyone on the road and in your vehicle. That is a huge responsibility and liability. Take is very seriously.
![]() Camaro Information | Buy Pedders Parts | Pedders Dealers | The 5th Gen Book | GMPP | SEMA Hot Wheels Camaro Brochure | EOD Fund Facebook Pedders Head Office 248.522.8021 |
#80 |
Thanks it helps me out on deciding on tires for my 335 tires as there is not a lot of 20" tires, As i have said this car will run on 335 rears and now 305 up front as soon as you tell us the off set for the front rims from Forgeline.
#81 |
One Lucky Guy.
Drives: #22 Tom Henry Racing 2010 2SS/RS Join Date: Dec 2007
Nice write up pete.
Thanks,
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
#82 | |
Dances With Mustangs
Having said all that, and I quite agree, the factory load rating is based on the factory vehicle weight. If a person is modding their car and doing weight reduction, that affects the load rating downward which is favorable. The factory rating is in essence a doubling of the vehicle weight. Standard vehicle weight is 3860; add 200 lbs for driver and you're at 4060. Double that and you have 8160 which is pretty close to what they chose as a load rating. I think they went slightly over simply because of what was available commercially for tires. If you start reducing vehicle weight through mods and can reduce it to say... 3700 lbs, add 200 for the driver and you're at 3900 so then double that which would be 7800. Divide that by 4 you get 1950 lbs per tire to maintain the factory ratio of double the vehicle weight. I think double is a little excessive myself; this isn't an SUV where I might be hauling 1000 lbs in passengers, a full load of bricks in the back and 8 sheets of drywall roped to the top. However you MAY be driving fast and cornering fast which causes load shift so you can't ignore tire load ratings either. GM rates everything conservatively so like their engines which are rated at 426 but can easily go higher without problems, I think it's safe to figure tire load rating was conservatively calculated too. I agree 50% above the gross driving weight (with driver) is the minimum and to be sure just go 60% or higher if anyone is concerned. Your tire's load ratings are about 63% above the factory weight of 3860 (+200 for driver); since I'm certain your car weighs less than that, it's all good. For anyone who has not reduced weight but wants to change wheels and tires, as long as the load rating of the tire is 1624 lbs which gives a total rating of 1.6x the weight of 4060 lbs (3860 + 200), you should be just fine. Anything higher than that of course is even better. That said, as has been stated by others YOU TAKE RESPONSIBILITY for your actions if and when you modify your car. If you are not sure or are concerned about a mod, then DON'T DO IT, regardless of what anyone says here or anywhere. If you're worried about it, DON'T DO IT. IF YOU DECIDE to modify anything on your car, don't blame anyone if something you do to it breaks something or causes you problems. The only time that doesn't apply is if something you purchased was faulty of course or "not as advertised" but as a general rule whatever mods you do, you do at your own risk; just so you know. As long as you understand and are cool with that, modding can be a lot of fun and very rewarding.
Blue Angel is here!! ![]() 1SS/RS LS3 M6 IBM |
#83 |
Needs Lowering
Great post.
#84 |
![]() ![]() Drives: 2SS/RS LS3 RJT Join Date: Jun 2009
Pete,
Any updates on this wheel package? I am eager to see them on a Camaro with a Pedders' suspension. ADM posted some pictures of 19" wheels, but I don't think they are the same thing as what you are designing. If we chose to stay with 20s, but still wanted the widest, non staggered wheel that would fit with your coil overs and sway bar set up, what would you recommend? |
#85 |
I'm pretty sure I'm going with 19's and probably a 275/35-19 tire but I'm trying to find a tuner shop who can recalibrate the speedo; just need someone in Southern Calif. that can plug into the computer and input the revolutions per mile of the new tire size.
#86 |
![]() Drives: 2008 TBSS Join Date: Jan 2009
Is suspension modification required to fit the 305's up front?
I would want to take up some of the slack in the wheels wells anyway, I'm just curious.
2SS RJT 6MT
ARH/QTP/HAI/Tune/Empire Billet |
#87 | |
![]() Drives: 5th Gen Rental Join Date: Aug 2007
Mike dms
Rob Anderson - Business Development
rob@peddersusa.com |
#88 | |
mike dms
#89 |
Southern Calif, Inland Empire but I can drive to Orange County (that's actually where my rims guy is) or anyplace within an hour if necessary.
#90 | |
mike dms
#91 |
susp.ban4life!
Drives: Raptor Join Date: Jun 2009
#92 |
![]() Drives: Bucket Join Date: May 2009
#93 | |
#94 |
Needs Lowering
Hmmm, yes you can. We have these on a lowered Camaro.
#95 |
![]() Drives: 2006 EVO MR - 390 @ wheels Join Date: Jul 2009
^^with the stock springs you can put 305's up front? Didn't you say the car was lowered? So you're not using stock springs at that point are you?
2010 2SS/RS 6spd manual -- Victory Red / Black Leather
1100, Preliminary order accepted 7/27/09 2000, Order accepted by GM 8/13/09 3000, Order accepted by production control 8/18/2009 TPW 9/07/2009 3300, Order scheduled for production 8/24/2009 3400, Order broadcast 9/1/2009 3800, Order produced 9/11/2009 4200, Shipped 9/11/2009 5000, Delivered to the dealer |
#96 |
Needs Lowering
You are absolutely correct. The car will be posted will with custom paint, cowl induction hood, chin spoiler, wheels, proCharger, Sweet Thunder custom exhuast, QTP cut outs, Cobalt Friction brakes, American Racing Headers, custom interior, shaved door handles, shaved badges, naked trunk lid and more after we show it at the 28th Street Cruise this Saturday October 29th in Grand Rapids. We hope to see you there.
#97 |
Needs Lowering
The vehicle we did the fitment on was on Pedders Xa coilovers. The vehicle Forgeline used to develop the wheels was on OEM suspension. When mine is out of paint and at Witt for the suspension upgrade we should be able to double check the fit on OEM suspension before the coilovers go on.
#98 |
Evil Pedders Guy Since 06
![]() Drives: His Wife Crazy Phone:860-880-0486 Join Date: Jan 2008
What is the load index on the G8 tires?
isn't it 96V and 94W |
#99 |
Awesome. I'd like to get four wheels and tires of all the same width, which should help with the understeer a bit with more contact patch up front.
I don't care to go too big though on the wheels/tires, as this will be a daily driver....maybe like 295's all around or something in a 19" or 20"wheel. I'm going to wait a bit before making a decision though to see how you guys go about doing things. I do plan on getting Xa's though...so I just have to make sure I've got the mula for both Xa's AND a good set of wheels.
#100 |
Needs Lowering
Good question and one I can't answer because I am riding on 275/35/19 Bridgestone Pole Positions and not OEM rubber.
| Thread Tools | |
| Pedders Suspension Benchmark Track Testing and New Jersey Track Day | Info@PeddersUSA.com | USA - NY / NJ / PA | 35 | 10-26-2009 05:20 PM |
| Pedders December Dollar Days for the 2010 Camaro and Brand X Vehicles | JusticePete | Wheels and Tires Talk Sponsored by The Tire Rack | 85 | 07-26-2009 05:20 PM |
| SEMA, Pedders Conference, GS Camaro, New Products | JusticePete | Wheels and Tires Talk Sponsored by The Tire Rack | 25 | 12-01-2008 01:25 PM |
| JP Got Bored or Maybe Lost His Mind | JusticePete | Wheels and Tires Talk Sponsored by The Tire Rack | 0 | 11-26-2008 04:18 PM |
| Pedders partnering with GM Racing on Camaro suspension | Info@PeddersUSA.com | Wheels and Tires Talk Sponsored by The Tire Rack | 6 | 09-30-2008 12:14 PM |
