sjm autoprod
Old 08-18-2014, 09:26 AM   #1
JGiovando
Drives: 2014 2LT RS Camaro
Brake mod question
Hey guys,
This may seem like a silly question but can I just remove my V6 rotors and calipers and replace with SS rotors and calipers, simply change them out. I know the brake lines should be changed as well but will they simply unbolt and bolt on, are there any additional parts needed (shields, etc)?
Thanks in advance.
Jason
JGiovando is offline   Reply With Quote
Old 08-18-2014, 01:03 PM   #2
BLTZKRG
Drives: 2014 Camaro SS
I would imagine u would need the larger ss backing plate/heat shield. They are mainly there for water guards...you can leave them off if u dont do much driving in the rain.
2014 Ashen Gray Metallic 2SS/RS M6
CAGS Skip-Shift Eliminator
1LE Strut Tower Brace
GMPP Track Pack Axleback
Halltech CAI
Fuse Pull Mod
BLTZKRG is offline   Reply With Quote
Old 08-22-2014, 02:11 PM   #3
J-Crazy Camaro
J-Crazy Camaro's Avatar
Drives: Red V8
you definitely don't want to leave off the backing plates, they prevent debris/crap off the road from entering your rotor and go into your caliper mount.
Your caliper mounts will be different and there may be electrical issues encountered, like traction control. I would just buy a new brembo or mgp brake package. its easier and the company put in engineering to know what works
J-Crazy Camaro is offline   Reply With Quote
Old 08-22-2014, 05:34 PM   #4
Sparkyz13Bee
Sparkyz13Bee's Avatar
Drives: 2013 Camaro 1LT
There are a lot of threads on here that have done this very mod. Do some searching. And I'm sure you can find your answer.
Sent from my Sparkyz iPhone using Tapatalk
Sparkyz13Bee is offline   Reply With Quote
Old 08-22-2014, 08:24 PM   #5
intensifi
Drives: '12 2LT Convertible
Rear dust shields require trimming or replacement. (I know it makes no sense.)
You will need new caliper bolts, pads, pins, etc.
Technically you should also get the SS master cylinder. If you do that you will be doing a full fluid bleed as well.
Yes you should do this. It's a great mod.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
