Old 08-18-2014, 06:46 PM   #1
EDFHOBBIES
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
brake bleeding and fluid change
Am I going to mess up the abs or brake system by changing one brake line at a time and installing the stainless steel Lines. and doing a fluid flush by pressing brake down with valve open on calipwr then close valve on pedal upstroke?
EDFHOBBIES is online now   Reply With Quote
Old 08-18-2014, 10:22 PM   #2
NC-V
NC-V's Avatar
Drives: cts-v
No, just keep an eye on the master cylinder to keep fluid in it. Should not have any problems what so ever as long as it doesn't run dry.
NC-V is offline   Reply With Quote
Old 08-18-2014, 11:26 PM   #3
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
Ya what he said.
I have changed brake lines, calipers, etc. no issues. Just don't run the system dry when bleeding.
CHMSC is offline   Reply With Quote
Old 08-20-2014, 09:23 PM   #4
Jylee
Drives: 2012 2LT
Motive self breeder
You can do it by yourself in 10 minutes. The hardest part is jack car and remove wheels.
Jack
Jylee is offline   Reply With Quote
Old 08-21-2014, 07:06 AM   #5
EDFHOBBIES
EDFHOBBIES's Avatar
Jack
So far the hardest part was cleaning every bit of grime off calipers! I hand washed 5 times each caliper scrubbed good 10 min each one, finale cleaned with caliper prep cleaner. LOL
Yellow paint here today.
Old 08-21-2014, 07:07 AM   #6
EDFHOBBIES
EDFHOBBIES's Avatar
Thanks... I forgot DOT3 or DOT4 fluid? I would be driving daily and doing road course 2 to 3 times a year..
Old 08-21-2014, 07:09 AM   #7
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Use dot4 if you plan on any RC events.
Motul is good for the price. There are several others out there you can use as well.
Old 08-21-2014, 12:37 PM   #8
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
+1 I recommend the Motul RBF600. You'll need about 3 pints.
Best regards,
Tyler
888-308-6007
JDP Sales is online now   Reply With Quote
