Old 08-21-2014, 09:36 AM   #1
mbellomo19
mbellomo19's Avatar
Drives: 2011 camaro 2SSRSS
koni struts and lowering springs
hi just wondering if i need anything other than koni struts and hotchkins 1'' Inch lowering springs are the koni struts even needed? what would they give me over factory?
mbellomo19 is offline   Reply With Quote
Old 08-21-2014, 10:09 AM   #2
BMR Sales
BMR Sales's Avatar
Drives: Race Car
The Koni STR.T's are a performance shock and are valved differently than their factory equivalents, they will provide a stiffer (more performance oriented) ride than the factory shocks/struts. You will also get a longer lifespan with the Koni's because they are designed for use with lowering springs, whereas you factory shocks/struts were not. Plus, they have a lifetime warranty through Koni.
You don't absolutely need anything else to install these parts, but it is "nice" to have adjustable toe rods installed with springs, just to give you a little more adjustability in your alignment settings.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 08-21-2014, 10:36 AM   #3
mbellomo19
mbellomo19's Avatar
does bilstein make an equvilant to the konis
Old 08-21-2014, 10:50 AM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yes, I believe so, but quite a bit more expensive.....
http://www.tirerack.com/suspension/s...utoModClar=1SS
T.C. Davis
813-986-9302
Old 08-21-2014, 10:54 AM   #5
mbellomo19
mbellomo19's Avatar
are they better? and excuse my ignorance but what do the adjustable toe rods installed with springs do?
Old 08-21-2014, 11:53 AM   #6
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I have not had any experience with the Bilsteins, so I can't really say if they are better than the Koni's. I do know that our 4th gen customers really like them. The adjustable toe rods will give you more adjustability in your alignment specfications. The factory eccentrics only go so far. Ultimately, the use of adjustable rear lower control arms (TCA029) coupled with the adjustable toe rods (TR003) are the best solution, but admittedly, the adjustable rear LCA's are a bit expensive for some budgets.
T.C. Davis
813-986-9302
Old 08-21-2014, 12:13 PM   #7
Demon Z/28
Scarecrow
Demon Z/28's Avatar
Drives: like a granny
how do the konis compare to 1le struts ?
The Rooster - 2015 Z/28
The Scarecrow -2014 1LE SOLD -
Demon Z/28 is offline   Reply With Quote
Old 08-21-2014, 12:17 PM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Originally Posted by Demon 1LE View Post
how do they konis compare to 1le struts ?
Performance would be close. The Koni's are valved a little bit stiffer, and better longevity with lowering springs.
T.C. Davis
813-986-9302
