Solo Performance
Old 08-14-2009, 02:41 PM   #1
Terrellford12
Drives: 2010 SS/RS
Whats the size?
Whats the factory exhaust size
Terrellford12 is offline   Reply With Quote
Old 08-14-2009, 02:43 PM   #2
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I believe it is 2.5 inches.
Crowley
Crowley is offline   Reply With Quote
Old 08-14-2009, 02:47 PM   #3
Terrellford12
Drives: 2010 SS/RS
Crowley
What do you think if i get the axel back from slp and put an x pipe on it? Also whats cats? What could i get and do to my car with the slp mufflers cats and x pipe? please let me know.
Old 08-14-2009, 03:04 PM   #4
toehead93
Drives: 2014 2SS/1LE
I plan on getting the SLP LMII one of these ways:
1. Axle-back plus 2.5" x-pipe to replace stock H-pipe and resenators (L99 only).
2. Axle-back plus 3" x-pipe and custom fabricated 3" exhaust from cats back.
3. SLP LMII mufflers and tips plus 2.5" x-pipe to replace stock H-pipe and resenators (L99 only).
4. SLP LMII mufflers and tips plus 3" x-pipe and custom fabricated 3" exhaust from cats back.
I am not replacing the cats until I get the headers. I'm leaning toward number 4.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-14-2009, 03:11 PM   #5
Terrellford12
Drives: 2010 SS/RS
Whats cats ? Can I see Them on my car i also have an L99?
Old 08-14-2009, 03:46 PM   #6
toehead93
Here is a diagram of the exhaust:
http://www.camaro5.com/forums/showth...xhaust+diagram See my post #8 for the legend of parts, the diagram from the OP is mis-labeled...the cats are redish-purple at the front.
There is a post I can't find with a great pick of the exhaust on a shop floor. High Flow cats are used with headers so they don't become the choke point in the system. With stock manifolds there's no point in replacing the cats, you still have the choke point with the manifolds. You're better off spending money elsewhere.
2010 2SS A6 - sold.
Old 08-14-2009, 04:17 PM   #7
Terrellford12
Drives: 2010 SS/RS
Thanks toe head im not tryna be a nag but i want it to be done right you know what i mean. So when i get the slp axel back and the x pipe where would i tell him to put the x pipe? and what about the three inch pipes what you were talking about
Old 08-14-2009, 04:25 PM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
Unless you are going with a big cam or supercharger then 3" is overkill and not needed. Do a search on the forum and you'll find where this is talked about serveral times. Same goes with the X-Pipe. There are pictures of the factory H-Pipe and then the aftermarket X-Pipe in it's place.
Build Journal
Old 08-14-2009, 04:40 PM   #9
toehead93
If you are adding just the axle-back and an X-pipe you'll end up keeping the stock 2.5" pipes. The 2.5" X-pipe will be installed to replace the stock H-pipe and two big resenators that hide it (see photo in this post) http://www.camaro5.com/forums/showth...xhaust+picture
If you want a 3" cat-back system you can buy the SLP cat-back which includes n x-pipe of have a shop fab a custom 3" system with 3" x-pipe.
2010 2SS A6 - sold.
315 size rear tire... Tony SS Wheels and Tires Talk Sponsored by The Tire Rack 99 03-07-2012 05:31 PM
Fuel Line Size JSOC_MQ1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 08-10-2009 10:50 PM
What size are stock exhaust tips SSCamaro2010 5th Gen Camaro SS LS LT General Discussions 4 07-22-2009 09:07 PM
2010 V6....what size tires Tachometer Wheels and Tires Talk Sponsored by The Tire Rack 7 02-26-2009 10:09 AM
DIN size? spartan611 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 9 08-03-2008 03:59 AM
