Solo Performance
Old 08-22-2014, 03:06 PM   #1
Sparkyz13Bee
Sparkyz13Bee's Avatar
Drives: 2013 Camaro 1LT
Am I crazy??????
I have a 2013 1LT And I just installed a ZL1 factory rear sway bar. The front is on the way. The installation was easy. Kind of a pain to get the bar over the exhaust.
Here is my question going over speed bumps and some bumps in the road. The car seems stiffer than before. Is this just me?? In the corners car is definitely more planted in the rear. A lot more rear grip now than front. Which is giving me a slight oversteer problem. But the stiffness over bumps has me scratching my head.........
Like I said. Could totally be in my head. If that's the case. I get it......... Don't judge me. LoL
Sent from my Sparkyz iPhone using Tapatalk
Sparkyz13Bee is offline   Reply With Quote
Old 08-22-2014, 03:36 PM   #2
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Hmmmm.....I was under the impression that the FE4 style bars wouldn't fit on a V-6 car because of interference with the V-6 rear brake calipers?!?!? Maybe it's just on the aftermarket FE4 bars that have the adjustable mounting locations for the end links??? Hmmm, learn something new every day!!!
T.C. Davis
tc@bmrsuspension.com
813-986-9302
Old 08-22-2014, 03:37 PM   #3
Sparkyz13Bee
Mounted in stock location. No problems........... Other than it is a tight fit.
Old 08-22-2014, 03:40 PM   #4
RKCamaro13
RKCamaro13's Avatar
Drives: 2011 Red 2SSRS A6
You gonna take out your old endlinks?
MPD1 Z Force hood, 1LE splitter, ZL1 rockers and diffuser, Heritage grille, Sparks Restorations emblems, Struct Tower Brace, Foot well Lighting, CNC ported throttle body, Roto-Fab CAI, SW long tube headers, High flow cats, Lethal Racing Prowler Cam, LS3 conversion, Yank 3400 Stall, Corsa 3" cat back exhaust, RX Catch Can, BMR Suspension, BC Coilovers, Slotted and Cross-drilled rotors, Magnuson Supercharger (soon to be).
RKCamaro13 is offline   Reply With Quote
Old 08-22-2014, 03:55 PM   #5
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
I noticed that too.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 08-22-2014, 04:12 PM   #6
Sparkyz13Bee
Stock ZL1 location. Apparently my rear lower control arms have the same mount holes as a ZL1.
Old 08-22-2014, 04:15 PM   #7
Sparkyz13Bee
They are removed........... Took them out after taking the pic. I prefer to do things right the first time.
Old 08-22-2014, 04:18 PM   #8
Sparkyz13Bee
Will the TCA028 rear lower control arms work with this rear sway bar as well? The end link mounts near the end of the arm close to the caliper.
Old 08-22-2014, 04:21 PM   #9
RKCamaro13
RKCamaro13's Avatar
I figured you did, just messing with you. If you do have any other suspension questions or upgrades I would highly recommend BMR. Keith is very knowledgable and can help you figure out what you need.
Old 08-22-2014, 04:23 PM   #10
Sparkyz13Bee
I am gonna get the rest of the rear suspension pieces from BMR. Rear lower control arms, rear end links and toe links and lowering springs.
Old 08-22-2014, 04:24 PM   #11
Sparkyz13Bee
The mere size difference between the stock rear 1LT SWAY bar and a stock rear ZL1 sway bar blew me away.
Old 08-22-2014, 04:26 PM   #12
Sparkyz13Bee
Here is a closer pic of the two bars. Quite a size difference.
Old 08-22-2014, 04:38 PM   #13
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yes, they will, we just revised the TCA028's to accept both the FE3 & FE4 style sway bars.
T.C. Davis
813-986-9302
