Emblempros
Old 08-14-2009, 03:47 PM   #1
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
LMR Intake concerns, with pic
With all the concerns about the LMR intake shield not fitting properly, I thought I'd post a pic.
Here's a pic of the shield before I finished the install. As you can see the shield fits really good and matches the shape of the car well.
After I finished.
Old 08-14-2009, 03:48 PM   #2
thecamaroguy
thecamaroguy's Avatar
Drives: 2010 Camaro SS/1967 Camaro SS
You will be very happy with your LMR CAI.
Wait until you hear the change in the sound of your car!
thecamaroguy is offline   Reply With Quote
Old 08-14-2009, 04:51 PM   #3
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
That actually looks pretty good...if that's exactly how you received it then they must have changed the template since I receive mine as the cut on mine was clearly different.
Keep an eye were it contacts the paint for rubs. The dealer also pointed out to me today that the upper edge of the piece was creating an indentation in the pad on the hood.
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 08-14-2009, 05:07 PM   #4
SGOS252382
SGOS252382's Avatar
Yes, that's how it arrived. No changes were made.
Actually, most of it doesn't even make contact. It looks like it does, but its just away from touching the car. There's really only 3 main contact points on that one side. The very bottom, the spot where it attaches with the nut, and at the very top end where it butts up against the side of the car.
I don't see rubbing being an issue at all.
You obviously got a pre-production model before they finished making changes. Why?
Old 08-14-2009, 05:09 PM   #5
ffrcobra_65
I agree. Over time, as the shield vibrates or from periodic handling, the edges that are in contact with the paint will rub and quite possible mar the paint.
If mine, I would get some small vacuum line tubing, preferable the cloth-braided type like those used on classic VW Beetles as they are more plyable/flexible, and measure it to the length of the edge, cut a slit in the middle of the entire length of the vacuum line and attach it to the bottom edge of the shield. The vacuum line will act as a cushion/seal to protect the paint.
Old 08-14-2009, 05:12 PM   #6
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
and then the vacuum line, will rub the paint.
put a strip of paint protection film along the area in question.
should only cost pennies.
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 08-14-2009, 05:22 PM   #7
ffrcobra_65
I agree if you use the fancy steel braided ones, will definitely rub paint off. I recommended a cloth-braided vac line. I have had a lot of cars, lots of older cars that have vacuum lines resting against painted parts of the engine bay and never had any issue.
Hmmm..I like your idea of some type of film to put on there.
Old 08-14-2009, 06:28 PM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
When your spending around $400 for a CAI you shouldn't have to do anything.
As of now the LMR CAI is my #2 choice. ADM's is #1 in my book at the moment. However I'm still 6 mths away from getting my hands on an SS and I'm sure there will be more options at that time. Not that we necessarily need more options.
Build Journal
Old 08-14-2009, 06:51 PM   #9
themossman
themossman's Avatar
Yeah...I don't know either...but I won't have it for much longer (it was a 'band-aid' so to speak anyway...
Unless you're 'dying' to get one(I was due to the work I had done), you might want to hold off for another month or so...pretty soon I think there's only going to be one clear option...but that's speculation on my part.
Current Summary:
Old 08-15-2009, 07:12 AM   #10
SGOS252382
SGOS252382's Avatar
No you shouldn't. I believe he was offered a new intake shield or some other deal, because LMR made a mistake by sending him a pre-production kit.
If you look at the pictures he posted in his thread, his intake shield isn't the same as mine.
Old 08-15-2009, 08:36 AM   #11
JJ2010
I am always amazed how people can find the smallest thing to complain about......
The LMR CAI is one of the best CAI for the Camaro to date.....
JJ2010 is offline   Reply With Quote
Old 08-15-2009, 11:25 AM   #12
themossman
themossman's Avatar
I'm sorry...but scratching paint down to the metal is not a 'small thing'. Everyone that has seen it in person has commented how ridiculous it is and how poorly the the piece is cut.
Current Summary:
Old 08-15-2009, 11:26 AM   #13
themossman
themossman's Avatar
Well...LMR wanted me to 'call' the shop...they have my contact info and have yet to ask for my address to send me a new piece.
I continue to sit waiting.
Current Summary:
Old 08-15-2009, 11:33 AM   #14
SGOS252382
SGOS252382's Avatar
1. Call them
2. Tell them you were sent the wrong intake shield(as discussed on Camaro5)
3. Give them your address
4. New intake shield shows up at you door.
CAI Comparison at LMR Dyno day mlee Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 08-17-2009 10:31 PM
Just installed an LMR intake!! SS Mike Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 45 08-09-2009 04:16 PM
Hennessey V6 Intake Review Tecca Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 23 08-06-2009 05:51 PM
More 2010 SS Air Intake Dyno Results From Texas Speed!! Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 07-03-2009 09:58 PM
Intake/ Air Cleaner observations and thoughts... (?V6/V8?) radz28 5th Gen Camaro SS LS LT General Discussions 27 01-23-2009 08:14 PM
