Caryle Racing
Old 08-14-2009, 09:58 PM   #1
SS/LS3
Drives: 2010 ss
e-85 or 93
Im getting my car tuned on the dyno next week. I bought stainlessworks long tube headers and x-pipe. Also bought a LMR cold air. My question is to tune .with e-85 or 93 and has anyone tried e-85 with good results.
SS/LS3 is offline   Reply With Quote
Old 08-14-2009, 09:59 PM   #2
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
Read here, http://www.camaro5.com/forums/showthread.php?t=33574 a couple posts down.
jpsuperman81 is offline   Reply With Quote
Old 08-16-2009, 09:25 AM   #3
toehead93
Drives: 2014 2SS/1LE
I went through the thread earlier and I don't think there is much difference. However, I have been told that Mobil and Sunoco offer the best quality 93-octane and Cheveron/Texaco add Techron to the gas which will affect the tune.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-16-2009, 11:46 AM   #4
SS/LS3
Drives: 2010 ss
Thanks guys. I think im going to run 93. I was just looking to get a little extra hp. I bought a lmr cai and stainlessworks complete exhaust, it should be here this week.
Old 08-16-2009, 11:58 AM   #5
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
i am thinking about trying a e85 tune,,, on a very hot humid day at wot i data logged a few degrees of knock retard
Old 08-16-2009, 02:01 PM   #6
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Manual explains proper gas to use and gas not to use
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 08-16-2009, 04:10 PM   #7
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
None of the engines on the Camaro are e85 compatible. Ethanol fuel will eat through some materials in an engine/fuel system not designed to run high concentrations of it. DO NOT use e85 unless the manufacturer says its ok.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 08-16-2009, 04:13 PM   #8
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
I've looked around here in San Diego and haven't seen any gas over 91 octane :( Still researching though...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 08-17-2009, 09:27 PM   #9
SShift
SShift's Avatar
Drives: Only Bowties!
Mill the heads to run 12-1 compression and run e85
SShift is offline   Reply With Quote
Old 08-17-2009, 09:29 PM   #10
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
I wouldn't. The engine has to be specifically built to run e85, you would def do damage
mydreamcar is offline   Reply With Quote
Old 08-17-2009, 10:19 PM   #11
redjewel
Drives: 2010 Camaro 2SS RJT
Can you elaborate or show where you found this? I have used Chevron for over 10 years almost exclusivley.
How does Techron affect the tune? This is confusing as Chevron is a Top Tier gas recommended by GM.
If there is better 93 to run in it I would like that to be substantiated.
Thanks
2SS RJT A6 Sunroof Polished Wheels. Delivered 5-22-09 by Classic Chevrolet Sugarland
redjewel is offline   Reply With Quote
Old 08-17-2009, 10:25 PM   #12
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
Everybody, read this! Do not put E85 in a car unless you are prepared to replace some parts with E85-compatible components. If your car is not running E85 out of the box, then you have some building to do before it is ready.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
Old 08-17-2009, 11:54 PM   #13
ADM PERFORMANCE
Drives: 2016 CAMARO SS
You can say that again.
CAN YOU SAY MEGGA INJECTORS NEEDED!
ADM PERFORMANCE is offline   Reply With Quote
Old 08-18-2009, 08:49 PM   #14
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
not necessarily. ideally, yes you want to ensure you have the proper fuel lines and other requirements to run e85 regularly as well as tuning for e85. running a stock (gasoline) tune with e85 in the tank is asking for some trouble as the two react differently.
not megga, but larger injectors would be on the list of things to change over
I piss excellence
and fart awesomeness
