Caryle Racing
Old 08-14-2009, 11:42 PM   #1
traip93
Drives: Ralley Yellow, Black Sripes 2L
Looking for step by step oil change process
Pictures would be GREAT.
Can anyone bullet point how to [erform an oil/filter change on a V6 2LT? I've always had my oil changed for me. I'd like to become a man at some point...
traip93 is offline   Reply With Quote
Old 08-16-2009, 11:00 AM   #2
traip93
i guess this is a dumb question
Old 08-16-2009, 12:26 PM   #3
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Doesn't the owner's manual illustrate how to do this? Hmm, I guess not...I don't have my car so can't give pictures:
o buy oil filter
o buy oil - manual has amount needed & type
o buy oil funnel & oil filter wrench & oil pan & ramps (to get under car)
o warm up car, drive on ramps (use help)
o let car cool 10 minutes and find oil drain plug; open hood and open oil cap (I pull out the oil dipstick also)
o look up torque specs on drain plug when you need to retighten - buy torque wrench
o drain oil into oil pan
o remove oil filter and let oil drip into pan
o open new oil filter and wet rubber ring with fresh oil
o tighten new oil filter - read how many turns past tight - HAND Tighten ONLY!
o replace oil pan plug - torque and don't over tighten!
o using oil funnel, fill engine with recommended amount of oil
o put oil dipstick back, put oil cap cover back
o warm up car, let coil check dipstick - add oil if needed
o drive off ramps, slowly, mark the change in your maintenance section of the manual
o dispose of oil at recycle location
Ok, feel free to add/modify, but keep flames to a minimum. This is off the cuff as I do this without thinking on my own vehicles.
Good luck!
Oh, here are some details, but not specific to the Camaro: http://www.edmunds.com/ownership/how...8/article.html
Michael J.
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 08-16-2009, 12:30 PM   #4
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Oh Brother.....
Old 08-16-2009, 12:47 PM   #5
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
on the v6 cars you want to remove the filter first because it is located on the top side of the engine(cartrige style filter) and when you remove the filter all the oil in the filter housing will be able to drain into the oil pan.
then drain all the oil and replace your filter
Old 08-16-2009, 01:09 PM   #6
chrisinlittlerock
chrisinlittlerock's Avatar
Drives: 2010 Camaro/08 Tundra
Have someone else you trust do it.
Rally Yellow 2SS/RS with Custom painted Black Rally Stripes, Heritage grill, Corsa cat backs with x pipe, CAI.
Delivered: 8/18/09!!!!Yes!!!!
"This is CHEVY country. On a quiet night you can hear a Ford rust."
chrisinlittlerock is offline   Reply With Quote
Old 08-16-2009, 01:11 PM   #7
1320junkie
Drives: The Imperial Army
Hey we all have to learn at some point and I am glad you came here to ask..I see you are North of Atlanta..I'm always changing oil..you can come down and learn if you like.
Old 08-16-2009, 01:14 PM   #8
Michael_Js
Michael_Js's Avatar
Originally Posted by SSOOCH View Post
Oh Brother.....
I'm sure even YOU had a 1st time
Old 08-16-2009, 03:01 PM   #9
traip93
i've always found it easier to just pay someone to do it. I'm sure it's not rocket science. I have and do change break pads and I've changes rotors a couple times.
I've never changed oil.
I was looking for non manual advice. Someone said to run the car for 20 min, then lift the car so the drain on the pain is at the lowest point, I thought that was quality advice. Taking the filter out first was a good nugget too.
Do you have to buy a new plug every oil change?
Someone also mentioned 2 oil filter changes per oil change???
Old 08-16-2009, 03:16 PM   #10
Michael_Js
Michael_Js's Avatar
Don't have to replace the oil plug, but some plugs have crush washers on them (don't have the Camaro so can't tell you, yet) and those should be replaced. 2 oil filters changes per oil change? Not sure what that means. I've heard people say 1 oil filter per 2 oil changes, but I prefer to change the filter EVERY oil change. It can't hurt
I even taught my girlfriend to change her oil on her Tacoma. She's proud of herself for that, and so I am
Old 08-16-2009, 03:59 PM   #11
97one
97one's Avatar
Drives: 2016 & 1967 Camaro, 2015 Impala, +1
Yes you could do it that way.
I would remove the drain plug first, then while the oil is draining for a few minutes or more remove the filter. This way there is less oil to drip from the filter cartridge when taken it out. ...... No big deal I know, just the way I would do it.
Also leave the drain plug out as long as you can,to get more of the old oil out. I leave it drain for at least 1/2 hour. You may not have the time to do that most people don't.
97one is offline   Reply With Quote
Old 08-16-2009, 04:25 PM   #12
CatiaJockey
CatiaJockey's Avatar
Drives: 2010 2LT RS
First class offer, if possible ya ought to take him up on it.
Old 08-17-2009, 12:49 AM   #13
camaroguyBC
camaroguyBC's Avatar
Drives: 1SS Blk/Blk w CGM M6
the oil plug he's referring too is the screw/bolt in the bottom of the oil pan. when you take it off, the oil runs out. screw it back in good and tight to make sure your new oil doesn't run out on the floor (trust me...i once forgot to put the damn plug back in ...you won't forget twice!)
the "2 filter / oil change" thing he meant was that some people don't change the filter every oil change (2 oil changes per filter). Personally i change mine out every time. the filter itself will contain a fair amount of used / dirty oil when you take it off...if you don't change it every time...all that crap goes right back in with the new oil.
good luck. we all had to learn at some point!
2000: 07/07/09
3000:07/17/09 TPW 8/3
3300:07/28/09
3400:08/01/09
3800:08/11/09 #34541
4200:08/12/09
--8/12/09 11:30am - departed Oshawa CSX
--8/13/09 11:04pm - arrived at CSX/UP Interchange - Proviso, IL - 200 miles to go!
--8/17/09 7:30pm - departed Proviso, IL
--8/18/09 5:15am - received at interchange, unloaded (11:04am), Janesville, WI
5000: 8/19/09
6000: 8/20/09
camaroguyBC is offline   Reply With Quote
Old 08-17-2009, 12:52 AM   #14
camaroguyBC
here's a couple easy demos on how to do it:
http://www.castrol.com/castrol/swfpo...580&title=View << this one is a Flash / animated demo with step-by-step instructions
http://www.ehow.com/video_11_change-motor-oil.html << video with commentary
2000: 07/07/09
3300:07/28/09
3400:08/01/09
4200:08/12/09
5000: 8/19/09
6000: 8/20/09
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
500 mile oil change (metal shaving) Treadstone Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 36 11-17-2010 06:10 AM
Initial LS3 oil change domano 68 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 07-09-2009 01:02 PM
Need Opinion on Oil Change 68blk/yel396 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 22 06-22-2009 12:02 PM
