Grabiak Performance Center
Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions
Old 08-17-2009, 02:40 PM   #26
MontyCarlo
MontyCarlo's Avatar
Drives: 2010 2LT/RS auto IBM
How much would you be able to spend on this upgrade?
FAQs:
1. No, I do not have any strong opinions about the Monte Carlo.
2. Yes, I know what my name looks like.
3. Yes, but the medication helps immensely.
2LT/RS IBM/gray #21,895 ordered April 21st, delivered July 3rd
MontyCarlo is offline   Reply With Quote
Old 08-17-2009, 02:55 PM   #27
Scrapppy666
Scrapppy666's Avatar
Drives: 2010 2SS/RS M6 Black/Black
soo... you are willing to spend 30-50K just to beat your cousin, why not borrow or buy one of your uncle's rides? Just out of curiosity, how old are you?
Pittsburgh Automotive Photography
Black on Black 2SS/RS w/ white stripes Dynomax 3" Bullet Catback, CAI Cold Air Intake
Scrapppy666 is offline   Reply With Quote
Old 08-17-2009, 04:00 PM   #28
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Originally Posted by wacamaro View Post
Thanks everyone its been alot of help! I dont want to come off as a dumba$$. But i am a newbie. Thanks exspeacially to Jannettyracing. That post was exactly what i needed to hear. I maybe a newbie but i relize the kind of money it will take which will take me about a year to get to the 700rwhp goal i just dont want to take any shortcuts in my greed for hp. Im a newbie when it actually comes to mechanics but as far as driving high horsepower cars im a little more seasoned. My uncle has had several Hot rods around 700 to 800 hp power that i was fourtunate enough to drive.
The only dumb question is the unasked one.
Your welcome, keep me in mind when your ready to start moving forward, I will lay out a plan of attack that makes sense for your pocket book and your goals.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 08-17-2009, 04:19 PM   #29
FreddyG
Drives: C5 Corvette
With the LS type of motors, 700 at the crank is doable without forged internals! The MOST important parts of the install are supplying adequate fuel AND getting the tune right!
If you mess up on one of these two things, you might want to take off those speed parts and get ready to warranty some engine pieces!
I know some Guys that have made over 700 RWHP on C5 Vettes and they lasted for over a year before making the decision to forge their motors! It can be done, but as stated above, it's not going to be cheap!
When you plan your budget, don't forget to factor in a new clutch, or trans work (depending if you have a manual or automatic), Definitely new rear tires, and probably a lot more supporting mods to boot!
FI isn't cheap and also when you add up your budget, add 10% more because it Rarely stays on target!
By the way, you should be able to Smoke his GT500 with 600 rwhp if he's got stock tires and you run drag radials! Practice your driving too because Many a race has been won by missed gears!
Good Luck and Please keep us posted on how it goes!
FreddyG is offline   Reply With Quote
Old 08-18-2009, 11:00 AM   #30
wacamaro
Drives: Blue
Ok i make about 7,000 a month im 19. Im not simply tring to beat my cousin ive already done that (not mustang vs. camaro) Im not spending 30,000 to 40,000 to beat my cousin im spending 30k to 40k to have a high horse power camaro. I dont have a budget on how much i want to spend, it just wont be all at once. And if it really cost around 30k why not just get it from hennessey? I would be asking my uncle all of this but he passed away about 4 months ago.
wacamaro is offline   Reply With Quote
Old 08-20-2009, 11:27 AM   #31
wacamaro
Drives: Blue
I think ive decided to forget about adding upgrades one at a time and just wait about a year and take it to Hennessey for all the upgrades is this a good idea?
Old 08-20-2009, 11:51 AM   #32
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
supercharger,heads,cam,forged internals,transmission,driveshaft,gears,half-shafts,BRAKES
Gentry78 is offline   Reply With Quote
Old 08-21-2009, 07:05 AM   #33
2010 CAMARO SS RS
2010 CAMARO SS RS's Avatar
Drives: 2010 Camaro SS RS
Texas Speed & Performance 454 cid LSX Rot. Assy.
Item# 25-TSP454Assy. $2,199.00
Select Crankshaft: | Callies CompStar Crankshaft $175.00
Select Connecting Rods: | Carrillo Billet connecting Rods $1,130.00
Select Pistons: | TSP/Diamond 4.200" -4cc Flat-Top Piston Set $0.00
Select Piston Ring Set: | Total Seal 4.200" Steel Top $130.00
Add Main & Rod Bearings: | Clevite "H" Chamfered $169.99
Balance Rotating Assy.: | Balance Rotating Assy. $225.00
Select Reluctor Wheel: | 58X Tooth Reluctor Wheel $60.00
________
$4,088.99
PRC LS7x 265cc 7.0L CNC Heads
Item# 199-265LS7 $1,899.99
Valve Spring Options: | PRC .700" Lift Double Spring Kit $475.00
Valve Options | 2.200"/1.61" Titanium Intake \ Stainless Exhaust $850.00
________
$3,224.99
Texas Speed LS7R Camshaft
Item# 25-LS7R $374.99
Comp Cams LS7 Magnum Pushrods
Item# 4-7913-16 $144.99
Comp Cams LS1 Gen III Solid Roller Lifters
Item# 63-8950-16 $429.99
World Products Warhawk LSX Engine Block Kit
Item# 28-WP0865154125 $4,899.99
Select Deck Height: | 9.800" $0.00
________
$4,899.99
all from texas-speed.com select 2010 camaro, engine and valvetrain and find these parts. will get you over 620rwhp(over 750 hp) then get a new era otr intake, arh lt headers, and slp loudmouth 1 or 2 axleback. then you will have 680+rwhp(over 825hp)!!!if you want to hit 1000hp get a maggie supercharger.
not a good idea to take it to hennesey.
also you will need new brakes.
2010 CAMARO SS RS is offline   Reply With Quote
Old 08-21-2009, 04:14 PM   #34
CamaroSpike23
The Jalopy Jedi
CamaroSpike23's Avatar
Send a message via MSN to CamaroSpike23 Send a message via Yahoo to CamaroSpike23
http://www.mastmotorsports.com/gascrate.php
Originally Posted by Bulldogwinters View Post
Read that link that Spike posted, it'll tell you everything you need to know.
I piss excellence
and fart awesomeness
Old 08-21-2009, 10:26 PM   #35
old motorhead
Drives: Maggie blown LS3 vette
TVS 2300 + blower cam + long tubes + free flowing exhaust + ported tbody @ 8+psi will get you there. It works in my vette. Don't see why it wouldn't work in a Camaro.
old motorhead is offline   Reply With Quote
Old 08-22-2009, 05:32 AM   #36
hollywoodGU
Drives: 1999 Firebird Formula
As for the Camaro, I'll tell you this much:
Of power, reliability, and cheap: pick 2
haha
yup another way cars are like woman, you want three things but can only get two. but with girls its you can pick two between: sane; hott; single.
hollywoodGU is offline   Reply With Quote
Old 11-23-2009, 10:10 AM   #37
tones2SS
tones2SS's Avatar
Drives: 13 Roush S3 05 Dodge Ram Daytona
Thumbs up
If you were going to do the upgrades one at a time, then you are wasting more money. Save up and get it all done at once. that way, all the little "bugs and snags" can be worked out. (LPE is a good company as well.)
GOOD LUCK!!
Nickey Chicago to offer Phase III 700HP version of 2010 Camaro SS!!! Hylton 5th Gen Camaro SS LS LT General Discussions 198 12-11-2010 11:58 AM
700HP Camaro big_dog General Automotive + Other Cars Discussion 0 07-14-2009 03:38 PM
