Cold Air Inductions
Old 08-15-2009, 12:44 PM   #1
Croathlete
Danny
Croathlete's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via AIM to Croathlete
Anyone else missing this screw?
So I was doing my 2000 mile oil change this morning when I noticed what looked like a missing screw near the oil filter in the oil pan case. Check out the picture attached. If any of you are under your cars anytime soon, could you take a peek and see if yours is missing as well?
2SS/RS CGM with black rally stripes
DON_RAFA describing my Noweeds cutouts - "Very Strong. When I couldn't see you I still heard you. Sounds like your car is pissed at the world."
Please help me fight back by supporting me in the 2010 American Cancer Society's Relay for Life. Every little bit helps. Click here for more information. Thank you to those that have donated!
Croathlete is offline   Reply With Quote
Old 08-15-2009, 01:26 PM   #2
Tanner
Tanner's Avatar
I just tried to crawl under there. I don't have ramps anymore. Not much room and I'm slightly claustrophobic so I could not get that far under. I'm betting it was used for moving it when the engine was built. The motorheads on here will be able to answer.
2SS/RS Victory Red / painted White Rally Stripes - 6 Speed Automatic with Tap Shifter
Sands - Surprise
Tanner is offline   Reply With Quote
Old 08-15-2009, 02:53 PM   #3
Timberline
Timberline's Avatar
Drives: 2010 SS/RS,LS3,M6,VR
I would expect since this block is used in many GM products from trucks to Cadillacs it is for a bracket mount for one of the other vehicles.
2SS/RS, Victory Red, Black Leather, LS3, 6spd, Polished wheels - R6P -
Timberline is offline   Reply With Quote
Old 08-15-2009, 11:03 PM   #4
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
Don't worry your not missing anything. There are random bolt holes on the sides of every block I have ever seen. Probably used for something at the factory or like Timberline said mounting brackets for another model.
Superman09 is offline   Reply With Quote
Old 08-17-2009, 07:45 PM   #5
camero
Drives: IOM V6 RS 38808
Nobody's going to check?
I've known how to spell Camaro since before you were born.
camero is offline   Reply With Quote
Old 08-18-2009, 05:38 PM   #6
canadian ss
Psycho on day pass
canadian ss's Avatar
Drives: 2010 yellow 1ss m6 -GM tech
Every block has holes in it. I assure you nothing goes there. There is nothing missing. Maybe someone at a casting facility can chime in? Possibly for an engine stand at the factory?
canadian ss is offline   Reply With Quote
Old 08-18-2009, 05:52 PM   #7
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
thats where the flux capacitor mounts to the motor.
seriously tho, as said above, you arent missing anything. engines have come with "empty" holes for years to be swapped in different cars/trucks etc and for different accessories as well
I piss excellence
and fart awesomeness
Old 08-18-2009, 07:01 PM   #8
Croathlete
Danny
Croathlete's Avatar
Haha, I wasn't trying to cause the latest "panic de jour" as Scott liked to call it. If it's typical for commonly used blocks to be missing screws in certain applications, that's a good enough explanation for me.
Old 08-31-2009, 02:50 PM   #9
SS4PK
SS4PK's Avatar
Drives: 2010SS
yes I noticed nothing in that hole too, I figured no big deal and did not think anything was missing. I suspected what others have posted, or is was a hole used for a bolt while installing the motor.
Her Hot Rod.
SS4PK is offline   Reply With Quote
Old 09-07-2009, 09:28 PM   #10
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
Just don't forget to set your date and time when you hit 88 miles per hour. Oh yeah, and the 1.21 jigawatts octane fuel!
Order date: 7/17/09
3000 TPW: 8/17/09
3400 status on 8/11/09
3800: 8/21/09
4200: 8/24/09 on rail car ETTX850796
5000/6000: 9/2/09
crzycicada is offline   Reply With Quote
2SS Infotainment System Options Missing 2010SSRS Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 18 06-29-2009 02:20 PM
Twin Screw Supercharger and Gear Ratio usmcjlp Forced Induction - V8 2 06-27-2009 02:50 PM
Missing air filter on a 01 Cavalier jstein General Automotive + Other Cars Discussion 4 06-06-2009 10:33 AM
New Twin Screw for Camaro by Techco coming? Calimaro Forced Induction - V8 33 06-05-2009 12:07 AM
Exterior foglights don't work? Might be missing the button? Camaro007 5th Gen Camaro SS LS LT General Discussions 62 05-23-2009 08:59 AM
