Cold Air Inductions
Old 08-15-2009, 07:27 PM   #1
Double O Nick
Double O Nick's Avatar
Drives: 2010 Camaro 2LT
Send a message via AIM to Double O Nick
Help with Halos
So I got the bumper off, Took out the headlights. Come to find out what is stopping me from having new orange Halos is my HID enclosure I cannot get to any of the screws to remove the lens. Is the HID enclosure different then the Halogens enclosure?
Delivered May 29th: 2010 Chevrolet Camaro 2LT RS Cyber Gray Metallic,Inferno Orange Interior,Polished Rims.
Double O Nick is offline   Reply With Quote
Old 08-15-2009, 07:55 PM   #2
Double O Nick
Still havent figured it out been trying non stop. no way to reach them.
Old 08-15-2009, 08:50 PM   #3
BigBOSS
BigBOSS's Avatar
Drives: 2010 Camaro 1LT/RS, 6M, IBM
You have to put it in the oven to soften the glue and pry off the front lens with a butter knife.
2010 Camaro 1LT/RS
Mods: Staggered 20" Lexani LX15 Wheels, Airraid CAI, AAC Blue LED Dome/Trunk Lights, AAC LED License Plate Lights, AAC LED P13W Running Lights w/Harness, Metra Radio Kit, Kenwood DNX9960 DDIN Radio, JL Audio 10" W6 Sub, JL Audio 500/1 Amp, ******** Sub Box and Amp Rack, AeroExhaust Resonators
BigBOSS is offline   Reply With Quote
Old 08-15-2009, 09:24 PM   #4
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
It was suggested to me on another forum about my current car to use 200 degree heat for about 10 minutes to soften the glue on my corner lights. I once did it for about 40 minutes and got a bit more of it loosened up.
I think it all depends on the glue, but I wasn't able to seperate my corner lights and wound up breaking them.
skuttduck is offline   Reply With Quote
Old 08-16-2009, 10:57 AM   #5
Double O Nick
Tried the oven thing. Lens wont even budge I can see screws just not sure how to approach them. No access.
Old 08-16-2009, 11:30 AM   #6
CustomCarWorx
Drives: 2013 THR ZL1 Black Vert
Non-RS Headlights
Nick,
Can you take a picture of the headlight and post? I might be able to help. Just want to make sure I am looking at the same part.
Gary
Custom Auto Worx
CustomCarWorx is offline   Reply With Quote
Old 08-16-2009, 12:09 PM   #7
Double O Nick
Yeah just gimme a sec
Old 08-16-2009, 12:41 PM   #8
Double O Nick
Man my camera is dead but the housing has six screws you can see from the front of the enclosure. I will have to take pictures tomorrow.
Old 08-18-2009, 02:37 PM   #9
Gromet
Gromet's Avatar
Drives: 2010 1SS, Auto, Moonroof.
Any update on this? Did you get into the enclosure?
Gromet is offline   Reply With Quote
Old 08-18-2009, 02:50 PM   #10
Double O Nick
No still have not. May just send it to ACC.
Old 08-31-2009, 08:35 AM   #11
Moonshade
Moonshade's Avatar
Drives: ABM LS
if you go to www.youtube.com there is an instructional video. I believe they are installing the Oracle brand halos. I watched since I plan on changing mine out seemed to be helpful. Good luck hope it works out for you.
Moonshade is offline   Reply With Quote
Old 09-06-2009, 09:28 AM   #12
CiscoBee
Drives: 2010 Camaro Rally Yellow 2LT
I tried the oven to the point that I started melting the plastic. There is NO WAY to get that assembly apart.
I believe the screws are only holding the black molding to the lens, they don't hold the entire fixture together. Once the assemble is opened, you can get to the screws from the inside.
Name:  LIGHT HOUSING.jpg
Has ANYONE figured a way to get them opened without breaking them???
CiscoBee is offline   Reply With Quote
Old 09-06-2009, 10:32 AM   #13
KTCAM
HPE 600
KTCAM's Avatar
Drives: 2010 Black 2SS w Inferno Orange
Look at the RED arrows i placed on the photo . thats where you have to start to pry open the thing after placing it in the oven @270 degrees for 20 min.The screw what you are pointing to with the white arrowns are NOT to open the headlamp. Once opened they will let you remove the inner mounting hardware which you do NOT NEED to play with once opened. It HARD to open them up. I had to place in the oven about 4 times for the first headlamp to get it to open. Once you get it a little separated with a screwdrive & just enough to get your fingers underneath it to pull it open its easy. The trick to get it cracked open with the srew driver without breaking it. Whwn i replaced it in the oven I just let it for 5 min. just to keep the glus soft. The first headlamp took me 1 hour to crak it. The secound one took 3 times in the oven & 30 min.total once I knew how much force was needed to open them up.
srory about the long rant
KTCAM is offline   Reply With Quote
HALO's / HID's Beyond Limits Cosmetics and Lighting Modification Discussions 31 12-21-2010 09:30 AM
Blue Halos sdill Cosmetics and Lighting Modification Discussions 14 07-30-2009 10:27 AM
Halos - Cool Little Tidbit DDustiNN 5th Gen Camaro SS LS LT General Discussions 35 07-07-2009 10:37 AM
Halos of the Camaro Devil-eyes Cosmetics and Lighting Modification Discussions 13 02-09-2009 08:15 PM
