Old 08-16-2009, 05:11 AM   #1
clubbdawg
clubbdawg's Avatar
Drives: 2010 Camaro 2SS/RS - A6
ARH Longtubes arrived last night . . . a couple of questions for DIY installers . . .
Can I create enough clearance under the front of the car to install these headers using jack stands?
I have all the necessary tools, but no access to a lift. Floor jack and jack stands are my only DIY option. Advice greatly appreciated.
Cheers.
clubbdawg is offline   Reply With Quote
Old 08-16-2009, 05:46 AM   #2
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
Check out post #18... looks like you should be good to go....
http://www.camaro5.com/forums/showth...103#post780103
Old 08-16-2009, 07:24 AM   #3
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
Yes, you definetly can do it on the floor w/ Jackstands. I di mine on the Camaro on a bud`s lift this time. My last set of ARH`s on my 06 Vette I did on Jack stands in the garage, no problem.The headers themselves will be a breeze. The tuff part is mating everything up at the axleback on the floor. It doesn`t give you much room to finagle things. It can be done but it may extract some choice words and phrases from your vocabulary...such as... The headers and the X-pipe really go up easy, and if you have trouble w/ the rear portion you could always install the headers and the x and then take it to an exhaust shop to have them mate the rear up.
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 08-16-2009, 08:50 AM   #4
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Here is my write-up on the ARH header install. Yes, you can do it on jackstands. Make sure you have a Sawzall and all the required tools before removing the OEM system though.
http://www.planetlsx.com/tech/How_To...0_Camaro_SS/98
Tony
Fquick.com/NineBall
Old 08-16-2009, 02:09 PM   #5
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
I did mine on jackstands. It was aggravating crawling around under the car but it got done.
Tip: After making the install, loosen all clamps to make minor adjustments in the routing. It's is difficult to adjust one connection without loosening the clamps on either side of the one you are working on. Make sure it is not too close to the floorboards or the driveshaft and that the OEM mufflers are settled properly in their hangers. Don't forget the 4 aluminum spacers for the crossmember.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 08-16-2009, 04:28 PM   #6
JDBeck23
Drives: 2010 Camaro, 2SS/RS
I did mine on a jackstands with a creeper... the creeper will save you at least an hour not having to inchworm your way in and out from underneath the car, definitely recommended!
And +1 to everything CWIweldace said... be mindful of ALL clamp positions before you cinch everything up, make sure by adjusting the position of the pipes you havent accidentally backed any of the pipes out... and cinch those clamps down SUPER tight or you'll have leaks.
2010 2SS/RS CGM
American Racing Headers, Magnaflow axle back, Roto-Fab CAI, Audio Integrations Sub box, Alpine Type R 10, Alpine MRP-500 amp, Pro Clips iPhone Mount
JDBeck23 is offline   Reply With Quote
Old 08-16-2009, 04:29 PM   #7
Tom@ARH
Drives: 2003 Corvette ZO6
Assemble everything loosely then work from the headers back adjusting as you go. please be sure to use at least 4 quality jackstands don't want to see anybody get hurt using cheap stands.If you have any questions PM me or call the shop 631-608-1986
Tom@ARH is offline   Reply With Quote
Old 08-16-2009, 11:51 PM   #8
khislop007
ZEUSS
khislop007's Avatar
Drives: Hard!
I can't wait to get mine and do the same!
Old 08-17-2009, 03:49 AM   #9
salohi
salohi's Avatar
Drives: 90 Black Camaro, 02 Sable
very intresting
2SS/RS
Black/Black
6Spd. Aut.
salohi is offline   Reply With Quote
Old 08-17-2009, 06:32 PM   #10
JDBeck23
didya get em on??
2010 2SS/RS CGM
Old 08-17-2009, 11:52 PM   #11
clubbdawg
clubbdawg's Avatar
Not yet. Just turned 1250 miles. Going to wait until I have her serviced at 1500 miles. Then I'll install and tune. Anticipation . . .
I'll take pix and post once I get started.
Cheers.
